This is a discussion thread titled "Diff. Drop Spacer torque", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
That's [actually] a really good question Ray! I'm interested in that info myself. After adding "washers" to the skid plate (to make it fit without hitting, after the install of the diff drop spacers), I have to wonder, if you "can" torque 'em down as much?
__________________ 2004 SR5 Double Cab 4x4 w/TRD Pkg. Mods to Date:
16" 5 Spoke Brawn Enkei Wheels, Keyless Entry, Line-X Bed Liner, Challenger Running Boards, Husky Floor Liners, Bug Flector II (painted to match), Colegan Bra, Borla Dual (Side-Exit) Exhaust System, 2" Wheeler's Coil Lift, TRD Add-A-Leafs Mods to Come:
265/75/16 BFG A/T's, Possible Mods:
RCD iirc torqe specs are crazy like 150lbs on a 1/2" bolt. This however is a 10.5grade bolt.
My guess on the stock or the diff drop bolts its probably like 90 - 125lbs. I used a pneumatic to get the stock ones off and I had the air pressure at about 90psi and it really had to work to get the bolt loose. I just tightened down with the same force. The skid plate is probably like 15 - 25.
Work in progress...
Imdone, thanks for your guess on the torque specs. I have the Total Chaos Fabrication diff drop. I could probably give them a call. They seem quite helpful. Does anyone have the Tundra service manual handy (mine is a 2002) with the stock diff bolt torque? Thanks.
__________________ 2002 Tundra Access Cab SR5 V8 4x4 TRD Donahoe Racing adjustable coilover shocks, Total Chaos Fabrication 1” Diff. Drop Spacer, Bilstein 5100 Series shocks, Downey add-a-leafs, Mickey Thompson 16X8 Classic II wheels, Mickey Thompson LT265/75R16 Baja Radial MTX tires, Cooper LT265/75R16 Discoverer M+S tires (for winter), K&N air filter, Westin Signature Series Step Bars, A.R.E. MX Series truck cap, LINE-X spray-on bedliner, AMP Research Bedxtender, DuraHitcH trailer hitch, Warn front receiver, front tow hooks, Auto Ventshade Ventvisors, Husky Floor Liners front & rear, General Lee 10 Meter radio, Astatic mic, Nemarc M-1S CB Console, Wilson 1000 CB antenna
