This is a discussion thread titled "Superplug (magnetic drain plug)", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-12-2005, 10:38 AM
Dealer : Champion Toyota Scion of Austin
2005 Toyota Tundra
6SPD's Photo Albums
Last Online: 07-26-2008 08:09 AM
6SPD is on a distinguished road.
Default Superplug (magnetic drain plug)
Anyone using/used one of these? What do/did you think? How effective was it?
www.superplug.com
Looks like an interesting idea.
Old 04-12-2005, 10:54 AM
Buzzard's Avatar
Dealer : Gulf Coast Toyota
2006 Toyota 4Runner
Buzzard's Photo Albums
Last Online: 11-08-2008 05:50 PM
Buzzard is on a distinguished road.
I have them in all my vehicles---not sure if its the same brand. AV Lubericant use to sell them.--- Buzz
Old 04-12-2005, 10:59 AM
czechm8's Avatar
Dealer : Jay Wolfe Toytota
2005 Toyota Sequoia,
- Other - Acura TL
czechm8's Photo Albums
Last Online: Today 02:33 AM
czechm8 is on a distinguished road.
FilterMag is another way to go. It gives you much more magnetic surface area. I run one on my Sequoia.
www.filtermag.com
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. DLS Nobelium components and coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar lamps.
Old 04-12-2005, 02:07 PM
2005 Toyota Tundra
6SPD's Photo Albums
www.filtermag.com
This looks awesome! Have you done before and after oil analysis?
Old 04-12-2005, 02:56 PM
czechm8's Avatar
- Other - Acura TL
No. I'm approaching 10K on my Amsoil and ready to change it. I just wanted a little extra protection.
The magnets are extremely strong and the only way to get them off the filter is to slide them off. I was worried at first that they might fall off, but there is no way that will happen! I wouldn't mind cutting open the old filter though to see just what was left behind by the magnet.
Old 04-12-2005, 09:16 PM
Invid's Avatar
Dealer : Toyota of Riverside
2002 Toyota Tundra
Invid's Photo Albums
Last Online: 10-02-2008 09:42 PM
Invid is on a distinguished road.
I use a FilterMag also and I did cut my oil filter open after my first 5K mile run with it on (what a mess!). You could see an outline of the magnets on the inside of the filter but the amount of metal shavings was negligible. I feel over the life of the truck that I will save it from a few scratches internally. All in all there is no price for peace of mind and that's why I got it. Simple cheap insurance if you ask me.
Spintech 3332XL Muffler | Hellwig Rear Anti-Sway Bar | Updated 2005 Tail Lights | Updated 2003 Alloy Wheels | AMSOIL OAF-15 Oil Filter | Ultra-Strong Oil Filter Magnet | Synthetic Fluids all around | Line-X Bedliner | Osram Silverstars | Michelin LTX M/S tires | Custom Grille w/updated Body Panels | De-Badged | Optima Spiral Cell Gel Battery
Old 04-12-2005, 10:42 PM
THarms's Avatar
Dealer : Eddy's Toyota of Wichita
2004 Toyota Highlander Limited AWD,
2001 Toyota Sequoia Limited 4x4,
1999 Toyota Camry-Solara SLE,
1995 Toyota T100 DLX
THarms's Photo Albums
Last Online: 11-19-2008 08:02 AM
THarms is on a distinguished road.
Is there really much true iron in the moving parts of anything inside of the engine? Piston rings, sleeves, bearings, valve guides, etc are steel or steel alloy that does not have enough iron content to make the magnet effective.
Transmissions, tranfer cases and differential parts are a whole different story and I can understand why a iron "scavenging" magnet would be a good idea.
2001 Sequoia Limited (Family SUV)
1999 Solara SLE (wife's car)
1995 T100 4x4 (my toy)
Old 04-12-2005, 11:12 PM
sequoiasoon's Avatar
Dealer : Competition Toyota Scion of Middle Island
2003 Toyota Sequoia,
- Other - 93 Corolla TOTALLED!
sequoiasoon's Photo Albums
Last Online: 11-04-2008 08:52 AM
sequoiasoon is on a distinguished road.
Search for Filtermag and/or some of my posts. I posted pics of a filter cut open with the filtermag on. I did a sample from my Corolla of my oil as well as a seperate sample from my filter after removing the magnet and using my finger to wipe the whole area to mix the particles into the sample. Regular oil had 5 ppm of iron, filter sample was 12 ppm iron with all the rest of the numbers being almost exact. Universal average for that motor for iron is 30 ppm so I'm much lower anyway . As stated it's more long term piece of mind for me.
Old 04-12-2005, 11:49 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Steel is attracted to a magnet just fine. What is steel...iron plus some alloying minerals. Nickel is the other magnetic material.
Piston rings and cylinder walls are all magnetic material, as well as timing gear teeth and a few other parts. Bearings are not iron or steel. What material are valve guides...bronze?
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Similar Threads for: Superplug (magnetic drain plug)
synthetic oils - yes or no? nhparrot Engine & Drivetrain 21 01-29-2008 05:25 PM
Magnetic Drain Plug DaveS Engine & Drivetrain 90 01-17-2007 01:52 PM
Socket Size for Rear Differential Drain Plug? cjderry 1Gen-Sequoia 4 06-23-2005 01:32 PM
transmission drain plug is stripped, pan threads bad as well. mikeinaustin Engine & Drivetrain 8 03-22-2005 10:01 PM
Magnetic Oil Drain plug BT-22 Engine & Drivetrain 4 03-01-2003 11:29 AM
