My switch leads are just rolled up in the glove box for now. My original plan was to replace the blank switch filler plug on my center console with a real switch. However, when I removed the center console to see what is behind there, I discovered this is easier said than done. However, I think I can use the PC sub-assembly from the Access Cab and adapt it to my Double Cab, but I haven't yet tried to locate the assembly. On the Access Cab this location has the cargo light switch, which would be perfect for the fuel map because it consists of a SPST switch plus an LED. I would replace the silk screening with "Fuel Map A/B". If that doesn't work out, I'll just mount them in my glove box.
Note: The Hazzard Warning light is located in the same position on the DC and AC, and is part of the same sub-assembly. I am hoping that it will mount right up to the DC center console main assembly PC board.
Double Cab
Access Cab
