Old 11-06-2004, 01:19 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
Default AEM Brute Force - install and review write-up
Thanks to Lon(creator of Tundrasolutions.com) for allowing me to do this write-up in order to receive a free AEM Brute Force Intake system. The AEM model number is 21-8401. This is specific to 00-03 Tundras and Sequoias with the 4.7L V8 motor. There are two models. The one I received, the intake pipe is silver in color. The other model has a polished intake pipe.
Tools needed for the install: Either a 1/4" or 3/8" ratchet will do, 10mm deep socket, 12 mm regular socket, 12” extension(didn’t have one so, I used 2 6” extensions), flat head screwdriver and a philip screwdriver.
(Click on the thumbnails to view a larger picture. All but one pic is 1024x768)
The picture below shows all the parts that are included in order to install the kit. As well as a cleaning kit for the filter. My first thoughts of the kit was, that this is just another intake system, just like any others out on the market. I’ll post my review at the end of this.
The next photo shows the stock air box. I originally modified my stock air box by cutting a huge hole on one side to allow more air. I also had a TRD drop-in filter. I have no complaints so far. Other than, I shouldn’t have cut that big hole. Anyways, onto the rest of the pics.
I first removed the throttle body cover using a 10mm deep socket. This allowed me to gain access to the hose clamp that holds the stock intake pipe to the throttle body.
The hose clamp is loosened with a phillip screwdriver. You can also use an 8mm socket.
Next is the removal of the MAF(mass air flow sensor) with the use of the same phillip screwdriver.
With a 10mm socket, I removed the bolt holding the AC line to the stock intake pipe.
To remove the bolt that holds the stock air box, a 10mm socket and 2 6” extensions were used to get to the one closest to the headlight.
The next two are located on the opposite side of the airbox. I only used one 6” extension and the 10mm socket. A few more things to disconnect and the intake system will be ready to remove.
Disconnect all four of the hoses that are connected to the stock intake system. 3 out of the 4 hoses will be replaced with new ones provided in the kit. The only hose you keep is the power steering air hose. That’s the one on the side separate from the other three.
Once everything is disconnected and unbolted the complete stock air intake unit can be removed. You may have to tug a little on the stock elbow to remove it. Here’s a pic of it removed.
The lower tab of the heat shield will be held in place and bolted down to the wiper motor relay bracket. Use a 12mm socket to remove it.
With a 10mm socket, this is where you’ll need to remove the stock bolt from the power steering reservoir bracket. The heat shield will mount onto this.
I got this picture from Off-Roadweb.com. I forgot to take a picture of the rubber edges installed prior to installing it into the truck. So with that in mind, install the two rubber insulators on the top of the heat shield and the rubber edging on the edge that is towards the front of the truck.
Mount the heat shield onto the stock location of the power steering reservoir bracket. Then tighten with a 10mm socket
The lower tab of the heat shield is bolted and tightened down with a 12mm socket. I had a problem here with the hole not lining up correctly. I had to persuade the bolt in with a little bending of the heat shield at the crease.
After installing the heat shield, ensure the wire, located in the picture below, has enough clearance as to not be pinched by the heat shield.
Next is to install the new AEM elbow. However, before doing so, this would be a good time to clean out your throttle body(TB) with a paper towel and TB cleaner. Install the elbow but, do not tighten the hose clamp.
With the rubber mount included in the kit, install it into the location where the stock air box bolts into (closest to the motor).
Before you install the intake piping, run a paper towel through one end to the other or blow some air through it to clean out any debris. Then install the 2 rubber grommets and the 2 hose fittings. It’ll be a lot easier to do now instead of in the engine bay.
Now, install the intake pipe into the new elbow, don’t tighten the hose clamp. You’ll see why later.
Here’s a pic of the intake bracket mounted onto the rubber mount. Place the washer then the nut on top of the bracket and again don’t tighten it down yet.
Reattach all the hose fittings onto the proper fittings with the new hoses(total of 3) and hose clamps. Each hose is a different size, so you shouldn’t have a problem attaching the wrong hose to the wrong fitting. Then tighten the hose clamps down.
Reattach and tighten the AC line bolt onto the new location on the intake piping with a 10mm socket.
The filter is now ready to be installed. You may have to move the piping a bit to get some clearance and install the filter. This is where not tightening the hose clamps and intake bracket comes in handy. Once you’ve determined everything is in place tighten all the hose clamps and bolts.
After tightening all the hose clamps and bolts install the throttle body back on and you are finished.
Here’s the finished product all installed. I’ve added a little touch to the intake piping.
After taking it out on the freeway and city streets, the response when I step on the gas is a bit more responsive and power gains are not a huge noticeable difference. However, I can notice some or maybe it’s just a “placebo effect.” When I’m on the gas hard the engine screams or it could be the AEM intake screaming. Not so much of an annoying scream but more like “I can breath and I have more power,” type of scream. Without any dyno test of my own, I won’t be able to really tell how much of a gain or loss I incurred throughout the RPM band. Maybe I should add my name to Herbicidal’s list for the dyno run. I can do a stock modified(big gaping hole on the side) intake run and the AEM Brute Force run. We’ll see what happens.
Again, thanks Lon for the kit!
Mike
http://dyogim.blogspot.com
Old 11-06-2004, 10:23 PM
Genthar's Avatar
Last Online: 11-05-2009 09:51 PM
Genthar is on a distinguished road.
Genthar's Photo Albums
It took my system a while to adjust after installing mine. It definitely roars when you romp on it, but, my butt dyno is unsure if there's any boost in power among the low end. Then again, it doesn't feel any worse either. I seemed to notice that after the install the tach seemed to climb more rapidly and freely than before, but I have no empirical data to back that up other than my own mental metronome.
Keep in mind too about the heat shield...while you're actually moving, you have quite a bit of air blowing through the compartment...the shield doesn't have to be air-tight to be effective at that point. Any heat shield is gonna be fairly useless when you're sitting about idling...even one that's sealed from the compartment is still going to absorb and radiate heat at that point.
Genthar
Old 11-06-2004, 10:50 PM
rxvcgiii's Avatar
Dealer : Frontier Toyota
2006 Toyota 4Runner
Last Online: 06-04-2009 06:12 PM
rxvcgiii is on a distinguished road.
Send a message via AIM to rxvcgiii rxvcgiii's Photo Albums
I'm gonna have to agree with this. I bought my intake for the sound. I know I haven't lost any power, but it really doesn't seem like I've gained any either. The intake is all bark and no bite... but that's alright... because it is one damn powerful bark!
Armada 176 AR5s Skis, Look P12 Jib Bindings, Rossignol Bandit B1 Boots, Scott Poles... in the bed of a 2000 V8 Tundra 2x4 Access Cab with:
JBA Titanium Coated Headers, Stone Mountain Racing Y-Pipe, Flowmaster 50 Exhuast, Teamwest Sway-A-Way Coilovers, Camburg Upper Control Arms, Wheeler's Add-A-Leafs, AEM Brute Force Intake, MB Quarts, US Acoustics Amp, Bazooka Tube, Lots of Dynamat, A.R.E. LSII Tonneau Cover, Sir Michaels Rollpan, Bushwacker Flares, Shaved BSM, Billet Grilles, Mickey Thompson Classic Locks, 305/70/16 Pro-Comp X-Terrains, Lots of little things here and there. Future Projects: Color-Coded White Rear Bumper and Tailgate handle, Revalve SAWs, Deaver 11 Leaf Packs, Bilstein 5100 Rear Shocks.
All this info repeated here!
Old 11-07-2004, 02:28 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
I've also noticed when I mash on the pedal, the intake starts to whistle a bit. Any of you notice this as well? I do agree that the sound from under the hood, sounds pretty good.
Mike
Old 11-07-2004, 06:16 PM
Genthar's Avatar
Yah, it will whistle a little...sounds kind of like a turbo charger spooling.
Genthar
Old 11-08-2004, 01:54 PM
Herbicidal's Avatar
Just a Herbicidal maniac.
2001 Toyota Tundra,
2008 Toyota Yaris Sedan 'S' Flint Mica,
2009 Toyota Corolla 'S' Barcelona Red
Last Online: 11-20-2009 01:17 PM
Images: 150
Herbicidal's Photo Albums
Thumbs up
Nice write-up Mike!
Old 11-08-2004, 05:19 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
Originally Posted by herbicidal
Thanks Herb.
How many tundras do you have for the dyno run and when is it planned for? I may have to join in on the group run but, I won't know for sure until the end of this month.
Folow-up review on the kit:
I'm on the pedal harder than before but, the get up and go from a full stop seems to be bit better than before.
Mike
Old 11-08-2004, 05:41 PM
Herbicidal's Avatar
2001 Toyota Tundra,
Images: 150
Thanks Herb.
6 at the moment, 2 with superchargers. No date planned yet, so there is plenty of time for you to sign up . Dyno shop still working out the quirks.
Now back to the regularly scheduled thread...
Old 11-08-2004, 09:56 PM
kmatoy's Avatar
Dealer : Kearny Mesa Toyota Scion
Last Online: 10-10-2006 08:55 PM
kmatoy is on a distinguished road.
kmatoy's Photo Albums
I have the AEM intake on my Tundra. So far I like the sound of it and it seems as if I am getting a few more miles out of a tank now, but my truck used to be able to break the tires loose and since the install I can only do it if I am turning around a corner... seems as if there is a bit of low end loss???
Old 11-09-2004, 04:12 PM
TheGryme's Avatar
Supportive Supporter
Dealer : Valley-Hi Toyota
2004 Toyota Tundra,
- Other - 1992 Toyota 4Runner
Last Online: Yesterday 03:41 PM
Images: 23
TheGryme will become famous soon enough.
TheGryme's Photo Albums
Default Question for Dyogim regarding stock air box.....
Nice Write Up......
Hey, in it you mentioned that you cut a hole in the stock air box......and that it was a mistake. Why? What happened that you say this was a mistake?
I'm thinking about modifiying the stock AB on my '04 by enlarging the hole from the AB thru the fender, from the stock......really small size of maybe 2 inches to possibly 4 inches and still retain the stock AB , just with a much larger intake.
Any feedback?
TheGryme Ummmm Beer Good.....Whiskey Better!
'04 Tundra DC
Grey....V8 SR5 4X4 TRD Off Road Suspension, LSD, Towing Package, Toyo Open Country A/T 265 75 16 ~ 8 Ply's, Magnaflowed (w/ Secret AirBox Mods!), UNIChipped, True~Flowed, DeBadged, ScanGaged, XM'ed.....Yeah!
'92 4Runner
Black, V6, Downey / Rancho suspension F&R, 3 inch sus lift, 1 inch body lift, SAW T-Barz, 4:88's, ARB (rear), 32X12.50 BS Dualers on AR 8X15 Wheelz, Power Slots and Pads, Downey headers, MagnaFlo Muff, K&N FIPK, Ported heads, 1 piece stainless valves...way too much money in it!
'04 YZ250F
Dr.D Header and Can, JD Jetting, P38 AP, UNI Flame Proof Air Filter, No Back Fire Screen, Carbon Fiber Carb Heat Shield, Renthals, ASV Controls....
'87 Nissan Pathfinder......gone but not forgotten.
Old 11-09-2004, 04:34 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
Originally Posted by TheGryme
Nice Write Up......
Any feedback?
I didn't gain anything form it. Here's how big the hole is:
Mike
Old 11-09-2004, 05:50 PM
TheGryme's Avatar
2004 Toyota Tundra,
Images: 23
That's pretty big but it looks like it would just suck in more air from the engine compartment...mostly hot, I think. I'm kinda thinking about increasing the size of the pipe thing that connects to the underside fender cold air intake stuff. Stock just seems so small an opening. I don't want to go to a K&N FIPK.....I run one on my 4Runner with a dry wrap and I still will get some "dust" inside the elbow just b4 the throttle body . Maybe a RAP?
'04 Tundra DC
'92 4Runner
'04 YZ250F
Old 10-15-2007, 02:06 PM
Dealer : Alpine Toyota
2003 Toyota Tundra
Last Online: 12-31-2007 09:14 AM
drvmtlltheydrp is on a distinguished road.
drvmtlltheydrp's Photo Albums
Default Re: AEM Brute Force - install and review write-up
anyone have a factory intake system that would fit on my 2003 tundra ltd after i take off the brute force cold air intake???
Old 10-15-2007, 02:19 PM
apimpdad's Avatar
2002 Toyota Tundra
Last Online: Yesterday 08:16 PM
Images: 57
apimpdad is a splendid one to behold. apimpdad is a splendid one to behold.
Send a message via AIM to apimpdad apimpdad's Photo Albums My eBay
post this in the classifieds sections as a wanted item.
SAS Tundra
Build Thread-
SAS on 02 Tundra
