Re: Diagnotic Trouble Shoot Code Problem
A faulty/loose gas cap should set a PO440 code.
PO441 referes to incorrect purge flow. Specifically the pressure in the charcoal canister does not drop during a purge cycle. Or during purge cut-off the pressure in the canister is very low compared to atmospheric.
PO446 refers to vent control malfunction. Specifically refers to either or both of two VSV's (vacuum switching valves) are not allowing flow from the fuel tank or charcoal canister and cannot be read by the pressure sensor. The pressure sensor and one VSV are mounted to the top of the charcoal canister, and the other VSV is mounted across on the intake maifold. I have commonly knocked off one of the vacuum lines on the intake mounted VSV before while doing spark plug changes, see if it is that simple. Below is further information.
Both your listed codes have the same possible causes, which are:
- Vacuum hose cracked,blocked or disconnected
- open or short cct in vapour pressure sensor cct. or faulty vapour pressure sensor
- open or short cct. in VSV (vacuum switching valve) circuit for the EVAP, or bad vacuum switching valve.
- open or short cct. in VSV (vacuum switching valve) circuit for the vapour pressure sensor, or bad vacuum switching valve ( 2nd one ).
- cracked charcoal canister ( black box on driver's side near firewall )
- ECM fault
What you are looking for is a problem correctly reading the vacuum purge cycle as opposed to a "gross leak" as caused by a bad gas cap.
The system is functioning but isn't coming up with the right specification of measured flow. I would start by inspecting for loose or damaged vacuum hoses. Then look to make sure all the connectors on the EVAP canister and surrounding solenoid valves are tight. Beyond that there may be some bad solenoid valves, you could do a resistance test on them to see if they are either open circuit of shorted. I don't have a resistance spec. handy, however a very low reading ( less than 5 ohms ) or a high reading ( over 500 ohms) is bad. I would guess a nominal reading to be in the 25 to 50 ohm range. Do not try to do an ohms test back to the ECM or on the pressure sensor, just the VSV solenoids themselves ( these have 2 or 3 hoses each, while the pressure sensor has none, only a connector).
