This is a discussion thread titled "Still looking for 4.30 gears???", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
This guy on the tacom board is selling some stuff and figured someone might benefit with the 4.30 gears.
04 Extra Cab 2.7 5 spd Located in Atlanta GA Doing SAS March 17th
Contact: Will Knox 770-517-8407 wknox22@yahoo.com
Front Diff w/ 4.30 gear
Rear Gear 4.30 factory gear w/ carier and Lock Rite with 4K miles on it
32-11.5/15 BFG MT's 4K on them
Lift Kit for front with Chaos Fab diff Drop Kit And Shocks
Rack And Pinion Steering
CV Joints Exelent Condition
Aluminum Skid Plate
Disc Brake assembly with hardly any wear
Upper and Lower A-arms W/ Ball Joints
Smitty-Built Step Bars (Black)
LC Engineering Muffler 2 1/4 center inlet and outlet ( sounded great on 2.7 )
Factory 31's on steel wheels w/ 26K miles & Factory Spare Never Used
Unexploded air bags
Sway Bar ( Taken off at 2K )
Rear Springs
Do you know if adding a locker depend on what gears you have or what size diff. you have. Reason being, i know there are not many aftermarket things for 4.30 gears.
__________________ 2001 Silver Tundra SR5
Mods:slimline ventvisors, TRD dual exhaust, TSC Toolbox, Protech 1" diff. drop spacer, Protech EZlift 2.5 in spacers, wheelers AAL, Extreme Alloy 1879 wheels, 285/75/16 Procomp Xterrains, Powertrax No-Slip, Hi-Lift Jack
Future Mods:Daystar 1 inch body lift, TeamWest coilovers, Camburg Uniballs, 4.56 gears, underdrive pulley, skidrow plates
32-11.5/15 BFG MT's 4K miles with or without 15x10 Aluminum BAJA's - $760 with wheels $425 without.
Front Coils with 2 1/2 inch lift and CHAOS FAB diff drop kit & rear shocks $110
CV's exelent shape $110 each or $190 both.
Front Diff with 4.30 gear $180
Aluminum Skid Plate $80
Rear 4.30 gear with or witout carrier $100 with or $50 without
Rear Lock Rite 4K miles $150
31-10.50 factory tires (26K) on steel wheels with never used spare $150
Disc Brake Assembly hardly used $125
A Arms and Spindles w/ball joints $100
Rack & Pinion Steering $ 125
Airbags with steering wheel $420
LC Engineering Muffler 2 1/4 inch outlet and inlet $30
The Locrite unit will fit any gear ratio with an open Toyota axle carrier. It won't work if you have a factory LSD unit.
Randy's doesn't even offer a 4.30. He has 4.11, 4.56, 4.88, & 5.29.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
