LinkBack (9) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #16 (permalink)
Old 11-12-2004, 11:14 PM
Last Online: 09-10-2005 12:10 AM
tamu_tundra is on a distinguished road.
tamu_tundra's Photo Albums
Originally Posted by PagalDesi4Life
I might have a similar problem. On a level of 1-10 (10 being the most difficult), what would you grade this whole "operation" for someone who has a good amount of knowledge in mechanics?
I'd give it about a 6. Thanks to this BB, you know what to do. Its mainly just time consuming. Just make sure you note how everything is hooked up before taking it apart. If I had to do it again, I'd probably take a digital pic of the connections. I had a buddy of mine helping, and we both assembled the same side we took apart. Seemed to work pretty well. It also helped having an extra hand to lift the intake assembly out...
  #17 (permalink)
Old 11-13-2004, 02:05 AM
PagalDesi4Life's Avatar
2001 Toyota Sequoia
Last Online: Today 05:32 AM
Images: 2
PagalDesi4Life is on a distinguished road.
Send a message via AIM to PagalDesi4Life PagalDesi4Life's Photo Albums
How long did it take you? I am hoping I will have my friend help me work on this, he knows a wealth about mechanics. Is there a step by step instruction on this BB on how to do it?
  #18 (permalink)
Old 11-13-2004, 09:22 PM
It took us about 4-hours from start to finish. I enjoy doing stuff like this, but don't consider myself very experienced by any means... So I would imagine you can probably do it quicker. I basically followed Victor and Eddie's posts off this thread for the instructions. Disconnect the lines going to the throttle body, fuel rails, and upper plenum assembly, unbolt the 10-12 bolts going into the head, pull out the assembly, remove the (tiny) starter/solenoid, repair the solonoid as posted, and put everything back together.
  #19 (permalink)
Old 12-08-2004, 10:48 AM
Dealer : Hayward Toyota
leadsled is on a distinguished road.
leadsled's Photo Albums
Thank you all for the information. I'm ordering the parts and doing this soon.
My Tundra seems to have the intermittent start problem more and more these days. It will click 3 or 4 times....then start up like there was no problem.
A special thanks to tamu tundra for posting the part numbers, and mustang67408 and eddie for the detailed instructions!
leadsled
  #20 (permalink)
Old 12-08-2004, 05:29 PM
Dealer : Stevens Creek Toyota
Last Online: 08-16-2009 10:56 AM
akauth will become famous soon enough.
akauth's Photo Albums
Before you go to all that trouble you might want to replace the relay first. I had the same issue. I actually even replaced the starter, but the problem came back. Once I replace the relay, I had it happen one time after that and it's not happened since. And that was sometime this summer I finally swapped it out. It's about $50 and 10 minutes of work. It's probably a LOT less if you can find the relay at other than Toyota.
But it's solved my problem and I had exactly the same issue. It was getting worse and worse. I even swapped the battery out - but I'm glad I did that anyway.
My system works like a champ now and I didn't have to resort to the contact change. I think what happens is that the relay is too weak to have the contacts connect properly and eventually they become a problem. But if you fix the relay, then the contacts don't matter so much as they hit solidly now.
Mine use to happen mostly when it was hot and off for 10 minutes and restarting. Or when it was cold in the morning. Now it never happens. And I'm glad because it was getting me mad since it was happening since 6,000 miles!
Alan
leadsled
  #21 (permalink)
Old 12-09-2004, 12:45 AM
Thanks akauth,
I will definitely change the relay first, then if that doesn't fix it, I will change the contacts.
leadsled
  #22 (permalink)
Old 12-21-2004, 04:02 PM
tamu tundra,
What was the difference in the two different part numbers for the contacts. I'm looking at the parts in the two bags and they appear to be identical.
I just want to make sure I get the correct parts on the correct side of the starter.
By the way, my starter is part of the "Cold Weather Package", so the part numbers for the contacts are different than yours: 28226-72010, 28226-74070.
leadsled
  #23 (permalink)
Old 12-21-2004, 06:39 PM
I'm really surprised that replacing the relay didn't solve your issue. I've got the same starter and after I replaced the relay it's been fine. Even through this cold weather when it always used to occur in the mornings.
I did have the issue happen one time right after I replaced the relay (at about the normal interval of every couple, three weeks) but after that time it hasn't happened and it's going on six months now.
I think the issue is that the relay isn't strong enough for some reason and the contacts don't touch like they should. After a while they might get some buildup which then interfers. But a good solid contact fixed the issue for me. I figured either it was relay in the system or the switch, but a relay would be my first guess. If it was 150,000 miles later I would have thought it was a hard contact issue somewhere. That's when starters are usually toast.
Alan
tamu tundra,
leadsled
  #24 (permalink)
Old 12-21-2004, 07:31 PM
akauth,
Yes, I too was hoping that it was just the relay. Oh well, I guess I know what I'll be doing over Christmas Holiday.
leadsled
  #25 (permalink)
Old 12-21-2004, 08:38 PM
akauth,
leadsled
Be sure to take lots of digital pictures along the way. I'm sure that it easier for anyone else doing it. Too, sooner or later people are going to have to replace the starters and it would nice to have that documented before it starts happening in a major way since it's such a headache.
alan
  #26 (permalink)
Old 01-03-2005, 02:42 AM
Default contacts replaced
akauth,
Well, the new contacts are in. I also changed the starter relay.
The truck starts just fine now. I didn't take a lot of pictures, but the few I did take will be posted soon.
This job is fairly straight forward, but it was a real pain getting the two bolts that hold the starter in. Just no room in there for my hands!
leadsled
  #27 (permalink)
Old 01-05-2005, 01:55 PM
ekunst's Avatar
Last Online: 03-18-2005 07:30 PM
ekunst is on a distinguished road.
ekunst's Photo Albums
Smile i give it a 7
the work in general is not that hard if you are experienced at mechanicial repairs and have a good torque wrench. there is more adversity involved in this job because after you have removed the intake plenums and runners you have to lay on top of the fender/engine bay to be able to reach the starter bolts and wire harness securing bolt. the starte bolts are accessed on the firewall side of the engine and are not the easiest to work with. patience is the main key here...and good luck!
  #28 (permalink)
Old 10-16-2006, 12:43 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: Yesterday 02:10 PM
Images: 22
Default Re: Starter / Replacement Contacts
thread resurrection...this had the best tech advice of the threads i looked at.
this morning, first time ever, roughly 130K miles, got the massive CLICK sound when i turned the key.
battery has plenty of juice, contacts are clean, everything is except no turnover just a CLICK. it's not the pop-pop-pop-pop sound like when the battery is low or whatever, and i assume the CLICK is the relay engaging.
it did start after a couple turns of the key, first it did about a quarter turnover, sounded like a huge GRUNT, then stopped. next round it started like normal.
does this sound like the same problem? if so, i will do the same procedure outlined by eddie and mustang. if thats the case, where's the best place to disconnect the fuel line from the intake plenum group?
and also it sounds like i disco the t/b from the plenum and leave it in the bay, but remove the plenum/rails/etc...correct?
what sort of sealant/gasket maker stuff goes between the plenum and block, if any? just the factory gasket?
thanks much
-sean
GFX by FreedomEagle50
Manual Hubs
  #29 (permalink)
Old 10-16-2006, 05:15 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
does this sound like the same problem?YES if so, i will do the same procedure outlined by eddie and mustang. if thats the case, where's the best place to disconnect the fuel line from the intake plenum group? Drivers side at the back of the plenum is where the fuel line attaches, its a 22mm wrench
and also it sounds like i disco the t/b from the plenum and leave it in the bay, but remove the plenum/rails/etc...correct?Yes unbolt the TB,but leave the water hoses connected to it. The injector rails can stay bolted on too, just remove the 6 bolts and 4 nuts that hold the manifold down to the heads. There are 2 6mm bolts that hold the wire harness down back by the firewall , they need to come out too. Once all the hoses and stuff are out of the way the manifold assy can be lifted straight out and the starter is below it. MAKE SURE TE BATTERY IS DISCONNECTED FIRST.
what sort of sealant/gasket maker stuff goes between the plenum and block, if any? just the factory gasket? Just the factory gasket, no sealer needed.
thanks much
-sean
Hope this helps
25 yrs with TOYOTA
  #30 (permalink)
Old 10-16-2006, 05:43 PM
Images: 22
would it help if i pulled the fuel pump fuse, let the engine die, then disconnected the fuel line? so as to reduce pressure in the line when i disconnect that 22mm nut?
Manual Hubs
LinkBack to this Thread: http://www.tundrasolutions.com/forums/engine-and-drivetrain/31638-starter-replacement-contacts/
Posted By For Type Date
Procedure for replacing 100 series(98 and up) starter contacts - Page 5 - IH8MUD Forums This thread Refback 05-06-2009 04:06 AM
Procedure for replacing 100 series(98 and up) starter contacts - Page 4 - IH8MUD Forums This thread Refback 02-28-2009 01:54 AM
Procedure for replacing 100 series(98 and up) starter contacts - Page 3 - IH8MUD™ Forums This thread Refback 06-30-2008 01:19 AM
Procedure for replacing 100 series(98 and up) starter contacts - IH8MUD™ Forums This thread Refback 06-22-2008 10:29 PM
90K and Starter replacement job - IH8MUD™ Forums This thread Refback 06-22-2008 08:25 AM
KirklandZoo: WorldZ beZt car... This thread Refback 07-21-2007 07:26 AM
90K and Starter replacement job - IH8MUD.com Forum This thread Refback 04-06-2007 01:56 AM
KirklandZoo: November 2006 This thread Refback 01-02-2007 12:45 AM
Yahoo! Answers - toyota tondra starter? This thread Refback 10-27-2006 04:51 PM
Have you had STARTER problems? grofva Engine & Drivetrain 12 09-10-2009 11:33 PM
96 Corolla 7A-FE starter removal? cwebb Corolla Matrix 3 08-18-2004 10:49 PM
Where can I get a wiring diagram for 02 SQ to install a remote starter ? Marcin 1Gen-Sequoia 3 12-08-2003 11:46 AM
What is the BEST remote starter? rc10solidus Electrical & Computer Systems 10 01-14-2003 01:32 PM
J & J Grille replacement pzencka 1Gen-Sequoia 10 04-02-2002 03:53 PM
