My truck was having some drivability issues and I decided to clean the MAF sensor to see if it would help.
I used a very soft model paint brush dipped in 70% Isopropyl alcohol and gently brushed all three wire elements in the MAF sensor. This worked very well. The dirt on the wires was slight but visible which became more apparent after the cleaning.
The improvement that this made was very noticable. Idle is now almost completely smooth. Responsiveness and low end torque is significantly improved. The increasing exhaust growl that was occurring at around 2200 rpm has returned to the level that existed when the truck was new.
A few months back, I replaced the air filter and discovered a couple of days later that I hadn't reseated the top of the air filter housing correctly. The truck ran horribly. Before discovering the problem, I drove a few hundred miles. After reseating the cover correctly, engine performance improved but didn't return to the same level. This was most likely the result of the unfiltered air flowing through the MAF sensor.
If you're having engine performance issues, you may want to check the air filter housing and the MAF sensor, especially if you've just done something to the intake system like I did. It's amazing how sensitive the air handling is on our engines.
