This is a discussion thread titled "Replacing Serpentine Belt", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
  #16 (permalink)
Old 11-17-2007, 06:51 AM
Puffnstuff's Avatar
Puffnstuff's Photo Albums
Last Online: Today 06:25 PM
Puffnstuff is on a distinguished road.
Default Re: Replacing Serpentine Belt
I swapped mine out in less than 10 minutes and it can all be done from up top.
My DC has: Python 990 Alarm System, Eclipse AVN5500 Navigation System w/80gb ipod & eclipse speakers, Kenwood KAC-X20 Amp, 10" Kicker Solobaric L5, UWS Black Deep Toolbox, Nasta SS Nerf Bars, Rugged Liner Bed Liner, AVS chrome bug shield, EGR in channel vent visors, Goodyear Fortera Tripletreds, Optima Red Top Battery
  #17 (permalink)
Old 11-17-2007, 01:41 PM
Burger Steak & Eggs's Photo Albums
Last Online: Today 06:56 PM
Burger Steak & Eggs is on a distinguished road.
Yep, took me about 15 minutes.
  #18 (permalink)
Old 11-17-2007, 04:49 PM
Hi Volt's Avatar
Dealer : Sunrise Toyota - Abbotsford
Hi Volt's Photo Albums
Last Online: Today 01:29 AM
Hi Volt is on a distinguished road.
Originally Posted by jajeh5 View Post
So I broke down and had a shop replace the belt today. On my way home I noticed a small whinning noise that would get higher pitched with engine rpm. Anyone have any suggestions?
Top idler pulley bearing will make that noise, almost has a bad PS pump sound to it. The pulley and bearing are purchased as one piece from the dealer. Tried to buy just the bearing from a number of bearing wholesalers, but the exact size isn't listed even though I had the part number. Apparently the manufacturer only produces it for Toyota. The ID and OD are readily available , however the thickness is oddball, can buy either thinner or thicker bearings, each of which are not close enough to do the job properly. The cost of the complete unit wasn't all that bad as I remember anyway, and two minutes to install. Was able to just slack the belt without removing, and change the pully ( just one bolt and east to get at ).
  #19 (permalink)
Old 12-01-2007, 01:22 PM
kwilson's Avatar
2005 Toyota Tundra
kwilson's Photo Albums
Last Online: 07-24-2008 01:56 PM
kwilson is on a distinguished road.
Just finished cleaning up from doing my belt. I think the belt portion of the job was 15 minutes. Then there was the cleaning of various engine parts and covers, removing corrosion from the positive battery terminal and putting everything away. 1 hour total. Hearing from others helps build the confidence to do the job solo.
Thanks
2005 Double cab, only Mod is the 3 child seats in the back seat.
  #20 (permalink)
Old 12-01-2007, 01:28 PM
Unfortunately you may be doing this again soon.
  #21 (permalink)
Old 12-01-2007, 01:50 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
HOGWILD's Photo Albums
Last Online: Today 07:16 PM
HOGWILD will become famous soon enough.
Let me run this by everyone. I am not a engine guru but I just purchased the replacement belt for my truck and was wondering how difficult this is to replace and if anyone has a step by step I could walk through.
You had to change belt on your 2007 Tundra? This seems strange because their is a TSB for the 06's to fix the squeal. why would their not be one for an 07 for free??
  #22 (permalink)
Old 12-02-2007, 01:20 PM
Johnny Law's Avatar
Dealer : Haddad Toyota
2005 Toyota Tacoma
My eBay Johnny Law's Photo Albums
Last Online: 10-06-2008 09:03 AM
Johnny Law is on a distinguished road.
Look at the starting date of this thread, I think he originally had an 03 Tundra.
"Si vis pacem, para bellum"-Vegetius
2005 Tacoma Doublecab TRD Offroad 4X4 shortbed - Modifications - Fog light mod, Debadged, Black Toyota grille emblem, Map Light Mod, DRL mod
Factory Accessories - Tacoma Bedmat, Extra set of D-rings installed in front bed bolts, Extra set of factory tie downs
Optional Options - FilterMag, Fumoto valve, Westin Suregrip running boards w/LED lights, WeatherTech Floorliners, WeatherTech window visor vents, Prestige remote car starter w/keyless entry, SilverStar headlight and turn signal bulbs, Toytek 2" lift, Muth heated signal mirrors, WAAG grille guard (center only, I'm old school), Taillights tinted by JonsTintedTails.com, Anthracite FJ Cruiser wheels w/ 265/75r16 BFGoodrich A/T
  #23 (permalink)
Old 12-11-2007, 10:59 PM
wirelessf's Avatar
Dealer : Waipahu Toyota
2001 Toyota Tundra,
- Other - 1990 Toyota 4Runner
wirelessf's Photo Albums
Last Online: Today 07:19 PM
wirelessf is on a distinguished road.
I finally changed mines due to the horrible squeak at cold startups. I thought it was a lubrication problem, but with the truck at 57K and still has the original toyota belt, I see no reason not to change it. I used a napa replacement belt, but kept the old one just in case.
01 Toyota Tundra
DRL disable mod -TB coolant deicer bypass - rear diff extended breather - poly steering rack bushings -fog light mod - remote ATF filter - Trueflow intake w/ stock filter - SS Autochrome headers
