This is a discussion thread titled "2001 Tundra - Engine Whistling/Chirping noise", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
I have a 2001 Tundra with a V8. I have the cold weather knock that everyone talks about. I know it wasn't ther when I bought it last summer. There has also been another development: the engine makes a sort of whisting or chirping noise. It doesn't sound like exhaust or anything. It almost sounds like it's just a squeaky pulley--that's the best way to describe the noise. It also varies with rpms. Any advice on getting rid of the noise?
Change your serpentine accessory drive belt and your squeak should go away. Goodyear Gatorbacks are good and Toyota just updated their factory replacement belt so they may both be good.
Larry
2004 Tundra V8 Limited Access Cab 4X4, Michelin 265/65/R17 ATX2 tires, Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
Yep, sounds like the accessory drive belt. I got a good Gates belt from NAPA.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
