Old 01-15-2005, 05:22 PM
Dealer : Gene Reed Toyota
2005 Toyota Tundra
Last Online: 08-28-2006 08:59 PM
mongrel is on a distinguished road.
mongrel's Photo Albums
Default 05 6sp lube owner's manual wrong! (?)
05 6-speed Tundra.
Owners manual says "manual transmission" oil capacity 1.9 quarts.
I just drained out 2.9 quarts!
The fill plug had a metal washer. The drain plug did not.
P.S. How much is the official Toyota tech manual for this vehicle?
05 Tundra RC 4L V6 6-speed
Meguiar's, 303, Mobil 1.
Blackstone Labs, Bobistheoilguy.
Old 01-15-2005, 05:25 PM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4,
2000 Toyota Tundra SR5,TRD,AC 4X4
Last Online: Yesterday 03:54 PM
Images: 17
LGL002 will become famous soon enough.
LGL002's Photo Albums
Are you sure you didn't read the Imperial measurement? Usually in the manuals the US quarts/gallons are in parenthesis right next to the Imperial measures.
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
Old 01-15-2005, 05:31 PM
2005 Toyota Tundra
Larry
I'm sure.
"L (qt., Imp. qt.): 1.8 (1.9, 1.6)"
Thanks for the reply.
I'm not moving it until I settle this.
Old 01-15-2005, 05:33 PM
LGL002's Avatar
Images: 17
Sorry, just double checking.
Larry
Optima 34R battery
Old 01-15-2005, 07:43 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
The drain plug metal or nylon gasket likely stuck to the sump.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 01-15-2005, 07:56 PM
Dealer : Moose Jaw Toyota
2003 Toyota Tundra White Regular Cab,
1995 Toyota Tercel 1994 base tercel,
2009 Toyota Matrix Pontiac Vibe
Last Online: 10-20-2009 03:43 PM
file014 may have some regrets.
file014's Photo Albums
You're probably supposed to fill the tranny until gear oil dribbles out of the fill hole. My 1994 tercel takes 2.9 qts also. I got redline MT-90.
Old 01-15-2005, 08:05 PM
2005 Toyota Tundra
Right.
First, I'll need another quart of lube.
Thanks.
Old 01-16-2005, 02:27 PM
2005 Toyota Tundra
Here's a mystery: on refill, it only took about 1.9 quarts, as the owner's manual states.
About 2.9 quarts definitely came out.
Maybe it wasn't *level* when filled?
I'm not going to worry about this. The old lube looked good, and the trans works perfectly.
Old 01-16-2005, 03:49 PM
2005 Toyota Tundra
Ken
I searched and searched, including in the drain bucket. Why didn't you tell me this before?
I'm a paying, registered member now.
