Old 10-11-2004, 06:46 PM
Last Online: 10-26-2008 10:14 PM
Tundra2UZ is on a distinguished road.
Tundra2UZ's Photo Albums
Default '03 Tacoma 2.7 PCV Valve Question
I have a '03 Tacoma DC with the 2.7 liter 4 cylinder. This evening I bought a genuine Toyota PCV valve for it since it is comming up on 30,000 miles. I noticed that the valve has threads on it instead of the traditional "pull-out-type" valve. There is a pink coating on the threads of the new PCV valve. Is this the right valve for this engine? I ask this because looking at the Haynes manual for the 1995-2000 model years, there is a picture of the same engine with the "pull-out-type" valve.
Also, if the threaded valve is the right type of valve for this engine, is the original factory valve hard to remove? If so I may just use the "if it ain't broke don't fix it" rule and just leave the old one in for at least another 20,000 miles since I use Amsoil 100% synthetic oil.
Old 10-11-2004, 11:10 PM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 32
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
The newer VVTi Toyota/Lexus V6's have a thread-on valve,so they probably have done the same for the 4-cylinders. My guess for the change,less chance of a vacuum leak at higher mileage since there's no rubber grommet that hardens with heat and oil contact. The pink coating is a anti-seize or sealer.
It won't hurt replacing the valve,the usual replacement interval is at 60,000 miles. Removal isn't hard,should be a 17mm wrench or socket.
2004 Tacoma automatic trans question SellthatNissan Engine & Drivetrain 5 03-15-2004 12:42 AM
PCV Valve? adamkn Engine & Drivetrain 6 01-07-2004 02:05 PM
Tacoma: Is there a PCV valve on 2.7 Liter '03 4 Cyl? Tundra2UZ Engine & Drivetrain 2 10-12-2003 05:54 PM
INFO: PCV Valve Maintenance nhparrot Knowledgebase Archive 0 07-30-2002 06:29 AM
