This is a discussion thread titled "TACOMA: Oil Change Question", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-11-2005, 10:52 AM
Larakin's Avatar
Dealer : New Country Toyota
2005 Toyota Tacoma
Larakin's Photo Albums
Last Online: 11-12-2007 07:32 PM
Larakin is on a distinguished road.
Default Oil Change Question
I have always changed my own oil in all of my past vehicles. My new Taco is the only one I have had trouble with. it is easy to change but does anyone have a trick that helps them not get oil everywhere when you pull the filter off? it sits on there upsidedown and I am nowhere near fast enough to pull it off without all of the oil in it spilling everywhere. there seems to be a little drain under the catch but it does not work? I pulled the little plastic cap off bit it still does not drain.
Any help?
2005 Tacoma DoubleCab 4X4 TRD Off-Road Short Bed 4.0 V6 - Indigo Ink
My Blog
Old 04-11-2005, 10:56 AM
JaredPointer's Avatar
Dealer : Sunny King Toyota
2005 Toyota Tacoma TRD Sport,
2007 Toyota 4Runner
JaredPointer's Photo Albums
Last Online: 08-07-2008 03:32 PM
JaredPointer is on a distinguished road.
Poke a hole in the filter with a hammer and screwdriver while you're draining the oil from underneath. Let it drain also. It won't get all of the oil out of the filter, but it helps a good deal. You may also want to find a smal coke bottle or something to fit under the filter drain to catch all the oil that may come out of the filter.
My Tacomas
Old 04-11-2005, 11:16 AM
Larakin's Avatar
2005 Toyota Tacoma
I put a coke can under the "drain" under the oil catch under the filter but it does not drain anything, not even a drop.
Poke a hole in the top or bottom of the filter? I assume the bottom but how do you catch that oil? seems to me it would just drain into that catch...
My Blog
Old 04-11-2005, 11:56 AM
2007 Toyota 4Runner
Maybe the little drain hole is clogged and you could clean it out with a pipe cleaner or something.
When you poke a hole in the TOP of the filter, it will allow air in the filter, allowing the filter to drain it's oil back into the block (or whatever). This will allow you to pull the filter off with minimal mess.
My Tacomas
BobCat7's Avatar
Dealer : Serra Toyota Scion
2005 Toyota Tacoma
BobCat7's Photo Albums
Last Online: 06-22-2007 09:55 AM
BobCat7 is on a distinguished road.
I think what he meant was to poke a hole in the filter before you drain the crankcase. This will allow most of the oil in the filter to drain out with the crankcase oil.
2005 Tacoma SR5 Prerunner TRD offroad package #2 w/tow
Old 04-11-2005, 12:01 PM
Larakin's Avatar
2005 Toyota Tacoma
Ahh, Got it now, Thanks!!
My Blog
Old 04-11-2005, 12:34 PM
Dealer : Roseville Toyota Scion
2005 Toyota Tacoma
rcsting's Photo Albums
Last Online: 10-26-2008 10:14 PM
rcsting is on a distinguished road.
I usually do all of my own oil changes but decided to bring my Tacoma to the dealer for its first oil change. When I left the dealer I could smell oil so I checked under the hood as soon as I got home. My engine and skid plate were covered in oil ! Their lube tech left the overflow area around the filter full of oil and they also missed the fill hole which covered my valve cover with oil too. I brought the truck back to the dealer who immediately steam cleaned my engine and detailed it along with giving me a cupon for a free oil change and rotation and another cupon for a free complete detail job in and out. The dealer made it right with me but I was pretty disappionted to say the least when it happened. I mentioned that putting a hole in the filter would help it drain but I guess they don't do it that way, maybe now they will.
Old 04-11-2005, 02:04 PM
anmrivera's Avatar
Dealer : Performance Toyota Of Lavista
2003 Toyota Tundra,
2005 Toyota Sienna
anmrivera's Photo Albums
Last Online: 10-29-2008 09:52 AM
anmrivera is on a distinguished road.
All right, what about on an 02. The filter is pointed up but not straight up. Is there a way to change the oil without having it leak all over the place? I am helping a friend out and he doesn't want any oil spilled when we change it. Thanks in advance for your help.
2003 Tundra 4x4 Access cab V-8, SR5, Silver Sky Metallic, TRD Off-Road package, Tow package, LSD, cold weather prep. package, Running boards, Convienence Package, Line-X bedliner, debadged, 4 window visors, Blue Cyber Eyes, $5 rs3200 upgrade , Fog light mod.
2005 Sienna LE 8 PAX, White, Full Curtain airbags, Tow prep package, VSC, Rear Disk brakes, rear audio, aftermarket entertainment center(will be bought soon)
I'm a proud Toyota Bigot!!!
Midwesterners checkout the midwest forum!Click here
Old 04-11-2005, 05:53 PM
Dealer : O'Brien Toyota
2005 Toyota Tacoma
bandit572's Photo Albums
Last Online: 11-21-2008 05:56 PM
bandit572 is on a distinguished road.
Get the filter slightly loose, then wrap a plastic shopping bag over and around it. Unscrew the filter with the bag enclosing it. Any and all oil will be in the bag. You can also use a gallon size zip lock bag. This is the way we do it for lycoming engines on a Cessna. Check this out also guys. I have one and will attest to its funtionality, as my filter in my airplane is horizontal and in a very cramped area.
http://www.sportys.com/acb/showdetl....roduct_id=5734
Old 04-12-2005, 09:04 AM
2007 Toyota 4Runner
Just for future reference......a site dedicated to such questions.
My Tacomas
Similar Threads for: TACOMA: Oil Change Question
synthetic oils - yes or no? nhparrot Engine & Drivetrain 21 01-29-2008 05:25 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Lowest Oil pressure question akauth Engine & Drivetrain 10 08-13-2007 05:51 PM
Oil Filter Change nhparrot Engine & Drivetrain 7 02-07-2006 08:33 PM
GEORGE! or anyone else..Whats The Best "DINO" Oil nhparrot Engine & Drivetrain 0 03-28-2002 04:21 PM
