Old 09-24-2004, 02:45 PM
mandzach's Avatar
mandzach
Dealer : Findlay Toyota Scion
2003 Toyota Tundra,
2007 Toyota Tacoma SILVER-DC-OR-4x4
Last Online: 10-13-2007 12:40 AM
mandzach is on a distinguished road.
mandzach's Photo Albums
Default Gas pedal on 03'+ (lets fix it!)
OK gang the guys with 03's+ know all about the 3/4 throttle position giving way to wot but full pedal down lends to less than wot....so
i was out looking around under the pedal and was thinking if i could put somthing under the pedal so it would attach to the bottem of the pedal (and never fall off accidentally) then i could limit the travel leading way to 3/4 throttle position.
the underside of the pedal is formed plastic with holes in it- i was wondering about some high density foam or rubber cut to fit tight in the holes---
any other ideas?
2007 Tacoma 4x4 DC/SB - Total Chaos UCA's, Donaho Racing CO's, Deaver Springs, 33" Toyo MT's
.................................................. .................................................> Built for Desert Fun!
Need Tranny Mods?--> IPT Valvebody calibration IPT Transmissions
Old 09-24-2004, 07:12 PM
Muleskinner's Avatar
Dealer : I-10 Toyota Scion
2004 Toyota Tundra
Last Online: 03-15-2008 04:37 AM
Muleskinner is on a distinguished road.
Muleskinner's Photo Albums
any other ideas?
What are you talking about???? 3/4 throttle gives way to WOT??? And full throttle does not. I've got a new 04 and I don't have that problem.
I know when you accelerate from a stop at about 1/2 to 3/4 throttle, you can feel the ECU continue to open the throttle plate even without moving your pedal, but this is normal for a "drive by wire" type of a ECU controlled throttle.
If I press the throttle to the floor, the ECU will open the throttle plate wide open and hold it there. So you have me confused.
04 DOUBLE CAB SR5 DESERTSAND MICA, CUSTOM FABRICATED Y PIPE, JET PERFORMANCE STAGE TWO ECU REMAP, RACOR REMOTE A/T FILTER, ROADMASTER RAS (REAR)
Old 09-27-2004, 03:13 PM
bwilder10h's Avatar
Dealer : Kings Toyota
2003 Toyota Tundra
Last Online: 06-15-2007 11:02 AM
bwilder10h is on a distinguished road.
bwilder10h's Photo Albums
I was kinda disappointed that the Unichip install didn't do away with this feature.
I'd like to mat it and melt the rear tires if my heart desires (it doesn't most of the time). It does aggravate me that I can't even power brake it from a dead stop though...
Old 09-27-2004, 03:31 PM
atrdnut's Avatar
2003 Toyota Tundra
Last Online: 11-16-2009 11:53 AM
atrdnut is on a distinguished road.
Send a message via AIM to atrdnut atrdnut's Photo Albums
Default Mmmm... melted rubber...
Originally Posted by bwilder10h
...It does aggravate me that I can't even power brake it from a dead stop though...
Yes you can... (click the devil smiley face...)
-Austin
-Austin
2003 Toyota Tundra SR5 TRD Sport
Old 09-27-2004, 03:59 PM
bwilder10h's Avatar
2003 Toyota Tundra
-Austin
Was that water under your tires?
My truck will only power brake if I'm on wet or slick pavement. From a dead stop on dry pavement, it won't even turn them over at all. It's sad really...
Old 09-27-2004, 04:35 PM
atrdnut's Avatar
2003 Toyota Tundra
Default You can do it!
It was bleach under the tires - I can smoke the tires on dry pavement - if you look at the video, you will see a second set of marks...that's where I missed the bleach (oops ). My tires were dry at that time. You just need to finesse your truck a little bit. You can do it.
-AJ
-Austin
Old 09-27-2004, 04:38 PM
bwilder10h's Avatar
2003 Toyota Tundra
-AJ
What do you mean by finesse? Please elaborate...
Old 09-27-2004, 08:45 PM
atrdnut's Avatar
2003 Toyota Tundra
Default elaborate
Well...the brake pedal is your friend - don't have it all the way down or you'll go nowhere - I think if you let it (brake) out just a little bit, you'll fake out the torque converter. At least that's what I have come to the conclusion... I have the brake out just enough to make the truck inch forward. At that point, go back and forth with the brake and gas to where you have a nice equilibrium. I wish I had some more concrete evidence to support you with, and what I have told you thus far may be extremely inaccurate. My apologies. However, I do know that with a little bit of practice, one can break the rear end loose on dry pavement. I'm sure there are some variables that may cause your rear end to have a more difficult experience breaking loose such as meaty tires, lack of power (i.e. headers, exhaust, etc.), and inexperience. If you have some crappy tires that you want to burn off before your next set, just play around with your truck. C'mon, it's a Tundra, it's going to hold up. You have no weight in the rear end - something has to give. I hope I have helped in the least bit. Good day.
-Austin
*BY THE WAY* - I'm not advocating any exhibition of driving - Please, if you're going to mess around, make sure it's on a closed road or somewhere you won't get hurt. Thank you.
-Austin
Old 09-27-2004, 09:27 PM
jim65wagon's Avatar
Dealer : Palmiero Toyota
2003 Toyota Tundra SR5 4x4
Last Online: Today 05:23 AM
Images: 3
jim65wagon is on a distinguished road.
Send a message via AIM to jim65wagon jim65wagon's Photo Albums
-Austin
Maybe you should just hold a "burnout school". Did you have a good day at school kids?! The old RT's are definitely burnout material, but my opinion is you are faking the ABS rather than the converter. In either case they'll burn if you learn. Practice practice practice, eventually everyone can do it well.
2003 SR5 V8 4x4 Access Cab; SS Autochrome intake with AEM dryflow; Truxedo cover; Rhino lining; 255/85/16 Cooper Discoverer S/T's; 16x8 Black Steel Wheelers; Ram Air; breather extensions; Viair 380COBA; Donahoe coilovers; Deaver 3leaf AAL; homemade bed rack; 21 gallon water tank, front Hidden Hitch w/Superwinch...
The 140,000 Mile Tundra Thread
Old 09-28-2004, 01:32 AM
atrdnut's Avatar
2003 Toyota Tundra
Arrow Class starts 7:00 pm
Well said, jim Next week: donut lessons
Old 09-28-2004, 02:23 AM
Last Online: 12-09-2006 04:30 AM
Bradley is on a distinguished road.
Bradley's Photo Albums
Default Problem Solved ???
Just find a Ford F-150 Vintage 92-96 5.0- 5.8 Liter , with the shifter in D at the count of 3, mash the gas pedal to the floor and then feather the gas pedal to prevent igniting the tire and pavement. Class Over
Old 09-28-2004, 08:27 PM
Last Online: 06-27-2007 03:53 PM
Hazardous Street Racing is on a distinguished road.
Hazardous Street Racing's Photo Albums
You can power brake.. trust me... sometime you want to hit the gas alittle and then hit the brake to get the truck to go forward and it should start spinning... I would make a instructional video but... forget the but... i might do it and post it on here When i did it umm my ABS light turned on :P hehehe The LSD worked well too
Old 09-29-2004, 08:55 AM
bwilder10h's Avatar
2003 Toyota Tundra
In my 96 Chevy with the 350, powerbraking was a breeze. None of this having to work it to get the tires to turn over.
The 4.7 should have plenty of low end (even with duals) to get the rear loose anytime you want. There has got to be a way around this gas pedal garbage.
Old 10-01-2004, 10:11 PM
silverTRD's Avatar
Dealer : Torrance Toyota
2003 Toyota Tundra
Last Online: 02-26-2009 08:56 PM
silverTRD is on a distinguished road.
Send a message via AIM to silverTRD silverTRD's Photo Albums
i agree, this gas pedal crap is annoying. tell me how a stock s10 v6 can hang with me.
MODS: who cares, nothing you have'nt heard already
Old 10-01-2004, 10:28 PM
Verndog's Avatar
Dealer : Doxon Toyota
2003 Toyota Tundra
Last Online: 10-30-2009 07:17 PM
Verndog is on a distinguished road.
Verndog's Photo Albums
any other ideas?
Ya...I actually designed a billet pedal cover that has an adjustable bolt stop under it for fine tuning. I'm just am too damn busy to follow up on it. If we get 20 guys wanting one I'll make it..need that to cover tooling costs. I'll post a cad model in the next week.
Kevin
2003 Silver Sky TRD SR5 V8 4x4 Access Cab
My 69 Mach 1 Pics
Factory Options:
TRD Offroad / Limited slip / Tow package / 130 amp alternator / Temp.-compass-autodim mirror.
Appearance Mods:
PPDBillet throttle & fuse covers /Weld Outback forged billet wheels / Smittybuilt nurfs / Bullbar / Leer Legend Canopy / Line X / billet antenna.
Performance Mods:
Chromex-ceramic coated S&S autochrome headers / Custom dual H crossover 2 1/4 into Magnaflow duals- rear exit / 265 75 16 Bridgestone Revo's .....R A P S /True Flow intake / Underdrive Pulley /Hellwig anti-sway bar / Timbren load springs-rear / Wheelers 2.0 leveling coilovers / Infinity x6. / Unichip PnP
