Old 10-19-2004, 10:53 AM
TIE-YOTA's Avatar
Dealer : Ron Carter Toyota
2004 Toyota Tundra
Last Online: 12-05-2008 08:57 AM
TIE-YOTA is on a distinguished road.
TIE-YOTA's Photo Albums
Default Overdrive?
When do you use Overdrive?
Previous Trucks Owned:
1990 Toyota Xtra-Cab 2wd (145,000 miles)
1996 Toyota Tacoma Ext. Cab 4wd (171,000 miles)
2004 Toyota Tundra DC 4wd (Phantom Grey - 48,700 miles and counting)
Toyota truck user for 16 years and counting..........
Also known as Thibodeaux at the Fuge.
Gig'em Ag's (Class of '94)
Modifications on DC to date:
3" Toytec lift, 1.5" Add-A-Leaf, Line X, Eagle Alloys Series 101 16x8 (3.60 B.S.), 285/75/R16's Cooper Discoverer ST's
Old 10-19-2004, 11:01 AM
peid's Avatar
Dealer : Billion Motors
1996 Toyota T100
Last Online: 01-05-2009 08:49 AM
Images: 31
peid is on a distinguished road.
peid's Photo Albums
All the time unless towing something large and heavy.
1996 T100, 180,000 and counting
Old 10-19-2004, 11:04 AM
czechm8's Avatar
Dealer : Jay Wolfe Toytota
2005 Toyota Sequoia,
- Other - Acura TL
Last Online: Today 06:04 PM
czechm8 is on a distinguished road.
czechm8's Photo Albums
Yes, always unless towing or ascending a steep grade when loaded down. Also, if you live in a low altitude region and travel to higher altitudes, you may want to disable the O/D to gain more revs and torque.
Old 10-19-2004, 11:11 AM
TIE-YOTA's Avatar
2004 Toyota Tundra
Yeap, which brings me to my next question. From a towing standpoint, what do you think the break over load (lbs.) would be for switching over? You can tell the overdrive needs to be ON due to RPM increase when it is OFF under normal conditions. The thing I was curious about and wondering is what the break over load lbs. is?
Old 10-19-2004, 12:19 PM
czechm8's Avatar
- Other - Acura TL
I don't think there is any specific weight you can assign to "when to use the O/D." The road conditions and grade are much bigger factors. Your manual probably states that if the tranny keeps wanting to shift in and out of O/D while towing, then disable the O/D to save the gears and keep the tranny heat down. If you are on a level grade cruising down the highway, then you are probably OK with using the O/D.
Let the feel in the seat of your pants tell when you need to disable the O/D. The tranny will do all talking for you.
Old 10-19-2004, 12:39 PM
TundrastruckDave's Avatar
Dealer : Greenville Toyota
Last Online: 11-22-2009 10:16 PM
Hey TIE-YOTA,
Whas..up?! Saw your question above and thought I'd offer my 2¢ worth.
Fact is... I honestly... have NO IDEA what an actual "weight cut-off point" might be? But I think czechm8 is right. It's a good "rule-of-thumb" which, has worked well for me, over the years. You probably have already used this "method" before... when towing, but in most cases... it works. You know the old saying: "an ounce of prevention... is worth a pound of cure". Better to "err" on the safe side. Anyway... let's say you're towing in overdrive... and you're on relatively "flat ground" (i.e. no long grades or hills such as in the foothills of a mountain range)... and the overdrive keeps kicking "in-n-out" when you encounter... even a minor grade... then... a GOOD "rule-of-thumb" would be... you DEFINATELY... DO NOT... need to be in overdrive.
Truth is though... I'd have to agree with you. It'd be nice to have an actual "weight cut-off point" for "when" and "when not" to use overdrive. But taking into consideration the many variables in driving conditions... as czechm8 said... such as terrain... that makes it even harder to "pin-point" a specific "weight cut-off point". A load being towed over flat terrain... might be O.K. for using overdrive... while the same exact load... towed over hilly terrain... may require that you take the truck "out" of overdrive.
As I said... it's just my 2¢ worth anyway. Sorry I couldn't be of more help.
Cheers,
Dave
Mods to Date:
Mods to Come:
265/75/16 BFG A/T's,
Possible Mods:
Old 10-19-2004, 12:42 PM
Boxer's Avatar
Dealer : Penney Toyota
2003 Toyota Tundra
Last Online: Today 01:29 PM
Boxer is on a distinguished road.
Boxer's Photo Albums
I towed 4 tonne (crushed stone) in a trailer this morning and kept the overdrive off the whole time (highway/in town).
Is overdrive always on? Brklyndriver Highlander 8 09-13-2006 01:19 PM
Help with disengaging overdrive beag03 Suspension & Axle 4 04-15-2004 03:59 PM
Towing Weight And Overdrive Question ?? ZIGGY454 Engine & Drivetrain 17 01-28-2004 08:35 AM
Use overdrive when towing? BrettDanKen Engine & Drivetrain 4 03-02-2003 01:33 PM
overdrive unit tundraidaho Engine & Drivetrain 2 03-31-2002 06:06 PM
