Originally Posted by dezert_rida
The degrees of crank rotation must be evenly spaced or there would be a horrible imballance.
You have 360 degrees of crank rotation, so a cylinder fires every 45 degrees on a V8.
4 cyl motors fire every 90 degrees of crank rotation, thats one reason they dont sound smooth. V8s sound deeper because there is more rotating mass.
Yeah, it seems they would need to be evenly spaced. Good point.
In a 4 stroke engine any given cylinder will fire every other revloution of the crankshaft (once in 720) so in a V8 you would fire once every 90 degrees and a I4 would be every 180 degrees.
How often the power comes will have a lot to do with how smooth the power delivery is. Longer spacing between cylinders firing will make it seem less smooth.
The other part of balance of an engine has to do with the movement of the mass inside the engine. Some engines are naturally harmonically balanced (I6, V12, V16, any flat engine). Some aren't. Some engines, like a V8, can be fairly easily balance by adding a few counter balance shafts.
