Grease Question (Mobil 1 synthetic on grease points)
+ Reply to Thread
Results 1 to 2 of 2
Thread: Grease Question (Mobil 1 synthetic on grease points)
  1. #1
    Junior Member kylant1 is on a distinguished road.
    Join Date
    Aug 2004
    Location
    PORTLAND, OR
    Age
    36
    Posts
    76
    Liked
    0 times
    Rep Power
    9
    Question Grease Question
    Is Mobil 1 synthetic grease okay to use on all the grease points? I cannot find the specific greases the manual calls for. Also, I don't want to have 2 different guns with different greases in them if it is not necessary. Mobil 1 seems like it would work for the different areas!?
    Any advise?
    2005 Tundra Double-Cab, SR5, Silver Sky Metallic, Loaded
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    KLS
    KLS is offline
    Supercharged Member KLS is on the right track. KLS's Avatar
    Join Date
    Feb 2002
    Location
    Port Townsend, WA
    Posts
    3,520
    Liked
    1 times
    Rep Power
    15
    It'll do fine.
    Ken
    You get what you inspect
    Not what you expect.
    Gibson exhaust system
    Hellwig Rear Antisway Bar
Posting Permissions
  • You may not post replies
  • You may not edit your posts
