If you are really interested on looking and purchasing 00 tundra V8
Here is a list to look for
- TSB done on the Brakes. Most common reports is vibration fr/rr between 45 mph to 70 mph
- exhaust Manifold leaks
- TSB oxygen sensor
- TSB on the relay for tow package
- oil Dip stick lenght
- Seatbelt tensioner
- Rattle on the doors
Maintenance
- Timing belt replacement at around 90K
- Water pump replace when timing belt was done
- Fluid change on engine, fr/rr diff, transmission and transfer case
- Power steering fluid
- Brake fluid
- radiator fluid (red is oem)
Leaks
- Check for leaks on the engine, trans, diff, wheel bearings, etc
- CVC joints
- Fr/rr shocks. Have they been replace
- radiator
Test drive
- Check for vibration
- steering wheel alignment
- stopping. ABS functionally
- engine noise
- rattle/sqeaks
-Transmission shifts
Functionality
- All lights function
- turn signals
- AC/heater
- radio
- Vents
- instrument cluster
- check light
Hope this helps
