This is a discussion thread titled "New S/C pulley", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
  #16 (permalink)
Old 03-14-2005, 09:47 PM
mike.elmes's Avatar
Dealer : Sun Toyota - Edmonton
Last Online: 01-07-2009 09:34 PM
mike.elmes is on a distinguished road.
mike.elmes's Photo Albums
Question TT Supra fuel pump pressure or flow rate comparison
Does anyone know the stock fuel rail pressure, and what the TT Supra fuel Pump provides? Mine (fuel pump) just arrived and I am thinking about farming out the job of swapping fuel pumps. I am at the same time getting the new Crank pulley installed.Got mine from a member last week. Might as well get them done together. I would like to get my Unichip re-programmed to the same as glen and scotts mapping which is as close to a custom tune as I'll get.
Unichip'd TRD Supercharger & 5.9 Overboost Crank Pulley,TRD Boost guage and Oak color matched pod,TRD LSD,Valvebody Upgrade by IPT in NY, JBA headers,Y pipe, K&N(Evol) SS catback exhaust, Helwig Rear antisway bar, Rear custom Leafpack,TRD Coils,Cornfed Spacers's with Y/B Bilsteins,Westin Outdoorsman Bushbar and Nerf Tubes, TRD Ivan Stewart 16X8 Rims and 285/75/R16 Revo AT tires.Pioneer 5500 MP3 Head unit/Q-Logic sub enclosure with dual crossfire subs/ 700 watts of Crossfire Amps/Bazooka 6.5's and 5.25's in Kickpanels/ CodeAlarm Remote starter/antitheft system.
  #17 (permalink)
Old 03-14-2005, 09:57 PM
mike.elmes's Avatar
Default belt length
Originally Posted by peterdragon
think for a 03' 2720mm-Gates ?
The one I got from Charlie says NAPA 25-061066 on it but I don't have a tape here at work to measure it. I will get one from home and see if I can measure it accurately.
  #18 (permalink)
Old 03-15-2005, 10:30 AM
bmlecuy's Avatar
What is six times seven?
Dealer : Ernst Toyota
2002 Toyota Tundra,
2007 Toyota Camry
Last Online: 02-22-2008 11:02 AM
bmlecuy is on a distinguished road.
bmlecuy's Photo Albums
The stock FPR is specified to regulate at 38-44 psi. Changing the pump alone will not change the fuel rail pressure. However, the Unichip set-up ports the FPR reference to the blower boost port, so under boost, the FPR clamps down harder and raises fuel pressure. More boost = more clamping. FYI here's a link to some good information on flow/pressure/voltage rating for various pumps including the Supra. I ended up going with the Walbro 255lph high pressure pump because it was 1/2 the cost of the Supra pump, performs as well, and is almost the exact same dimensions as the stock pump (I'll post some pictures shortly to show this). Install was a breeze, the main issue is running the tank as empty as possible to make handling it easier.
This weekend I hope to look at what my fuel pressure is doing under driving conditions.
I also have a slight pinging problem from about 4200 to redline with the Unichip installed. I've worked with Unichip to pull timing out in this range. We've pulled 10° out and I still have ping. I think the real solution is more fuel, or as mentioned above, water injection. If I run high octane race fuel, I get no ping and a strong pull all the way to the top.
I'm also looking into installing an exhaust gas temp or wideband A/F to keep an eye on things and make sure I'm not leaning out too much. I want to move to the 5.9" pulley, but need to adress this first.
Another thought I had was using a rising rate FMU like this one to push more fuel under boost. What I don't know is if I run a risk of throwing a CEL for too-high a fuel pressure.
Brian
2002 Tundra SR5 AcessCab 4x4 TRD Off Road w/ LSD
Supercharged, Unichiped, IPT, S&S Headers, Spintech, Walbro GSS342, DR Coilovers, Hellwig Rear ... more
G-Tech: 0-60: 6.97" 1/4 Mile: 15.36" @ 95.4 mph
  #19 (permalink)
Old 03-15-2005, 10:33 AM
bmlecuy's Avatar
2002 Toyota Tundra,
2007 Toyota Camry
This belt part number translates as a 6-rib (061066), 106.6 inch running length (061066).
  #20 (permalink)
Old 03-15-2005, 09:47 PM
silverTRD's Avatar
Dealer : Torrance Toyota
2003 Toyota Tundra
Last Online: Yesterday 10:56 PM
silverTRD is on a distinguished road.
Send a message via AIM to silverTRD silverTRD's Photo Albums
would this be a good fuel pump for a s/c'd tundra?
MODERATOR'S NOTE: redirect removed as ebay links are not allowed per TS posting guidelines.
MODS: who cares, nothing you have'nt heard already
  #21 (permalink)
Old 03-21-2005, 12:59 PM
Dealer : Lustine Toyota/Dodge
2003 Toyota Tundra
Last Online: 12-23-2005 01:11 PM
Leviathan is on a distinguished road.
Leviathan's Photo Albums
Does anyone know what the oem injector sizes are, and what upgrades are available?
  #22 (permalink)
Old 03-21-2005, 01:15 PM
bmlecuy's Avatar
2002 Toyota Tundra,
2007 Toyota Camry
The injectors are specified as 224-276 cc/min, 13.4-14.2 ohm.
  #23 (permalink)
Old 08-19-2007, 10:44 PM
Dealer : GO Toyota
Last Online: 01-01-2009 07:31 PM
ravencr is on a distinguished road.
ravencr's Photo Albums
Default Re: New S/C pulley
So ASP definitely makes the larger crank pulley's for the 4.7L?
Chris
  #24 (permalink)
Old 08-20-2007, 11:21 AM
Dealer : GO Toyota
If I'm running an 80mm pulley currently and only producing 3.2 psi of boost at 5,300 rpm, how would I determine what size to make the crank pulley to increase it to 6 psi?
Also, I know most people run underdrive pulleys to reduce the parasitic drag...are there any problems with going the opposite direction and increasing the speed of the accessories with the overdrive pulley's?
Chris
  #25 (permalink)
Old 08-20-2007, 06:58 PM
Dealer : Fairway Toyota
2003 Toyota Tundra,
2007 Lexus LS460 L,
2005 Lexus LS430,
- Other - 1971 Datsun 240Z-
Last Online: 12-28-2008 07:00 PM
rytherwr is on a distinguished road.
rytherwr's Photo Albums
ASP Racing 1 877 928 8678
Yes, ASP makes them (or used to) but I had to call and ask.
Wayne
  #26 (permalink)
Old 08-21-2007, 09:55 PM
dogger's Avatar
2000 Toyota Tundra,
2001 Toyota Sequoia
Last Online: 12-16-2008 02:07 PM
dogger is on a distinguished road.
dogger's Photo Albums
The route I took was to install a smaller pulley on my supercharger.
This increased my boost from around 4 psi to 6 psi along with a big
gain in power. The pulleys are available from Pulley Boys
just call them and tell them what your application is and they will
send you the correct size, cost under $100. This way you can run
your stock belt and not spin you accesories at hyper speed.
One word of caution to all of you talking about bigger injectors,
bigger fuel pump, more boost, etc. The 4.7 is not the stoutest
short block around, this is why the stock boost is under 4 psi
and the supercharger is not equipped with an intercooler.
Toyota doesn't want you upping the pressure because you will
more than likely end up ventilating your block with connecting
rods. If you are still bent on making monster horsepower, replace
the stock rods with some quality H beam units. Here is a link
to a company that sells them: lextreme.com.
With that in mind, I only run the smaller pulley in the winter
(cold dry air) and I never rev it all the way out. The rest of
the time I run the stock pulley and still keep a close eye on
the boost gauge.
dogger
  #27 (permalink)
Old 08-21-2007, 09:59 PM
Dealer : GO Toyota
What size in mm is your new pulley?
Chris
  #28 (permalink)
Old 08-21-2007, 10:12 PM
dogger's Avatar
2000 Toyota Tundra,
2001 Toyota Sequoia
I'm not positive, but I think it is a 2.2" which is about 56mm.
I'll have to measure it to be sure though.
dogger
Bookmarks
