LinkBack (9) Thread Tools Display Modes
  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 10-18-2004, 01:31 AM
Last Online: 09-10-2005 12:10 AM
tamu_tundra is on a distinguished road.
tamu_tundra's Photo Albums
Default Starter / Replacement Contacts
Need some help...
V8-2wd 2001 Tundra 84k-miles... and have what I believe is a starter problem. Symptoms are solenoid clicking with each turned key and then finally a startup after 4-5 tries. I've checked the battery and have cleaned all battery terminals.
I've searched through all the other threads, and it looks like most people have narrowed this down to the starter contacts. I want to go to the dealer and ask for these contacts, but I don't really know what I should be asking for. Is it the contact internally between the solenoid and the starter? In other words, would I need to take apart the starter and replace these contacts? If so, how many are there?
Or is it the battery contact on the outside of the starter? It seems that if the solenoid is clicking then this contact would be okay? I'm just guessing...
Also, from reading the other threads it seems you have to take off the air intake manifold. I'm assuming this is just the air-filter and surrounding box? Or it is a lot more involved than this?
Any help is much appreciated. I'm getting tired of playing starter-roulette every morning before going to work...
Old 10-18-2004, 01:55 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Dealer : Findlay Toyota Scion
2002 Toyota Tundra,
- Other - 1967 Mustang,
2005 Toyota Prius,
2005 Toyota Tundra DC,
2008 Toyota Sienna RAMPVAN
Images: 164
Originally Posted by tamu_tundra
Need some help...
V8-2wd 2001 Tundra 84k-miles... and have what I believe is a starter problem. Symptoms are solenoid clicking with each turned key and then finally a startup after 4-5 tries. I've checked the battery and have cleaned all battery terminals.Sounds like the starter
I've searched through all the other threads, and it looks like most people have narrowed this down to the starter contacts. I want to go to the dealer and ask for these contacts, but I don't really know what I should be asking for. Is it the contact internally between the solenoid and the starter? YES In other words, would I need to take apart the starter and replace these contacts?YES If so, how many are there?2 of them, and you have to clean the armature for the windings.
Or is it the battery contact on the outside of the starter? NOT likely It seems that if the solenoid is clicking then this contact would be okay? I'm just guessing...Nope it is an internal starter contact failure.
Also, from reading the other threads it seems you have to take off the air intake manifold. I'm assuming this is just the air-filter and surrounding box? Or it is a lot more involved than this? It is the Air filter/a/f hose/ intake manifold, along with the injectors and rails, fuel line, return line, emmision hoses. it can be done as a unit with 2 people. It is quite heavy to lift out of the truck.I would also suggest replacing the intake manifold gaskets while your in there.
Hope this helps
25 yrs with TOYOTA
Old 10-18-2004, 05:54 PM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 32
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
I've done several Lexus LX470 starter replacements. They use the same engine so the following tips can be applied:
Like Victor said,most of the parts can be removed as a single unit. The throttle body,fuel injectors/rails,and upper plenum stay together. All you need to unbolt are the lower manifold nuts (ones that go into the head).
When removing the intake manifold nuts,shove some kind of sticky stuff in the socket (I use butyl rubber sealer). You do not want to drop those nuts when reinstalling them.
Be prepared to spill coolant,there are coolant lines going into the throttle body that have to be disconnected. Clamping the hoses with needlenose visegrips help reduce the mess.
Open the gas cap to relieve some fuel pressure. Have rags handy when loosening up the fuel connections at the rails. Smoking during this stage of the job is a bad idea
Ratcheting box-end wrenches make removal of the actual starter bolts easier. 14mm size.
You will probably have to sit/lie in the engine bay to get most of this work done. Have something comfy to sit on,you'll be there for a while.
Old 10-18-2004, 06:30 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Be prepared to spill coolant,there are coolant lines going into the throttle body that have to be disconnected. Clamping the hoses with needlenose visegrips help reduce the mess. You dont have to remove these lines , just lay the throttlebody off to the side, once you remove the 4 nuts.
Excellent advise
25 yrs with TOYOTA
Old 10-18-2004, 08:05 PM
Thanks Eddie and Victor- definitely helps get me prepared for this. I've replaced a starter on Chevy before, but it was nothing like this!
Victor, you mention to clean the armature for the windings. What do you typically use and do to clean them? Any trick to opening up the starter?
-Kent
Old 10-18-2004, 08:31 PM
Eddie's Avatar
Moderator
2000 Toyota Tundra,
Images: 32
Damn,now you tell me Next LX470 I'll do that.
Old 10-18-2004, 09:05 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Once the starter is out, you only have to remove the rear plate. 3 - 8mm bolts. The contacts unbolt with a 12mm wrench. Do 1 side at a time.
The armature winding you will have to remove to get to the contacts, has a ring on it, it will be black and burnt looking. Just use some fine sanding paper to scuff it nice and shiny again, go easy on it and dont take off to much copper, just enough to get it clean not spotless.
Let us know how it turns out
Eddie and i will keep our ears open.
Good luck
25 yrs with TOYOTA
Old 10-18-2004, 09:26 PM
Parts are coming in on Thurs (btw, $8 each for the 2 contacts and then ~$30 each for the 2 gaskets), so I probably won't get a chance to tackle this until Sat.
I'll keep yall (yes, I'm Texan!) posted... thanks again.
Old 10-23-2004, 10:30 PM
Just wanted to thank yall again for the help. Everything went smoothly and replacing the contacts seemed to solve the problem.
I still can't believe the starter was actually under there...
Old 10-23-2004, 10:35 PM
2002 Toyota Tundra,
2005 Toyota Prius,
Images: 164
Have a cold 1 (or 2 ) for us.
WHOOOOOO AHHHHHHHH!!!!!!!!!
25 yrs with TOYOTA
Old 10-23-2004, 10:49 PM
Verndog's Avatar
Dealer : Doxon Toyota
2003 Toyota Tundra
Last Online: 10-30-2009 07:17 PM
Verndog is on a distinguished road.
Verndog's Photo Albums
My hat is off to you! Good job...and you have a heck of a lot more patients then I...I would have footed the $900.00 bill and saved the cuss words for the California drivers.
Kevin
2003 Silver Sky TRD SR5 V8 4x4 Access Cab
My 69 Mach 1 Pics
Factory Options:
TRD Offroad / Limited slip / Tow package / 130 amp alternator / Temp.-compass-autodim mirror.
Appearance Mods:
PPDBillet throttle & fuse covers /Weld Outback forged billet wheels / Smittybuilt nurfs / Bullbar / Leer Legend Canopy / Line X / billet antenna.
Performance Mods:
Chromex-ceramic coated S&S autochrome headers / Custom dual H crossover 2 1/4 into Magnaflow duals- rear exit / 265 75 16 Bridgestone Revo's .....R A P S /True Flow intake / Underdrive Pulley /Hellwig anti-sway bar / Timbren load springs-rear / Wheelers 2.0 leveling coilovers / Infinity x6. / Unichip PnP
Old 10-28-2004, 04:55 PM
Dealer : Hayward Toyota
leadsled is on a distinguished road.
leadsled's Photo Albums
My Tundra may have the same problem, however, when I hit the key...there is no "click" noise....just silence. When I let off and try again it fires right up.
As of today, it seems to be working fine. I hate these intermittent problems. They are sometimes difficult to pin down.
Could you please post the part numbers on the invoice, so when I go into the dealership I have some idea what to tell the parts guy. I will also have some way of checking the part numbers before the order is placed.
Thanks.
leadsled
Old 10-28-2004, 09:16 PM
No problem:
Intake Manifold Gaskets (PN 1717150020)
QTY-2 @ $30 each (both sides identical)
Solenoid Contacts (PNs 2822650070 & 2822650080)
QTY-2 @ $8.43 each (different kit for each side)
There are two sizes of alternators used in the V8s (1.4kW & 2.0kW), but I believe the starter contacts are the same for both.
Also, there is another gasket you come across when you remove the solenoid end cover. I didn't bother replacing this as looked pretty good and seemed to just serve as a debris barrier.
I'm by no means an expert, but just to make sure things are clear... My starter was only clicking once (the solenoid hitting the armature contact)- not clicking repeatedly (like when you have a low battery).
If it's not making any noise, then maybe power just isn't getting to your solenoid? You've probably done this already, but it might be worth while to make sure you have a good connection at your battery...
Let me know if you need anything else...
Old 10-29-2004, 01:14 AM
Dealer : Stevens Creek Toyota
Last Online: 08-16-2009 10:56 AM
akauth will become famous soon enough.
akauth's Photo Albums
I was having the same issue. I replace the starter with a new one. Same issue after a while. Finally, this summer I replaced the starter relay in the fusebox and it happened one more time and that's been it for the problem for me.
Usually it would happen about once a month or so. Seems to be gone for me. Hasn't happened in a while.
Alan
Thanks.
leadsled
Old 11-12-2004, 03:30 PM
PagalDesi4Life's Avatar
2001 Toyota Sequoia
Last Online: Today 05:32 AM
Images: 2
PagalDesi4Life is on a distinguished road.
Send a message via AIM to PagalDesi4Life PagalDesi4Life's Photo Albums
I might have a similar problem. On a level of 1-10 (10 being the most difficult), what would you grade this whole "operation" for someone who has a good amount of knowledge in mechanics?
LinkBack to this Thread: http://www.tundrasolutions.com/forums/engine-and-drivetrain/31638-starter-replacement-contacts/
Posted By For Type Date
Procedure for replacing 100 series(98 and up) starter contacts - Page 5 - IH8MUD Forums This thread Refback 05-06-2009 04:06 AM
Procedure for replacing 100 series(98 and up) starter contacts - Page 4 - IH8MUD Forums This thread Refback 02-28-2009 01:54 AM
Procedure for replacing 100 series(98 and up) starter contacts - Page 3 - IH8MUD™ Forums This thread Refback 06-30-2008 01:19 AM
Procedure for replacing 100 series(98 and up) starter contacts - IH8MUD™ Forums This thread Refback 06-22-2008 10:29 PM
90K and Starter replacement job - IH8MUD™ Forums This thread Refback 06-22-2008 08:25 AM
KirklandZoo: WorldZ beZt car... This thread Refback 07-21-2007 07:26 AM
90K and Starter replacement job - IH8MUD.com Forum This thread Refback 04-06-2007 01:56 AM
KirklandZoo: November 2006 This thread Refback 01-02-2007 12:45 AM
Yahoo! Answers - toyota tondra starter? This thread Refback 10-27-2006 04:51 PM
Have you had STARTER problems? grofva Engine & Drivetrain 12 09-10-2009 11:33 PM
96 Corolla 7A-FE starter removal? cwebb Corolla Matrix 3 08-18-2004 10:49 PM
Where can I get a wiring diagram for 02 SQ to install a remote starter ? Marcin 1Gen-Sequoia 3 12-08-2003 11:46 AM
What is the BEST remote starter? rc10solidus Electrical & Computer Systems 10 01-14-2003 01:32 PM
J & J Grille replacement pzencka 1Gen-Sequoia 10 04-02-2002 03:53 PM
