Originally Posted by KLS
The difference between Mobil 10W-30 and Mobil 1 10W-30 is at least double the oil life.
All brands of oil are more alike that different these days of higher oil standards. Use any name brand.
Ken
Ken is right, whether you go dino or synth, both perform more than adequately.. oil technology has leapfrogged by leaps and bounds in the last decade.
If you'd like to double your drain interval like I do (going 10K between changes) to reduce the amount of time spent under the truck, use synthetic; I use Mobil1 10W30 and have just posted my most recent oil analysis on this board.
However, if like most people, you have a psychological barrier that prevents you from gaining a comfort level with change intervals beyond 3, 4 or 5K miles, certainly use conventional oil; using synth with shorter intervals is just a waste of money (unless there are other factors involved, like towing, excessive short trips, extreme low teperatures, etc.).
As for price, when using the interval I do, it's cheaper to use synthetic. Over 10K miles:
Synth - 6.5qts @ $4 and one filter $6 = $32.00
Dino - 13qts @ $1.79 and two filters @ $6 = $35.27
... and there's less used oil for recycling... a small way of reducing environmental hazards.
