This is a discussion thread titled "Y-Pipe", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 03-04-2005, 02:33 PM
Jordansrealm's Avatar
Dealer : Toyota of Huntington Beach
2005 Toyota Tundra,
Jordansrealm's Photo Albums
Last Online: 10-27-2008 03:15 PM
Jordansrealm is on a distinguished road.
Send a message via AIM to Jordansrealm Send a message via Yahoo to Jordansrealm
Default Y-Pipe
Magnaflow Catback Exhaust - Installed
Installed the system yesterday and it sounds awesome and looks bitchin. While changing out the old I noticed this y-pipe connection bringing both headers together under the truck. This is a horrible piece of engineering. At one point the pipe is cut down to 1" tubing. This has to be one of the biggest restrictions in the entire system.
Has anyone replaced this? Does any company make a replacement piece? If this piece was made better it would really open up the system for ALL our trucks.
2007 Toyota Tundra 5.7L v8 4wd TRD Limited
Old 03-04-2005, 02:41 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
dyogim's Photo Albums
dyogim will become famous soon enough.
JBA makes one.
Mike - http://dyogim.blogspot.com
Old 03-04-2005, 02:42 PM
Genthar's Avatar
Genthar's Photo Albums
Last Online: 11-18-2008 05:40 PM
Genthar is on a distinguished road.
JBA does make a Y-Pipe replacement (Part no 2010Y if I recall correctly), but I don't think anyone has managed to do any stand-alone testing with it. Opinions seem to be mixed with it, but I don't know if there's been any substantive testing. I have it on my truck, but I had it installed with the headers and exhaust so I couldn't tell you if it helped or not.
Genthar
2005 Toyota Tundra,
Thank you if you know a direct link lemme know. I'll start searching now!
Old 03-04-2005, 02:53 PM
2005 Toyota Tundra,
I take it when you purchase the headers it does not come with that piece?
Old 03-04-2005, 03:08 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
You can either buy it together or separate. I'll save you the hassle of searching by referring you to the "TS store". CLick on the link at the bottom of the page.
keninsb's Avatar
Dealer : Toyota of Santa Barbara
2002 Toyota Tundra,
1996 Toyota Camry LE White Tan Leather
keninsb's Photo Albums
Last Online: 07-10-2008 10:59 PM
keninsb is on a distinguished road.
No and Yes. The JBA headers do not come with the Y-Pipe. The TRD Headers do. I purchased a JBA Y-Pipe from here:
http://www.centuryperformance.com/de...t_id=JBA-2010S
They do not list the Y-Pipe but sell it cheaper than anywhere I have found ($165 + Shipping).
I installed my headers first, then the Y-Pipe about 6 months later. I DID notice a difference, but have not had a dyno.
Also, I agree with your assessment of the stock Y-Pipe: It seems VERY restrictive. I compared the two while off the truck and was amazed at the difference.
Ken
To many mods to list...
Old 03-04-2005, 03:11 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Toyota's engineers rarely produce "a horrible piece of engineering." It looks to me like the narrowed-down section acts like a venturi nozzle that pulls a slight vacuum on the other pipe. Maybe not, but few if any aftermarket Y-pipes produce any power gain.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 03-04-2005, 03:34 PM
triggs75's Avatar
Dealer : Claremont Toyota Scion
2004 Toyota Tundra
triggs75's Photo Albums
Last Online: 06-30-2008 06:17 PM
triggs75 is on a distinguished road.
I thought the Y pipe would not fit on the 04 and above years, since they changed the position on the cats and something else? I thought it was on one of the threads in here. Along with the TRD headers, you have to cut and weld alot more since they changed things up. or am I just talking crazy.
EDIT:
Here is a thread that states there are 2 different lengthed y-pipes that JBA makes. Thread
Chad
2004 V8 TRD Offroad package SR5 4x2 Access Cab
STEREO MODS: Pioneer 8600 headunit | jl 250/1 amp | Alpine 320/2 amp | kicker 65/2 door speakers | 2x 8" punch 2's in Q-Logic box under seat | XM pioneer gex-910 radio tuner | Harmon Kardon Plug and Play | Street wires set up | & dynamat
Exterior Add-ons:2.5" King Coilovers | 4.5" TC Lift | Bilstein 5100 Rear shocks | AAL Rear | 4" rear block | 315/70/17 BFG AT's | 17x9" Boze Fatal's 3 5/8" B.S. | Custom steering shaft | Extended driveshaft | JBA Headers | Mangnaflow 14" muffler | Front Grille | Advance Cover | Bed Mat | Challenger Running boards | Window Tints | Debadged | AMI Antenna | Temp & Comp. rear view mirror | TRD oil & Radiotor caps | Clear Corners | X51 Fatboy Bulbs & IPF Wiring Harness | Backup Sensors
Recently Added:ARB Airlocker with 4.56 gears.
Old 03-04-2005, 04:12 PM
mike.elmes's Avatar
Dealer : Sun Toyota - Edmonton
mike.elmes's Photo Albums
Last Online: 09-03-2008 04:27 PM
mike.elmes is on a distinguished road.
I have the Y pipe from JBA, I doubt it would help much unless you are S/C'd and pushin 9 psi. These small block engines seem to have better low end with some backpressure.
Unichip'd TRD Supercharger & 5.9 Overboost Crank Pulley,TRD Boost guage and Oak color matched pod,TRD LSD,Valvebody Upgrade by IPT in NY, JBA headers,Y pipe, K&N(Evol) SS catback exhaust, Helwig Rear antisway bar, Rear custom Leafpack,TRD Coils,Cornfed Spacers's with Y/B Bilsteins,Westin Outdoorsman Bushbar and Nerf Tubes, TRD Ivan Stewart 16X8 Rims and 285/75/R16 Revo AT tires.Pioneer 5500 MP3 Head unit/Q-Logic sub enclosure with dual crossfire subs/ 700 watts of Crossfire Amps/Bazooka 6.5's and 5.25's in Kickpanels/ CodeAlarm Remote starter/antitheft system.
Old 03-07-2005, 09:57 AM
Dealer : Poway Toyota
2004 Toyota Tundra
dezert_rida's Photo Albums
Last Online: 11-19-2008 01:35 AM
dezert_rida is on a distinguished road.
Send a message via Yahoo to dezert_rida
Ive made a custom one before out of 2". I just cut the tubing at the ds flange and bent a section, cut the PS back a bit, and brought them together with a piece of 3" tubing flared out in a merge style. The customer already had a 3" exhaust, and I had just finished installing JBAs on it as well. The boss delivered the truck back to his friend after work and said he was impressed at the power for a gas motor.
