This is a discussion thread titled "Draining the Washer Fluid Tank", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 01-25-2005, 10:24 AM
Desertnate's Avatar
Dealer : Newbold Toyota
2001 Toyota Sequoia
Last Online: 05-05-2008 08:57 PM
Desertnate is on a distinguished road.
Desertnate's Photo Albums
Default Draining the Washer Fluid Tank
I posted this here since I assume the washer fluid tank on both the Tundra and the Sequoia are the same...
How do you drain the washer fluid tank? Not many cars have a drain, but at least the top is open so it can be siphoned off. Our tanks have a screen across the top which is molded into the tank and won't come off.
I bought my Sequoia in Houston with a full tank of fluid. The weather here in south west Illinois has been really mild so I have used very little fluid up to this point. Problem now is the weather has turned VERY cold and the summer fluid that works in Houston freezes solid here. I need to swap the fluid out with something that won't freeze, but can't figure out how. I really don't want to just sit with the wipers going and blow a whole tank of fluid all over the vehicle in order for it to empty.
Any tips?
Old 01-25-2005, 10:38 AM
Dealer : Acton Toyota
2006 Toyota Avalon,
2003 Toyota Highlander,
2007 Toyota Corolla
Last Online: 09-08-2008 07:16 AM
MMitsock is on a distinguished road.
MMitsock's Photo Albums
How is the tank attached to the engine compartment? It may be easiest to un-bolt it and turn it over to dump out the fluid.
Old 01-25-2005, 11:03 AM
czechm8's Avatar
Dealer : Jay Wolfe Toytota
2005 Toyota Sequoia,
- Other - Acura TL
Last Online: Today 07:40 AM
czechm8 is on a distinguished road.
czechm8's Photo Albums
Either that or try a small wet/dry vac and suck it out. You wouldn't want to use too much pressure though.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. DLS Nobelium components and coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar lamps.
Old 01-25-2005, 11:10 AM
czechm8's Avatar
- Other - Acura TL
I had another thought.........you could just drill a hole in the platic screen big enough to get a siphon tube down there. And if you were still worried about getting something you didn't want to past that hole, jut cut a round piece of screen and lay it top of the platic screen (it can't gall through). Or just use a funnel with a screen in it. The bottom line is that the only reason you need the screen is probably so you dont' dump the little foil seal from the washer fluid bottle in there.
Old 01-25-2005, 11:56 AM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4
Last Online: Yesterday 08:19 PM
LGL002 is on a distinguished road.
LGL002's Photo Albums
Any tips?
On my 2000 Tundra the screen/ funnel does pull out quite easily. If yours does come out you might try siphon the fluid out. In order to reach the reservoir I'd have to remove the plastic fender well splash guard liner which might be a pain in winter time. If you can get the existing fluid to thaw, in lieu of pumping it through your washer nozzles disconnect the hose before the nozzles and it'll pump down much faster. Here in Minnesota I use a 50% mix of - 30 washer fluid (methyl alcohol blend) with Prestone -34 De-icer fluid which contains methyl alcohol & ethylene glycol to help with refreeze on the windshield if it's sub-zero and snowing. It will actually melt some ice and prevents refreeze as snow dilutes the regular winter fluid on your windshield.
I had a scenario a few years back where using just the winter washer fluid in a sub zero snowstorm where the fluid mixed with snow would freeze across my windshield every pass of the wiper blades. That hasn't happened since I began mixing the two fluids. Good Luck with your task.
Larry
2004 Tundra V8 Limited Access Cab 4X4, Michelin 265/65/R17 ATX2 tires, Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
Old 01-25-2005, 12:37 PM
Dealer : Big Island Toyota
Last Online: 11-30-2008 05:26 PM
Haoleb is on a distinguished road.
Send a message via AIM to Haoleb Haoleb's Photo Albums
I have a 2000 also, and the screen thing can be pulled right out no problem. Maybe they changed them but i kinda doubt it.
Everything Under The Sun Is Eclipsed By The Moon, But The Sun Is Eclipsed By The Moon- Roger Waters
Old 01-25-2005, 05:16 PM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Eddie is on a distinguished road.
Eddie's Photo Albums
Unbolt the tank and let 'err spill. Make sure you don't lose the rubber grommets holding the pump into the tank (and fluid level sender if so equipped).
Old 01-25-2005, 07:48 PM
dgg2002's Avatar
Dealer : Autoway Toyota
2004 Toyota Highlander
Last Online: 08-15-2008 08:43 PM
dgg2002 is on a distinguished road.
Send a message via AIM to dgg2002 dgg2002's Photo Albums
I've emptied mine a couple times. I just unhook the hose running to the jets and hang it out the side of the engine bay. I then just let the pump blow it out onto the driveway, and away from the truck.
Bookmarks
