This is a discussion thread titled "2004 LSD fit a 2001?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Hello everyone,
I did a search and came up empty. Will a limited slip from a 2004 Tundra fit my 2001? Any difference in gear ratio? 2WD-2WD.
thank you
2000 Toyota Tundra 2WD Cab, nerfs, 2.75" lift, Ivan Stewart 4wd shocks, rear sway, spray on liner,S&S headers/Y-Pipe, ASP crank pulleys, drilled/slotted rotors, Flowmaster exhaust, 4.10 gears with LSD. bumper grill guard, SELLING
1998 GS400, 506hp, supercharged/intercooled with everything (sold)
2002 SC430 with a great many mods
2004 GX470 with many mods
Hello everyone,
thank you
Yes it will fit-
You should be able to completely swap out the complete 3rd member
- Same rear end/ R& P size for all Tundras
As far as Gear Ratio - Should be 3.9X but
Best thing to do would be confirm your gear ratio
-I'm Not sure what year Tundras with v8/v6 were avail w/ what ratios
If the swap is going from 2wd to 2wd , matching gear ratios is not much of a concern since you don;t have to match fronts
Yes it will fit-
Gear ratios could be a bit tricky even on a 2WD due to speedometer calibration issues. Unless Toyota sneaked in one I don't remember, I believe that '00 to '04 Tundra gear ratios have been as follows:
'00 to '04 Access Cab V8s: 3.91
'04 Double Cab V8: 4.10
'00 to '04 Automatic 4WD V6s: 4.30
All other '00 to '04 V6s: 4.10
Other than the automatic V6s, AFAIK the same ratio was used for 4WD and 2WD drive trucks of the same year and engine.
__________________ Ray
Thank you for the replies. It is appreciated. I picked it up off ebay. Rolled 2004 2wd Tundra AC w/ 35k miles.
Entire 3rd member for a little more than 200.00 and local. Can't beat that.
