This is a discussion thread titled "Front/Rear Diff and T-case Oil?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-11-2005, 11:16 AM
Last Online: 08-16-2005 08:59 AM
kylant1 is on a distinguished road.
kylant1's Photo Albums
Question Front/Rear Diff and T-case Oil?
I'm getting ready to change the diff oil and t-case oil in my truck. The manual says to use 75w-90 Hypoid gear oil in the front, 90w gear oil in the rear with limited slip, and 75w-90 gear oil (doesn't mention hypoid) in the t-case.
I was wondering if it would be okay/acceptable to run Mobil 1 synthetic 75w-90 gear oil in all of these spots? I don't see why not. It meets all the spec except is multiweight and the rear diff only calls for a 80w-90 multiweight when used below 0*.
thanks for the help
2005 Tundra Double-Cab, SR5, Silver Sky Metallic, Loaded
Old 02-11-2005, 12:37 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Many of use have run syn 75W-90 in the rear with good results.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 02-11-2005, 02:35 PM
naunibecker55's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra
Last Online: 08-21-2008 05:53 PM
naunibecker55 is on a distinguished road.
naunibecker55's Photo Albums
Dealer also uses 75w90 synthetic.
Interior- Alpine 9835 & KCA-420i * Diamond s600s * JL 300/2 * CDT CL-6X * JL Stealthbox * JL 250/1 * 20 GB iPod* Matrix RS3.5
Exterior- Yokohama Geolander A/T* 4% Tint * IS Grille * IS Wheels * Camburg/TW Coilovers * Camburg UCA's * Bilstein 5100's * IS Flares
BOOST ME
Old 02-11-2005, 08:54 PM
HotRod8's Avatar
Lifetime Member
Dealer : Stampede Lexus Toyota
2003 Toyota Tundra,
1996 Toyota Corolla DX Plus
Last Online: 12-27-2008 04:07 PM
HotRod8 is on a distinguished road.
HotRod8's Photo Albums
Are you guys sure this okay, I mean using 75W-90 instead of 80W-90? I know that Ken is very well informed on such subjects so I will certainly respect his opinion.
The spec. in my manual for the rear diff. is SAE 90 (above -18*C or 0*F) or SAE 80W or 80W-90 (below -18*C or 0*F). What does this mean? Up here in the "Great White North" we routinely see -18*C during the winter, but certainly not constantly. About 2 or 3 weeks ago it was something like -30*C (or about -22*F), but for the past week or so the highs during the day have been +10*C (50*F) or better. By next week we could very likely be back to that -30*C sh$@, I mean stuff. What are we supposed to do change our gear lube every week?
I do know that 80W-90 gear lube is not easy to find, I ended up buying Amsoil as that was the only brand I could find in that weight. I really like the idea of just buying the 75W-90 and using it in both diffs and the T-case.
Rod
Old 02-12-2005, 11:03 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
I installed Amsoil 75W-90 shortly after I bought the truck. @ 60,000 miles I drained the differential to install a limited slip. The Amsoil gear oil came out bright green just like it went in. The gears had very good looking contact patches--no fretting, no wear evident at all except for normal contact. The magnet on the drain plug had little or no steel on it. Part of that mileage was towing a 5200# trailer in 90 & 100° weather at highway speeds. I put Schaeffer 80W-90 back into the differential because it is an even heavier duty gear oil. I'd feel OK about putting Amsoil back in, though.
Ken
Old 02-13-2005, 10:52 AM
what about the transfer case? i'm pretty sure I will use 75w-90 in the diffs.
Old 02-13-2005, 01:19 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
75W-90 in the front diff & t-case, preferably syn. 80W-90 or 90 wt. in the rear diff, but synthetic 75W-90 works very well.
Ken
Bookmarks
