This is a discussion thread titled "Seafoam question", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-13-2005, 01:00 PM
GaryFisher's Avatar
Dealer : Herb Chambers Toyota of Auburn
Last Online: 08-06-2008 03:16 PM
GaryFisher is on a distinguished road.
Send a message via AIM to GaryFisher GaryFisher's Photo Albums
Default Seafoam question
I went to put Seafoam into my truck today viw the PVC hose however when I removed the hose the truck just hissed at me and stalled out. I let everything warm up but the thing will not run without that hose connected. Anyone know if I am doing anything wrong or is there a different way to get this stuff into the engine?
Im afraid to run it through the brake booster line as that is hooked into the supercharger and I dont really want this stuff touching the teflon lined rotors.
SR5 V6 4X4 5Spd Modifications Include... ACT performance clutch, Bassani Split Side Duals, Fabtech Shocks and front Coilovers, IS Kit, Grillecraft Grille, BBS Wheels, 285/75/16 Firestone Destination M/T's for wheelin, 20" Enkei RT-6's w 295/50/20's for street , Air Box Mod, Pro Comp Boost GaugeTRD Supercharger, URD Fuel kit, URD 2.2 Pulley ALL GONE - Now Audi S4 Avant
Old 02-13-2005, 03:39 PM
GaryFisher's Avatar
Anyone? Bump
Old 02-13-2005, 04:15 PM
wylcat's Avatar
Dealer : Sparks Toyota
2002 Toyota Tundra,
2000 Toyota 4Runner
Last Online: 01-01-2009 07:40 PM
wylcat is on a distinguished road.
Send a message via AIM to wylcat wylcat's Photo Albums
I am not an expert but by diconnecting the pcv line you created a vacuum leak so big that the engine wont run. what if you attach the can of seafoam to the line and then restart the engine?
HAVE YOU DRIVEN OVER A FORD LATELY?
Team West SAWS (cranked up to 3.25")
Total Chaos UCA
ORS Manual hub kit
reese front receiver hitch
10,000 lb. winch on receiver hitch
Warn Quick connects front and rear
rear brake porportioning valve mod
3" perfomance products body lift
skyjacker AAL
wheelers urithane kit for front swaybar and steering rack
BFG AT's
Eagle101 wheels
CB radio W/ dual fiberglass 48" ant.
Old 02-13-2005, 05:07 PM
THarms's Avatar
Dealer : Eddy's Toyota of Wichita
2001 Toyota Sequoia Limited 4x4,
1999 Toyota Camry-Solara SLE,
1995 Toyota T100 DLX,
2009 Toyota Camry HV (wife's car)
Last Online: 01-07-2009 09:31 PM
THarms is on a distinguished road.
THarms's Photo Albums
I usually rev the engine to about 2000rpm by wedging a screwdriver into where the accelerator cable connects to the butterfly on the intake. It still runs rough when sucking in the Seafoam (or BG44K) but is running fast enough that it doesn't die.
2009 Camry Hybrid (wife's car)
2001 Sequoia Limited (family SUV)
1999 Solara SLE (kid's car)
1995 T100 4x4 (my toy)
Old 02-13-2005, 05:53 PM
Matador98's Avatar
Dealer : Toyota Scion of Lompoc
2000 Toyota Tundra,
- Other - 1987 Land Cruiser,
1999 Toyota Land Cruiser UZJ100
Last Online: Yesterday 05:03 PM
Matador98 is on a distinguished road.
Send a message via AIM to Matador98 Matador98's Photo Albums
Either have somebody in the truck rev the engine to keep it from dying, or as previously mentioned, use your other hand to open pull on the cable. You could start the truck, quickly remove the line, put your thumb over it, and it should still run. Then stick the tube in the can and suck it up lightly, until about 2/3 of the way done, and submerge the tube. The engine should die, and then let it sit for several minutes.
I doubt it would hurt the teflon in the supercharge, but I would use the PVC as well just to be safe if possible.
Be prepared for your truck to smoke like hell.
Andy Gibson
2000 Tundra, 94K, K&N Drop-in, Spintech Truck/RV Muffler, Hellwig, 2005 Sequoia Center Console Installed and looking awesome! - TOTALLED and on the prowl for a replacement......
1999 UZJ100 Land Cruiser, 217K, new carpet, no major Mods planned; it's the wifeys
1987 FJ60 Land Cruiser, 207K, K&N Drop-in, Jacobs Ignition, Jacobs Wires, Dynomax Muffler and Hi-Flow Cat, Electric Fuel Pump Conversion, Rebuilt Carb, Rebuilt Combination Manifold, SS EGR Tube, Someday...A Lift
Old 02-14-2005, 01:40 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Expect LOTS of smoke.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 02-14-2005, 02:26 PM
Dealer : Bill Penney Toyota
2003 Toyota Tundra
Last Online: 10-07-2008 10:49 PM
hsvhobbit is on a distinguished road.
hsvhobbit's Photo Albums
I used the brake system vac line and while the engine didn't run too smooth, it did keep running long enough to get the seafoam into the engine. FWIW, everyone's right, expect LOTS of smoke.
Old 02-15-2005, 10:14 AM
GaryFisher's Avatar
Alright well I got it to run with thw hose off and excuse me for this newbie question but the stuff is not going through the PVC valve correct? It is going to be sucked through the supercharger because that is where the vacuum is? Is this right?
Bookmarks
