This is a discussion thread titled "Fluid changes", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-14-2005, 03:24 PM
utah's Avatar
Dealer : Younger Toyota
2002 Toyota Tundra
Last Online: 12-16-2008 10:13 PM
utah is on a distinguished road.
utah's Photo Albums
Default Fluid changes
I’m lazy and don’t feel like looking this stuff up so maybe somebody here has this information setting close by and can post the information I’m looking for. Getting ready to change out some of the fluids, how much do I need to get for the following?
• Transmission (is there a filter?)
• Front and rear differentials (rear has limited slip), is there an additive needed?
• Transfer case
• Coolant
Also if anyone has done this, how long did it take, couple hours or whole day? Just need to know if I need to set aside a whole day or half. Thanks for the information.
"My fellow Americans, I am pleased to tell you I just signed legislation which outlaws Russia forever. The bombing will begin in five minutes."
(Ronald Reagan 11 August 1984)
Old 02-14-2005, 03:54 PM
Dealer : Down East Toyota
Last Online: 06-22-2008 10:48 AM
PegLeg is on a distinguished road.
PegLeg's Photo Albums
• Transfer case
• Coolant
Gee, I just did all this and have all the info sitting here on my desk, but I am too lazy to type it in
Old 02-14-2005, 04:25 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
No filter on the transmission; I like to add an in-line filter like a Magnefine or SPX Filtran. 16 quarts for a complete flush & renewal. 4 quarts for a pan drain & refill. Use synthetic.
Synthetic ATF in the power steering...1 quart is enough for three drains & refills.
A quart of top quality brake fluid will be enough for a complete flush & bleed. I like ATE or Valvoline.
Just about all differential gear oil already contains the limited slip additive. Usually more is not needed. Use synthetic 75W-90 in all. 4 quarts for the rear, two each for the t-case & front.
Gallon & half of Toyota's antifreeze.
Shouldn't take more than an hour, unless you're lazy.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 02-14-2005, 05:53 PM
lunagr's Avatar
Last Online: 09-08-2005 12:44 PM
lunagr is on a distinguished road.
lunagr's Photo Albums
There is no way that I could do all of that in an hour...
Gather tools and supplies, put drain pan under truck, oops sump is at the FRONT (dang!), turn truck around to face DOWN the driveway, find suitable NEW drain pan (crushed good one while turning truck around DANG)...
...oops, need more paper towels...bust knuckles when wrench slips, $hit, out of band-aids, get electrical tape from tool box and cover bleeding knuckle...
...wife needs to get car out of garage NOW! Oh crap...
Steve
"I don't understand everything that I know about it"
Old 02-14-2005, 08:21 PM
Invid's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra
Last Online: Yesterday 02:21 AM
Invid is on a distinguished road.
Invid's Photo Albums
I did all this myself too but it took about two hours, mostly waiting for the fluids to drain especially the viscous gear lube. I have a tip for you, if you're gonna flush the coolant then get yourself a two foot 3/8 inch ID rubber tube so you can slip over the petcocks on either side of the engine near the tranny. This will alleviate a lot of grief and mess when draining the right and left sides of the engine block. I got 3.25 gallons drained and it took the same when pouring in fresh coolant. I guaged the gallons when I filled three milk jugs. I replaced the thermostat too while it was dry and that took about five minutes.
Spintech 3332XL Muffler | Hellwig Rear Anti-Sway Bar | Updated 2005 Tail Lights | Updated 2003 Alloy Wheels | AMSOIL OAF-15 Oil Filter | Ultra-Strong Oil Filter Magnet | Synthetic Fluids all around | Line-X Bedliner | Osram Silverstars | Michelin LTX M/S tires | Custom Grille w/updated Body Panels | De-Badged | Optima Spiral Cell Gel Battery
Old 02-14-2005, 09:09 PM
Tundrav8yamaha's Avatar
Major Contributor
Dealer : Mike Calvert Toyota Scion
- Other - yamaha,
2000 Toyota Tundra (totalled),
2004 Toyota Tundra Trd Off road Navi,
2008 Toyota Highlander HV limited navi 4wd i
Last Online: Yesterday 11:37 PM
Default coolant change
It's easier to buy one of those coolant change clamps that are around $8.oo and then hook the garden hose clamp into the top portion of the engine on the firewall and run the garden hose link into the coolant hoses(on firewall) that is where I tapped into with the garden house and performed my flush works just as easy
T3 Grill, Line X extra front Bumper coating (too many mod's to list)
www.tundraheadquarters.com (Surporter)
Old 02-14-2005, 09:13 PM
Major Contributor
- Other - yamaha,
Default filter
[quote=KLS]No filter on the transmission; I like to add an in-line filter like a Magnefine or SPX Filtran. 16 quarts for a complete flush & renewal. 4 quarts for a pan drain & refill. Use synthetic.
There is a filter in the trans kls however it's a metal mesh screen and I am told it can be cleaned when it's off but if you wish to buy this part it's around $70 dollars
Old 02-15-2005, 08:11 AM
mitchr's Avatar
Dealer : Phil Bachman Toyota
Last Online: 07-08-2008 10:53 AM
mitchr is on a distinguished road.
mitchr's Photo Albums
[quote=TUNDRAV8GEORGIA]
I have dropped pans on other auto trany's before to clean the screen(filter), but most of the time it did not look dirty to me. I was wondering if anyone had checked the screen on the Tundra to see how dirty they get. I have about 56,000 on my Tundra and have done the drain and refill about 4 times since it was new.
Thanks, Mitch
Old 02-15-2005, 11:17 AM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
I consider a screened inlet to be a strainer, not a filter. Just terminology.
The "one hour" business was just trying to get the lazy guy who got us to do his homework into trouble.
Ken
Old 02-15-2005, 11:56 AM
lunagr's Avatar
Ken
Whew! Thanks Ken! I was really worried for a while! I usually catch that kind of stuff...that one was slick enough to slip under the radar...
Steve
Bookmarks
