Old 03-01-2005, 06:50 PM
triggs75's Avatar
Dealer : Claremont Toyota Scion
2004 Toyota Tundra
Last Online: 06-30-2008 06:17 PM
triggs75 is on a distinguished road.
triggs75's Photo Albums
Default High-flow catalytic converters
Is it worth getting High-flow catalytic converters if you are going to put on JBA headers and not getting larger pipes anywhere else? As of know, I believe I'm just replacing the muffler and not getting larger pipes.
Chad
2004 V8 TRD Offroad package SR5 4x2 Access Cab
STEREO MODS: Pioneer 8600 headunit | jl 250/1 amp | Alpine 320/2 amp | kicker 65/2 door speakers | 2x 8" punch 2's in Q-Logic box under seat | XM pioneer gex-910 radio tuner | Harmon Kardon Plug and Play | Street wires set up | & dynamat
Exterior Add-ons:2.5" King Coilovers | 4.5" TC Lift | Bilstein 5100 Rear shocks | AAL Rear | 4" rear block | 315/70/17 BFG AT's | 17x9" Boze Fatal's 3 5/8" B.S. | Custom steering shaft | Extended driveshaft | JBA Headers | Mangnaflow 14" muffler | Front Grille | Advance Cover | Bed Mat | Challenger Running boards | Window Tints | Debadged | AMI Antenna | Temp & Comp. rear view mirror | TRD oil & Radiotor caps | Clear Corners | X51 Fatboy Bulbs & IPF Wiring Harness | Backup Sensors
Recently Added:ARB Airlocker with 4.56 gears.
Old 03-01-2005, 06:51 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Nope. Stock cats flow fine.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 03-01-2005, 06:55 PM
triggs75's Avatar
2004 Toyota Tundra
Ken
Thanks for the quick response.
Old 03-01-2005, 09:26 PM
Dealer : Poway Toyota
2004 Toyota Tundra
Last Online: 03-06-2009 10:15 AM
dezert_rida is on a distinguished road.
Send a message via Yahoo to dezert_rida dezert_rida's Photo Albums
Chad
On these modern trucks, the only difference in the stock cats and aftermarket OBD 2 cats, are the size of the inlet\outlet. I believe the stock ones are 1 7/8" diameter.
It doesnt make sense to put larger cats on if your keeping the stock piping. If your goin to increase the piping size, then it does.
Logic asside, theres only a certain few vehicles that may use an aftermarket OBD2 converter in CA. There are some Chevy\Ford and Dodge vehicles that have been approved. If the vehicle is not on the list, you must use an OEM OBD2 cat.
