This is a discussion thread titled "iForce V8 Redline ?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-26-2002, 02:24 PM
GeneralTJI's Avatar
Last Online: 04-02-2003 09:32 AM
GeneralTJI is on a distinguished road.
Send a message via AIM to GeneralTJI GeneralTJI's Photo Albums
Default iForce V8 Redline ?
Just was wondering what your guy's V8's redline at ? or better yet, what RPM do they pull too ?
Old 05-26-2002, 05:47 PM
v8Toilet's Avatar
Dealer : Bernardi Toyota
Last Online: 03-27-2008 09:05 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
Redline is 5200. They pull to 5200 RPM but power drops off after about 4000 RPM and it doesn't do much after 4800 RPM. 3000-4000 is the best power range. It's kind of a narrow power band but the transmission does a good job of keeping it in that power band and it's so smooth that you don't even realize it half the time.
Old 05-27-2002, 01:25 PM
GeneralTJI's Avatar
Interesting, so the torque curve starts dying down after 4k.. thats lower than I thought it would.. amazing it still makes 250HP + stock... and is only 4.7 L
When do they start to pull hard ? where does the bottem end start to kick in
My Tacoma pulls hard from around 2500 -2750 up to 5000... thats its power range, its kinda weak before that, or after 5k... well.. actually it has quite a bit of torque at 2000 but not what I'd call "racing power"
anyway, where does the tundra really come on strong ?
Old 05-27-2002, 03:33 PM
v8Toilet's Avatar
It seems to pull the hardest at around 3500 RPM. That is the engines torque peak anyway.
I've driven the v6 Tundra with automatic and stick and it seems to have about the same torque range except of course it's not as dramatic as the V8 engine. They are both DOHC engines with basically the same style intake and exhaust systems. A base 2wd regular cab Tundra with the v6 five-speed transmission will go 0-60 in 9 seconds. The SR5 V8 access cab 2wd automatic Tundra will do that in 7.9 seconds. The v6 could roast the tires pretty easily on my friend’s manual T-100 indicating good low-end torque, which is why you may get the jump on some of the cars you have raced.
You are always telling us how quick your truck is that you street race all the time. If your Tacoma is really that fast than you should take it to the track at least once and see what it can do? It’s fun and you don’t risk killing someone, getting into an accident, or losing your license. I bet you could get a 15.5 quarter mile with it if you’re a good driver and you have the proper modifications. Try it and see what you get!
Old 05-27-2002, 03:38 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Does anybody have a dyno chart of a stock Tundra?
Anyway, I'm looking at the hp chart of the V8 from my 2001 sales brochure. It shows a pretty straight line up to about 3900 rpm, then it starts rounding over. From 4000 to the peak at 4800 the hp line is about half as steep as the preceding part of the line. The hp drops from 4800 to the end of the chart at 5000.
Ken
Old 05-27-2002, 08:36 PM
GeneralTJI's Avatar
Don't worry, I have been wanting to take it to the track for a while now... this Friday it finally opens up !
My times probably will suck cause its 6500ft up here.. but im gonna give it a whirl anyway
Old 05-28-2002, 03:51 PM
Last Online: 09-15-2003 09:45 AM
blktundr is on a distinguished road.
blktundr's Photo Albums
Don't worry, the guy next to you will be at 6500 feet also, unless he gets the left lane At Bandimere, the left lane is at 6502 ft.
That will kill him.
Goos luck.
Steve
Old 05-28-2002, 05:27 PM
Last Online: 07-01-2002 12:31 AM
Snake777 is on a distinguished road.
Snake777's Photo Albums
Actually doesnt your engine run better at higher altitudes? I've heard this is because of the oxygen sensors. There is less oxygen and so your engine puts more gas in the cylinders, making it run faster. No idea, thats jst what ive heard.
Old 05-28-2002, 11:36 PM
GeneralTJI's Avatar
NO they Run way worse up here...
this is why, you engine needs the proper amount of Oxygen and Fuel at all times... like 13-14 parts of air for each part of gas (somehwere around there)
So, if you come up here where there is approx 20% + less oxygen because its thinner.. you engine has to put in less gas to keep that ratior correct so the engine runs properly.
So if you have 20% less air, and now your engine turns the fuel down 20%, you have 20% less power too... its a bummer, stuff runs like poop up here ! I used to live at sea level, however I didnt have my license yet.. but I could tell the diff in my bikes (MX)
but, if you run a properly tuned turbo or supercharged system you can take advantage of everyone else who is N/A because you can gain back that 20% .. plus additonal power (what t/superchargers normally do even at sea level) .. double advantage
... thats my plan !
Old 05-29-2002, 09:26 PM
Toy4ever's Avatar
Last Online: 11-06-2005 12:22 AM
Toy4ever is on a distinguished road.
Toy4ever's Photo Albums
Why do you think new engines run better in the cold. Your oxygen levels are more concentrated therefore the fuel burns better and you get more power. The whole concept to forced induction is to introduce more oxygen to the chambers, creating more power. Less oxygen will slow you down big time. Ever notice during the summer if it is humid out how the truck doesn't seem to pull as hard vs the cool night of winter????
Sold Toyota Tundra.....
Bought a honda.....Good luck everyone...This was one of the best websites I have ever seen for a vehicle as far as information goes. I have learned so much from you guys. Thanks......
Old 05-29-2002, 11:10 PM
Dealer : Phil Wright Toyota
Last Online: 07-04-2008 02:00 PM
arkie6 is on a distinguished road.
Send a message via Yahoo to arkie6 arkie6's Photo Albums
Originally posted by v8Toilet
Redline is 5200....
The first red mark on my tachometer is at 5400 RPM. Are the 2000 models different than later models?
Bookmarks
