4x4 light flashing
+ Reply to Thread
Results 1 to 4 of 4
Thread: 4x4 light flashing
  1. #1
    Rookie turi is on a distinguished road. turi's Avatar
    Join Date
    May 2002
    Location
    San Diego, CA
    Age
    43
    Posts
    14
    Liked
    0 times
    Rep Power
    0
    Default 4x4 light flashing
    when I try to engage 4hi the light flashes but 4x4 is engage. any suggestions on what is the problem?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    DIRT BAG wylcat is a splendid one to behold. wylcat is a splendid one to behold. wylcat is a splendid one to behold. wylcat is a splendid one to behold. wylcat is a splendid one to behold. wylcat is a splendid one to behold. wylcat is a splendid one to behold. wylcat is a splendid one to behold. wylcat is a splendid one to behold. wylcat is a splendid one to behold. wylcat is a splendid one to behold. wylcat's Avatar
    Join Date
    Feb 2004
    Location
    Myrtle Beach, SC
    Age
    39
    Posts
    1,405
    Liked
    2 times
    Images
    18
    Rep Power
    30
    sounds like an ADD actuation problem... it might be partialy engaged or even fully engaged, but the position sensor says that it isn't. first I would get under there and make sure the wire connections are clean and tight. also check for any cuts or breaks in the wires.
    HAVE YOU DRIVEN OVER A FORD LATELY?
    Team West SAWS (cranked up to 3.25")
    Total Chaos UCA
    ORS Manual hub kit
    reese front receiver hitch
    10,000 lb. winch on receiver hitch
    Warn Quick connects front and rear
    rear brake porportioning valve mod
    3" perfomance products body lift
    skyjacker AAL
    wheelers urithane kit for front swaybar and steering rack
    BFG AT's
    Eagle101 wheels
    CB radio W/ dual fiberglass 48" ant.
  4. #3
    Join Date
    Feb 2004
    Location
    Myrtle Beach, SC
    Age
    39
    Posts
    1,405
    Liked
    2 times
    Images
    18
    Rep Power
    30
    here's a couple older threads dealing with the early model tundras front ADD
    $800.00 to fix 4wd ADD not covered by warranty
    2000 ADD Actuator - "Issue" - Could use some help?
    Total Chaos UCA
    ORS Manual hub kit
    skyjacker AAL
    BFG AT's
    Eagle101 wheels
  5. #4
    ΜΟΛΩΝ ΛΑΒΕ imjin is a glorious beacon of light. imjin is a glorious beacon of light. imjin is a glorious beacon of light. imjin is a glorious beacon of light. imjin is a glorious beacon of light. imjin is a glorious beacon of light. imjin is a glorious beacon of light. imjin is a glorious beacon of light. imjin is a glorious beacon of light. imjin is a glorious beacon of light. imjin is a glorious beacon of light. imjin's Avatar
    Join Date
    Oct 2003
    Location
    California
    Age
    45
    Posts
    1,617
    Liked
    0 times
    Images
    66
    Rep Power
    167
    When you hit 4-hi, try to rock the truck back and forth by putting it into forward & reverse. Sometimes that helps to get it into gear. When it finally connects, you may hear a faint clunk that'll tell you it's locked into position. Usually I only have to do this when I'm parked on a hill and try to engage 4-lo or hi.
  1. Fog light switch mod (non DRL) question
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 01-21-2011, 09:52 PM
  2. synthetic oils - yes or no?
    By nhparrot in forum Engine & Drivetrain
    Last Post: 06-10-2010, 03:43 PM
  3. Fog Light Mod Quirks
    Last Post: 03-28-2002, 10:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
