This is a discussion thread titled "Redline gear oil", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-16-2005, 06:41 PM
Dealer : Anderson-Weber Toyota
Last Online: 06-01-2007 08:30 PM
Pee Wee is on a distinguished road.
Pee Wee's Photo Albums
Default Redline gear oil
I'm going to change my diffs and transfer case over to redline 75w90 in my 04 tundra dc. Here come the questions guys.
1- For the guy's that are running this oil in there limited slip rear diffs. Is there enough friction modifer added to the gear oil already or did you have to add more to get away from chatter?
2- Since I have to order the oil I just want to double check my numbers for the amount I will need to change both diffs and transfercase. Does 6qts sound right?
THANKS FOR YOUR HELP!!!
Pee Wee
Old 02-16-2005, 07:11 PM
Dealer : Jimmy Vasser Toyota of Napa
Last Online: 09-14-2008 04:10 PM
fastone01 is on a distinguished road.
fastone01's Photo Albums
Most GL5 gear oil today have anti-chatter, anti-slip, friction modifiers on them already. Peace of mind and heavier use, I still prefer to add more! Overtime, they do break down. Alot of users here will say the same thing. I do it for peace of mind. 6 quart is more than enough. 5 qts is more like it.
Pee Wee
Old 02-17-2005, 04:39 PM
jim65wagon's Avatar
Dealer : Palmiero Toyota
2003 Toyota Tundra SR5 4x4
Last Online: 01-07-2009 06:11 PM
jim65wagon is on a distinguished road.
Send a message via AIM to jim65wagon jim65wagon's Photo Albums
I didn't add any modifier to the redline oil and it seems to be just fine. I say try it and if there is a problem add the modifyer.
2003 SR5 V8 4x4 Access Cab; SS Autochrome intake; Truxedo cover; Rhino lining; 255/85/16 Cooper Discoverer S/T's; 16x8 Black Steel Wheelers; Ram Air; breather extensions; Viair 380C on board air; Daystar 1.5" lift; Deaver 3leaf AAL; homemade bed rack; 21 gallon water tank, Hidden Hitch w/Superwinch...
The115000MileTundra
Old 02-17-2005, 07:33 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
If too much LSD friction modifier is added you lose part of the LSD effect. If not enough is in the oil you get chattering. Don't add more unless you have chattering, then add a little at a time.
I used 4 quarts for the rear, 2 for the transfer case, and 2 for the front diff.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 02-18-2005, 12:36 AM
ab's Avatar
ab ab is offline
Dealer : Metro Lexus Toyota of Victoria
2006 Toyota Tundra DC 4x4 Ltd,
2003 Toyota Sequoia 4x4 Ltd,
- Other - 87 MR2 T-Top,
2005 Toyota Tundra Long bed,
2000 Toyota Tundra AC 4x4 Ltd,
2007 Toyota Tacoma Sport
Last Online: Yesterday 10:48 AM
ab is on a distinguished road.
ab's Photo Albums
Default Gear Oil
I am also planning on changing gear oils. The owners manual calls for 75W90 for the diff but the only oil I can find in that weight is semi or full sinthetic. Will this make my rear axel seals leak or can I just use 80W90??? Thanks.
Old 02-18-2005, 10:13 AM
lelandstanford's Avatar
2005 Toyota Tacoma
Last Online: Yesterday 06:06 PM
lelandstanford is on a distinguished road.
lelandstanford's Photo Albums
Smoother LSD lockup with Redline 75W90 than factory fill. No need to add more friction modifier.
2005 Tacoma AC 2WD 2.7L 5M
Old 02-18-2005, 10:43 AM
75/90W Syn should be fine.
Bookmarks
