This is a discussion thread titled "Finally... a custom Unichip tune!", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-16-2005, 10:44 PM
scdtrd's Avatar
Dealer : Lagrange Toyota
Last Online: 07-31-2008 05:34 PM
scdtrd is on a distinguished road.
scdtrd's Photo Albums
Default Finally... a custom Unichip tune!
Yes.. it has been a LONG and patient road.. but I FINALLY found a good Unichip tuner in the deep south! I am going to Hesco in B'Ham Alabama!
http://www.hescosc.com/
I spoke to Lee (Owner) and I spoke to Jack and Tony several times.. and I have an appointment @ 10:00am CST on Monday Jan, 17th 2005 to have the Tundra FINALLY tuned! What I have worked out is to put the pre-programmed map on the "a" setting, and the new, custom tune on the "b" setting. This way, incase ther is SOMETHING that happens after I leave, then I know I can run the "stock" map. I will have the Supra TT Fuel pump, OD Crank pulley and the True-flow intake all mapped to MY Tundra! 8.5psi and fuel pressure to spare! According to Jeff, I have the place for 4 hrs.. and we will "get it right". I will have Dyno maps of before and after and A/F readings as well! I will post all my findings as usual.
Oh boy, I am a happy camper!
So, here goes... "Cover me boys, I'm going in!"
SCDTRD
The Beast:
1994 Toyota Camry V6 XLE
The Mods:
Front tower Ractive Strut Bar, Whiteline rear AntiSway Bar, Rage Breaker 17.5x7 Rims and Falken Ziex 512 rubber, Limo Tint, Pioneer DEH 7700MP Head Unit, Polk 6x9 rear and Polk 6.5 Front speakers, Tokico struts front and rear, Carbon kevlar brake pads, Cryo treated rotors, ZEX 82021 N2O system, Polished and ported upper and lower intake runners, shift kit, and more to come.....and.... YES... it is a CAMRY....
"Back in the black!"
Old 01-17-2005, 11:38 PM
scdtrd's Avatar
Default Interesting findings...
Ok.. spend a SOLID day at the Unichip place in B'Ham Alabama. Met the crew and made a few friends. It... was interesting. Ok.. I know you want numbas...
so here they are.
Base line run:
This is all with a 29% Drive Train loss factor..
Unichip as I got it from Jack, no changes..
Crank HP 352.5 hp @ 5100 rpm
Rear Wheel HP = 273.3 @ 5100 rpm
Crank TQ = 380.7 @ 4300 rpm
Rear Wheel TQ = 295.1 @ 4300 rpm
A/F = 10.54
Now.. here is where it got interesting, I had several runs.. about 6 to be exact.. and we went from top to bottom thru the map. I know EXACTLY what was done and what the map looks like and how it all works now.. and let me tell you.. cool stuff. Anyway.. I was AMAZED that my truck ran BETTER on the LESS agressive map than it did on the agressive map... yep.. it did. We had a "listner" and several scopes hooked up and believe it or not, there was ping, that was not heard... but only on a scope! SO.. when I REDUCED the timing, it had BETTER numbers! So, based on that... we went in a completely different direction. With out going into tooo much detail, I REMOVED 3 deg of timing at the upper end and added timing in the lower to mid section and reduced the fuel curve, leaning it out in the center and added a bit more in the top end and WOW!
Here are the numbers from the last, final run...
Custom tune run:
Crank HP = 403.3 hp @ 5300 rpm
Rear Wheel = 286.6 hp @ 5300 rpm
Crank TQ = 423.2 tq @ 4100 rpm
Rear Wheel = 300.5 tq @ 4100 rpm
A/F = 11.37
I will scan and post the runs... Not tooo shabby. The TQ curve is MUCH flatter... I mean FLAT... and the HP curve is a nice, smooth slope to the top. NO PING and better MPG to boot. It was 152.5 miles from my driveway to theirs.. and USUALLY I got that to ½ a tank.. and.. over all I am getting on avg. 14.2 mpg BEFORE the tune. I am getting (based on a full tank leaving and filling up when I got back) 15.3 mpg now. That was @ cruise @ 75mpg 80% of the time. NO CEL's and smooth sailing. So, as you can see, I LOWERED the peak TQ readings and flattened the A/F and TQ lines...
There is a BIT more I can wring out of it BUT, I was cautious on the side of durability. Lee was there the entire time and explained EVERYTHING in detail to me. He took his time and was VERY nice. If your in this neck of the woods and need a tune, I HIGHLY recommend Hesco! A TOP NOTCH place. Jeff called and spoke to Tony and Jack while I was there and spoke about the tune and the details. I do not know the exact conversation, but it worked.. whatever they spoke about.
PM me if you need more detailed info!
SCDTRD
The Beast:
The Mods:
Old 01-18-2005, 04:37 PM
CATiger's Avatar
Dealer : Dublin Toyota Scion
Last Online: Yesterday 10:18 PM
CATiger is on a distinguished road.
Send a message via AIM to CATiger CATiger's Photo Albums
Originally Posted by scdtrd
Custom tune run:
A/F = 11.37
WOW!
Need I say more?
- JD
2000 Toyota Tundra Limited 4x4 w/ TRD Package
Thunder Grey Metallic
Factory Options: Leather Captain's Chairs, Color Keyed Running Boards, tow package
Aftermarket Additions: JVC KDSHX900 w/ HD, Sirius S50 Satellite Radio, JL Audio Stealthbox, Eclipse 500W 5-channel Amp, MB Quart Ref Components w/ 1.5" tweeters up front, Coax rears, Peel & Seal sound deadening, Trenz Billet Grill, Tailgate Extender, Sylvania Silverstar headlights, Hella SuperTone Twin Horns, Ivan Stewart Body kit sprayed with Duplicolor bedliner
Modifications: JBA Titanium coated headers, Hellwig Anti-Sway Bar, TRD Dual Side Exit Exhaust, TRD IS Wheels Polished and Powdercoated Gunmetal Grey, shod w/ 285/75R16 Bridgestone Dueler A/T REVO, RaceRunner Sway-A-Way Coilovers & Daystar Add-A-Leafs, Front Porterfield Brake Pads, Power Outlet Mod, Rear Seat Mod, NGK iridium plugs
Latest modifications: Sirius S50 Satellite Radio, Unichip, Powertrax No-Slip Rear, grey bumpers, G tech
MySpace
Old 01-18-2005, 05:39 PM
BlueRanger's Avatar
Dealer : Toyota Carlsbad
2004 Toyota Tundra
Last Online: 01-05-2009 11:59 AM
BlueRanger is on a distinguished road.
Send a message via AIM to BlueRanger BlueRanger's Photo Albums
holy cowpokes, gives a whole new meaning to pulling like a raped ape. How does it pull now btw, just crazy fast? Its all in the tuning, I cant believe those numbers, thats friggin awesome. Time for some good quality track time...
04 Tundra, Hoes, Uni's, Spintech, 285s + other misc. bling items.
Old 01-18-2005, 08:36 PM
scdtrd's Avatar
Default 2nd day results
Well... here is my observations on the 2nd day. It SCREAMS in the mid section.. I mean.. WOW! in the 65 to 85 mph range.. I am really lethal. On ramps, passing and even cruise... it is snappier and crisp. It get on with the program. I had to reset the ECU, so I am guessing that initial MPG readins will be on the low side due to the reset and my fat right foot as well. No CEL's and smooth.. I mean SMOOTH power. Especially in the 2500 to 3500 rpm range... which is where I wanted it tuned. WOT is for the BIRDS.. I drive in the meat of the RPM band, not WOT. Cruise @ 80mph on my Tundra is exactly 2525 rpm as proven on the dyno. So, when I get ready to pass, it comes out of lockup and jumps to 3000 rpm.. and it really responds. Hesco has a loading dyno, so we tuned at low mid and high loads as well. It was WELL worth the trip, time and $$$.
SCDTRD
The Beast:
The Mods:
Old 01-18-2005, 09:29 PM
ed brewer's Avatar
Dealer : American Toyota
2004 Toyota Tundra
Last Online: 02-27-2008 02:39 PM
ed brewer is on a distinguished road.
ed brewer's Photo Albums
Default Wow!
I want a ride!!!
Base: 2004 DC SR5 V8 4x4 TRD Offroad Pkg. (Silver Sky)
Mods: TRD Exhaust|SS Autochrome Headers(HPC Coated)|Unichip|PPD Billet TBC|RaceRunner SAWS 2.0
Old 01-18-2005, 09:33 PM
Dealer : Funk's Toyota
2005 Toyota Tundra
Last Online: Yesterday 11:05 PM
Diego is on a distinguished road.
Diego's Photo Albums
Can YOU say HEMI KILLER! I think my 05 with the VVti goes good, that thing must REALLY haul a$$.
Old 01-18-2005, 11:56 PM
scdtrd's Avatar
I have the before and final dyno runs.. I will scan and post VERY soon.. I will notify when I get them out there!
SCDTRD
The Beast:
The Mods:
Old 01-18-2005, 11:57 PM
scdtrd's Avatar
Originally Posted by ed brewer
I want a ride!!!
Mon down, and I will let YOU take it for a spin!
SCDTRD
The Beast:
The Mods:
Old 01-19-2005, 12:28 AM
BlueRanger's Avatar
2004 Toyota Tundra
Does Delta offer discounts after the Xmas day incident....
Old 01-19-2005, 07:10 AM
PagalDesi4Life's Avatar
Dealer : Toyota of Stamford
2001 Toyota Sequoia
Last Online: 11-14-2008 12:05 PM
PagalDesi4Life is on a distinguished road.
Send a message via AIM to PagalDesi4Life PagalDesi4Life's Photo Albums
Thats unbelieveably awesome!! I wonder what you'll get in a 1/4 mile now.
Old 01-19-2005, 07:33 AM
Dealer : Toyota Scion of Roswell
2004 Toyota Tundra,
2004 Toyota Sequoia Limited 4X4
Last Online: 01-04-2009 10:51 PM
aspenh1 is on a distinguished road.
aspenh1's Photo Albums
Default Retune
SCDTRD - your PM is full so I had to post.
Being that B'ham is not that far from Atl, what did he charge to do the retune? Also, since it seems Toyota will not have a charger for the 04, how much do you think it would help me (see my mods list) to have it done?
Base:: 04 Double Cab, 4x4, Natural White, Oak Leather, Heated Seats, Headrest DVD, 6 Disc Changer, Sirius Sportster 4, VSC
The GOOD STUFF: Unichip, Borla Performance Duals, Camburg Upper Arms, Teamwest Coilovers, 3" Front lift, 1.25 blocks, 285/70/17 Bridgestone Dueler AT Revos, 1.5" wheel adapters, Cornfed Differential drop, Hellwig sway bar, Line-X, Folding tonneau cover,TRD mesh grill, Chrome stainless nerf bars, Chromed Stainless bull bar
2nd 04 Sequoia Limited 4X4,Natural White
Old 01-19-2005, 08:52 AM
ed brewer's Avatar
2004 Toyota Tundra
I was thinking the exact same thing.
Old 01-19-2005, 12:10 PM
scdtrd's Avatar
Default Change of thinking...
It was $300.00 skins for the tune and dyno runs. I was there from 11:00am CST to 5:00pm CST.
I believe the premise of "Max Power" is not a realistic one, as it is rarely achieved on the road. In my conversations with Lee and Jeff, I came to the conclusion that the main tune area is in the 2500 to 3500 RPM range. AND.. in addition to the range we set, the BOOST level is RARELY above ZERO when in CRUISE. We went and did some "real world" driving and got on the highway and set the cruise @ 75 and watched the boost gauge and WITH the Unichip laptop took readings and measured against the boost and found, a LOT of timing could be safely added. Then, when the boost did come on, like up a hill or something, then the timing was removed and the power still was there. ALSO, the FUEL curve.. this is the amazing part. We were able to remove 33% fuel FROM the map and STILL made MORE power in the crusie range of 70-85 mph BELOW boost of zero. See how it all plays together. I was flabberghasted at the "real world" tune. T
