I have an 01 2WD Tundra and I really want a 4WD but I was wondering if I'm better of just trading it in for a 4WD Tundra. I really like everything about my Tundra except it is not 4WD. I know it is possible but is it worth the effort doing the conversion. If I were to do this conversion I would try to get most if not all the parts from a scrap Tundra at a junk yard or something. Thanks!
there's also the sas route...but it's a little costly. Look around, some other members have solid from axles on their trucks now. It would probably be easier than going for factory 4x4, if not more expensive.
you would need to get the a.d.d. system from a junked tundra, a front diff, t-case, front driveshaft, rear midshaft, and i think different hubs. kinda a lotta parts. easier to buy new, unless you plan on doing something unusual like SAS.
Has anyone actually done this? I found a guy with a couple of junked tundra 4x4s and I have seriously considered this. I recently moved to Nor Cal from So Cal and 4x4 makes more sense up here than it did in San Diego.
DevinSixtySeven you mentioned an "a.d.d." what is that? I think you are right as far as the parts needed would be the:
1. Front Diff
2. Xfer case
3. Front drive shaft
4. Rear Mid shaft (is there one?)
5. Hubs
If anyone knows of any other parts needed or has done this your input would be appreciated.
Of course I'd love to go for a Solid Axle up front and that may be an option but for now I found this guy and the price is right.
I tried PMing and Emailing you via your profile and it states you have chosen not to receive PM's or emails. I got your PM. Email me at ponsie-mike@comcast.net and we can meet up sometime. I work on Concord Ave. across the street from Sam's club and Sportmart.
Sorry to hijack the thread! Back to the conversion...
A conversion from 4x2 to 4x4 is actually very, very simple:
A) Jack up radiator cap on 4x2 truck.
B) Drive new 4x4 truck under it!!
MrBeanley
Glenville, New York
2004 Tundra Double Cab 4x4
I can't speak about converting a Tundra but a friend of mine converted a Chevy truck to 4x4 and said he would never do it again. A lot of work and headaches and for what it would cost you, your better off selling your truck and getting a 4x4 IMO.
I called Demello and I talked to them about converting my truck into 4wd and using a solid axle would cost me at about 7-10 grand! That sounds good to me but I better start saving!
yeah...that would be sweet. and think you wouldn't have to worry about trying to sell/trade your truck.
How tall did Demello say they would go for 7-10g's? Would it be a leafspring style job?
just curious...If I keep my truck forever...and get another one. I may dick around with it on the side. I've already put to much in it to get anything for it if I'd try to sell it.
converting a chevy to 4wd is not even comparable to the tundra. the front suspension on a 4wd tundra is pretty much identicle to a 2wd unit. on a chevy, NOTHING is the same. they have different arms, spring types(torsion bars vs. coils), different frame crossmembers, steering setup is different.
anyways, on the tundra it should be do-able because everything on the 2wd is similar to the 4x4 truck, should bolt in, maybe having to add some tabs and mounting brackets here and there.
you could always add an RCD lift at the time of install and use their brackets to mount the diff
