Originally Posted by pbsis
Hey all,
I was wondering if there is a how-to or diagram for changing the oil on my 2002 Tundra extended cab?
Any tips? What oil, its the 10,000 mile mark..
Thanks
PB
-Have on hand 7 quarts of your choice of oil...for 10k, maybe the new extended drain interval Mobil 1, 10W-30 in mild or hot weather and 5W-30 for cold,
-new filter, OEM, WIX or NAPA/Gold, Purolator or Pure One, Baldwin or Hastings,
-new aluminum gasket for the drain plug,
-12mm, 14mm, & oil filter wrench.
Drive to get the oil thoroughly warm, maybe 30 minutes.
Park on a level spot and set the parking brake.
Remove the skid pan.
Put a drain pan under the oil drain plug.
Remove the oil drain plug. Be sure you remove the old gasket
When reduced to an occaisonal drop, renew the aluminum gasket and replace the drain plug. Tighen to 35 ft-lbs (firm but don't strip the threads).
Put the drain pan under the filter & remove it. Wipe the threads and gasket face clean, wipe new oil on the filter gasket, (maybe fill the filter with new oil), reinstall hard hand tight. Be sure you did not leave the old rubber gasket sticking to the engine. The filter will tell how much to tighten.
Replace the skid pan...hand the pan by the front hooks and put in one rear bolt. Put in all the bolts loosely, get everything lined up, then tighten all the bolts firmly. Don't start them crooked (cross threaded) and strip the threads.
Fill the engine with 6-1/2 or 7 quarts of oil, total, look everything over, start the engine, look for leaks.
Clean up your mess, recycle the oil, and you're done.
Ken
