This is a discussion thread titled "Freezing in Alaska heater/engine issues", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-12-2005, 10:50 PM
jwlak's Avatar
jwlak's Photo Albums
Last Online: 04-25-2007 07:16 PM
jwlak is on a distinguished road.
Default Freezing in Alaska
Hi Guys I hope someone will have an idea or two. I have 2002 tundra with the 8cyl. I love the truck but I can’t get much for heat out of it. I live in Alaska and it’s rather nice to have a truck that has a good working heater. I can start the engine and let it run for 15 min. 20 min an hour or two or more and the temp gauge will not come up more than 1/8 to 1/4 off the peg depending on the outside temp. At an Idle the air is luke warm. Going down the road the temp gauge is up maybe 1/3 off the peg. At best the air coming out of the heater vents is a little better than luke warm until I drive driving down the road maybe five miles then I start to get a little better temp. However it still is nothing to brag about. I have taken it to the dealer twice for this problem. The first time they told me that I had a loose clamp on the lower radiator hose and it was sucking air causing the problem. I'm still smiling about that. They changed the thermostat at my request however this did not help. Now they say it is within the spec and there is nothing wrong with it. I have talked to several people that have Tundra’s and they all say that they have great heaters. So guys any help would be greatly appreciated.
Old 01-12-2005, 11:35 PM
anmrivera's Avatar
Dealer : Performance Toyota Of Lavista
2003 Toyota Tundra,
2005 Toyota Sienna
anmrivera's Photo Albums
Last Online: 09-18-2008 07:56 AM
anmrivera is on a distinguished road.
Don't know about the 02's but on mine under the hood mounted on the firewall is the control for the heat control. If you have a partner go inside and turn the heat knob you will see it moving. If when in the full hot or cold position you see a gap between the two "long points" you need to adjust it so there is no gap. Sorry for being so vague but it is about 10 here and I am not going outside to look under the hood! LOL
2003 Tundra 4x4 Access cab V-8, SR5, Silver Sky Metallic, TRD Off-Road package, Tow package, LSD, cold weather prep. package, Running boards, Convienence Package, Line-X bedliner, debadged, 4 window visors, Blue Cyber Eyes, $5 rs3200 upgrade , Fog light mod.
2005 Sienna LE 8 PAX, White, Full Curtain airbags, Tow prep package, VSC, Rear Disk brakes, rear audio, aftermarket entertainment center(will be bought soon)
I'm a proud Toyota Bigot!!!
Midwesterners checkout the midwest forum!Click here
Old 01-12-2005, 11:44 PM
BlueRanger's Avatar
Dealer : Toyota Carlsbad
2004 Toyota Tundra
BlueRanger's Photo Albums
Last Online: 09-02-2008 08:47 AM
BlueRanger is on a distinguished road.
Send a message via AIM to BlueRanger
My heater is a beast, yours definitly needs some tlc
04 Tundra, Hoes, Uni's, Spintech, 285s + other misc. bling items.
Old 01-13-2005, 12:00 AM
jwlak's Avatar
The Dealer checked that out one of the times I took it there. Then I also did a check myself and it does appear that its opening all the way.
I have been told that Ford and Chevy have a restrictor in the line going to the heater so as not to allow a full flow. I wonder if Toyota also does the same?
Old 01-13-2005, 12:03 AM
DevinSixtySeven's Avatar
Dealer : Voss Toyota
Last Online: Yesterday 09:50 PM
wait a sec, you mean your engine temp guage never moves beyond 1/8 to 1/4 up the dial? it should climb to, and stay at, about halfway. wish i could help troubleshoot but i dont really know anything about engines, just posting where my guage sits for reference.
-sean
GFX by FreedomEagle50
Manual Hubs
WTB: Passenger side headlight housing and signal light housing, OEM Toyota, for 2000 Tundra
Old 01-13-2005, 12:07 AM
Invid's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra
Invid's Photo Albums
Last Online: 10-02-2008 08:42 PM
Invid is on a distinguished road.
They might have a restricter in there somewhere but the heater in my 2002 Tundra is a fire breathing dragon. I only need to let it idle for about five minutes then the heater blows out very warm air, five minutes more and on low it's almost unbearably hot.
Spintech 3332XL Muffler | Hellwig Rear Anti-Sway Bar | Updated 2005 Tail Lights | Updated 2003 Alloy Wheels | AMSOIL OAF-15 Oil Filter | Ultra-Strong Oil Filter Magnet | Synthetic Fluids all around | Line-X Bedliner | Osram Silverstars | Michelin LTX M/S tires | Custom Grille w/updated Body Panels | De-Badged | Optima Spiral Cell Gel Battery
Old 01-13-2005, 12:27 AM
cubic22's Avatar
Dealer : Durant Toyota
2002 Toyota Tundra
cubic22's Photo Albums
Last Online: 05-08-2008 07:19 AM
cubic22 is on a distinguished road.
Send a message via Yahoo to cubic22
Post
I reccomend a little more research.
Here are a few threads to get you started.
This was on an highlander
This one seems a little more promising.
Keep us updated.
JOHN
Old 01-13-2005, 12:28 AM
jwlak's Avatar
-sean
Yes at an Idle that is as far as it goes. When I am running down the road it will go up to about 1/3.
Old 01-13-2005, 12:32 AM
Invid's Avatar
2002 Toyota Tundra
And that is year round too? Not just in winter? That is so odd because these 4.7L V8 engines run hot.
Old 01-13-2005, 12:34 AM
cubic22's Avatar
2002 Toyota Tundra
Exclamation
I would also concur in devin's note that it isn't normal that i have seen for engine not to warm up to mid level.
JOHN
Old 01-13-2005, 12:45 AM
jwlak's Avatar
Originally Posted by cubic22
I would also concur in devin's not that it isn't normal that i have seen for engine not to warm up to mid level.
I sure wish I could get the dealer to understand this. I had the service writer ask me if I had tried putting cardboard in front of the Rad that maybe that might fix it. I really apprecitate the posts guys. If nothing else I at least know that there are 02 Tundras out there that have good heaters.
Old 01-13-2005, 01:02 AM
cubic22's Avatar
2002 Toyota Tundra
BTW, thread has been moved to engine forum.
JOHN
Old 01-13-2005, 02:07 AM
AV8R's Avatar
Dealer : Uniontown Toyota Scion
AV8R's Photo Albums
Last Online: 09-19-2008 03:26 PM
AV8R is on a distinguished road.
The dealer's on the right track with the cardboard helping. You don't want to restrict the entire radiator though. Something doesn't sound right with the temp gauge not going around 1/2 way and you said they replaced the t-stat. The other thing you can do is install a block heater for those cold mornings but that just helps get the oil temp up a little before you crank it over. Good luck with this one. Just a thought, but maybe another dealer will have a different perspective.
2006 Tundra V8 Salsa Red Pearl Dbl Cab, Limited 4x4, Leather Interior w/ Htd Captain Chairs, SRS Side Curtain Airbags, Moonroof, All weather guard, DRL's, LSD, Rear Audio, Overhead Console, Touch Screen DVD Navigation, Line-X, Husky Liners, VSE Bazooka Sub, Retrax Bed Cover.
Curiosity killed the cat but satisfaction brought him back.
Old 01-13-2005, 02:36 AM
jwlak's Avatar
Yes I should have mentioned that the truck is has a soft plug engine heater, to heat the water. a pad heater on the oil pan to heat the Oil and a another pad heater on the transmission to keep it warm as well as a pad heater on the Batt. to keep it warm. I think the most of my heat is comming from being pluged in (smile). This is normal equipment for Fairbanks Alaska. The truck for the most part does not know how cold it is.
Old 01-13-2005, 09:18 AM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4
LGL002's Photo Albums
Last Online: Yesterday 04:44 PM
LGL002 is on a distinguished road.
I'm assuming because of your location all of the Tundra's sold in your area come with the Cold Weather Package. You may have to do the cardboard or better yet put it or a vinyl cover across your grill opening to reduce air flow not only across your radiator but also across the engine itself. It could even take a combo of both. I've never had to do that here in Minnesota in temps down to minus 35F but I do know it's takes a long time idling (30 minutes or more) at that temp for the temp to come up much. Once I hit the road it comes up to mid range in a few miles and after driving 10 miles at highway speed (to warm the interior hardware items) I have to turn my heater control to mid point and turn the fan to low or even off or I'm cooking. I didn't see what temp extreme you're dealing with but if it's lower than what I've seen it's possible that the engine can't generate enough heat to overcome it's environment under normal circumstances. Trying to retain heat in the engine compartment may be your only option. Do other Tundra owners that have purchased or serviced their trucks at your dealer have the same issue? If they do not your dealer should have some clue as to why yours is different. If nothing else have your dealer bring in a Toyota rep for assistance.
Larry
2004 Tundra V8 Limited Access Cab 4X4 , Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
