This is a discussion thread titled "Fluid Level In Your Battery", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-25-2002, 09:54 PM
Jef Jef is offline
Dealer : Checkered Flag Toyota
2005 Toyota Tundra 05 DC White
Last Online: 05-04-2007 10:42 AM
Jef is on a distinguished road.
Jef's Photo Albums
Default Fluid Level In Your Battery
Just a reminder, check the water level in your battery. Even though they say it is maintenance free, you can and should check the water level. I had to add water again to mine. Second time in a year and a half, but it should save the battery from getting a bad cell.
It's an easy insurance policy to prevent getting stuck somewhere because the battery died from a dry cell.
Jef
Old 05-25-2002, 10:10 PM
Last Online: 11-22-2002 11:10 PM
Tundra Jerk is on a distinguished road.
Tundra Jerk's Photo Albums
Cool
Jef,how often do you replace a battery?4 years?
Old 05-25-2002, 10:45 PM
Jef Jef is offline
Jef's Photo Albums
TJ,
I have only replaced one battery in the last ten years. Obviously not very often. However, I checked the fluid level in my battery last fall and made a post stating so. Lots of responses from folks who had never checked their water level and found their batteries needed it.
Like I said, an ounce of prevention may save you from getting stuck.
Jef
Old 05-25-2002, 11:19 PM
SATundra's Avatar
Dealer : Alamo Toyota
Last Online: 01-01-2009 05:17 PM
SATundra is on a distinguished road.
SATundra's Photo Albums
Default corroding battery tie-down, any fix?
Well I noticed mine was starting to corrode where it touches the battery so I took it off, sanded down the corroded area then sprayed it with di-electric spray. We will see if it helps.
Has anyone figured out a FIX for this yet? If so what did you do? What has everyone else tried?
SATundra
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES:
Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION:
front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
Old 05-25-2002, 11:41 PM
TMS2U's Avatar
Moderator
Dealer : Longo Toyota
Last Online: 12-30-2008 12:30 AM
TMS2U is on a distinguished road.
TMS2U's Photo Albums
Fixed mine by getting an Optima!!
Old 05-25-2002, 11:45 PM
TMS2U's Avatar
Moderator
The OEM battery in my truck was a joke. Corrosion all over the place, random drains, just a nightmare.
For a "true" maintanence free set up spend the $$ for an Optima, better yet go for two!!
Old 05-26-2002, 12:10 AM
Last Online: 05-18-2006 09:50 AM
Tundra_Jules is on a distinguished road.
Tundra_Jules's Photo Albums
I generally replace the battery when it fails to start the vehicle. Sure, it's annoying to be stuck when the battery does give up but hey, I'm a resourceful guy. I can ask someone for a jump every 4-5 years or come to the rescue of my wife when her car won't start (only happened once).
I am more than a little concerned with all the corosion around my battery tie downs though. I'm going to bring it up next time I'm at the stealership.
Old 05-26-2002, 09:53 AM
mrpink's Avatar
Last Online: 09-27-2006 02:53 PM
mrpink is on a distinguished road.
mrpink's Photo Albums
I have heard of people changing batteries every 4 or 5 years. Here in Phoenix, I have never I have never had one last over 1.5 years. Any make. But it's a dry heat. Go Diamondbacks!
Jim
Old 05-26-2002, 02:31 PM
Dealer : Lake Charles Toyota
2001 Toyota Sequoia
Last Online: 12-16-2008 10:44 PM
doctormdds is on a distinguished road.
doctormdds's Photo Albums
My Sequoia also had a lot of corrosion around the battery in just a short while. I cleaned it with a mix of baking soda and water and coated everything with grease. The corrsion returned after just a few weeks. So, I cleaned it again with the baking soda/water mix using a toothbrush. Once it dried well overnight, I sprayed the posts and hold downs with NCP-2 Battery Corrosion Preventative Spray which I purchased at Wal-Mart. So far, the corrosion has not returned. I'm sure you could purchase an equivalent spray at any auto parts store. Regarding replacement of the battery, I will not do so until either the original battery fails or about 4 years - whichever comes first. Then, I will go with OPTIMA battery. I just can't see replacing a perfectly good, relatively new battery. Incidentally, the original battery on my 1982 Toyota pickup lasted over 7 years! Maybe they don't make them like they used to.
Stan
Old 05-26-2002, 06:18 PM
Dealer : Centennial Toyota Scion
Last Online: 03-10-2006 11:03 AM
T'sTOY is on a distinguished road.
T'sTOY's Photo Albums
I took mine back to the dealer and they replaced the tie down and covered everything with a heavy grease. Unfortunately, after 6 months, the corrosion is back.
I think I'll push for a new battery next time . . .
An old fix for the early 4x4 Toys was to install a rubber shield around the front of the battery to keep the acid from running over the side and onto the windshield washer motor. Without the fix acid would leak out and down onto the motor, which eventually lead to the motor/housing failing and leaking.
The rubber shield worked great, and I made mine out of an old inner tube.
They also make battery tray pads that are designed to keep the acid from eating through the tray, something like that modified to fit over the battery might work as well.
T
Old 05-26-2002, 08:24 PM
Dealer : Ram Country Toyota
2004 Toyota Tundra
Last Online: 01-22-2007 03:31 PM
duffstuff is on a distinguished road.
duffstuff's Photo Albums
Default What a coincidence!
I was just logging in to post the same question! I've been watching mine for a while and it is getting worse. I'm getting rust-colored runoff down inside the engine bay from it. Has anyone tried the battery mats that are supposed to help? I think Griot's Garage sells them, and maybe Performance Products, don't know who else. Think I will talk to the dealer about mine also. Hopefully someone here has a good fix.
Thanks for the help everyone...
SATundra, I still hope we can met up sometime. I'm interested in the undercab lights you installed... Take care.
Old 05-26-2002, 11:57 PM
Tundra00's Avatar
Dealer : Green Tree Toyota
2005 Scion tC
Last Online: 04-21-2007 09:25 PM
Tundra00 is on a distinguished road.
Tundra00's Photo Albums
I sand blasted mine and repainted it.
I don't see why you couldn't also clean it up and dip it in that liquid plastic coating for tools.
Tundra00
Old 05-27-2002, 12:34 AM
Tundraholic's Avatar
Dealer : Stewart Toyota
Last Online: 04-23-2007 12:14 AM
Tundraholic is on a distinguished road.
Tundraholic's Photo Albums
Coat battery terminals and battery hold down areas with vaseline petrolem jelly.
Tundraholic
Old 05-27-2002, 12:40 AM
Dealer : Lithia Toyota of Odessa
Last Online: 10-12-2008 11:33 PM
Henk is on a distinguished road.
Henk's Photo Albums
TMS2U- which Optima? Red or Orange? Does either fit? thanks.
Old 05-27-2002, 01:24 AM
TMS2U's Avatar
Moderator
I put in a yellow top, but the orange top is a better fit because the poles are reversed. The only thing you need is a height adapter as it is about an inch shorter than the OEM.
Enjoy!
Bookmarks
Linear Mode Linear Mode
