This is a discussion thread titled "Lubing Slip Yoke", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-18-2005, 11:48 PM
2003 Toyota Tundra
Last Online: 12-10-2008 10:32 AM
Parshal is on a distinguished road.
Parshal's Photo Albums
Default Lubing Slip Yoke
I dind't find the exact answers in a search but I'm sure this has been covered before. Sorry for the duplication.
Since I bought my '03 Tundra used it's had a pretty strong thunk during braking and starting. I started to drop the drive shaft today in order to grease the slip yoke. Not having done it before, I thought the drive shaft would be fairly easy to drop. I removed the bolts from the flange and the truck rolled back a little moving the flange on the diff about halfway between the bolt holes on the drive shaft. I was surprised the shaft didn't easily drop. Fearing that there was some sort of compression holding it there I decided not to whack it with a 2 lbs. dead blow hammer. So, I rolled the truck back a little more and put the bolts back in.
A couple of questions. How hard should the drive shaft be to drop? Should I just jump on the bumper a bit to loosen it? Will it be hard to get back on if I go through that exercise?
Also, the flange on the diff is now rotated 1/4" turn. I can't imagine that the four bolt holes need to be in the exact same holes when the shaft is put back on do they?
Old 04-19-2005, 01:10 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 01-02-2009 07:59 PM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
I would put it back exactly the way it was, to avoid the possibility of vibration. In a perfect world in wouldn't matter, but Toyota's world isn't that perfect anymore. Member Arkie6 wrote the original instructions for lubing the slip yoke on a Tundra 4x4. His method works. If you can't search it out, give me a PM.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 04-19-2005, 10:34 AM
2003 Toyota Tundra
I did find Arkie6's post but it mentioned nothing about getting the drive shaft off the flange. What I read went into great detail about using the zerk fitting to grease it. Mine's so dry I'd like to remove it.
Old 04-19-2005, 01:09 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Use the grease fitting. It puts grease into the correct spot for lubrication. Get a grease containing moly, grease it full, don't blow out the seal, remove the fitting, drive slowly over a curb or bumps to work out any excess grease, replace the fitting, and you're done.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 04-19-2005, 01:53 PM
Mike Donofrio's Avatar
Dealer : Gateway Toyota
Last Online: 01-14-2008 05:40 PM
Mike Donofrio is on a distinguished road.
Mike Donofrio's Photo Albums
Ken
Great advice, especially if you have a 4WD. The front driveline uses itty, bitty plastic seals on the u joint. Anything more than one full pump and you'll wind up needing new joints. See the photos in my photo gallery if yer curious.
Mike D
Lost traction? Lock it up!!! Front locker install instructions here: http://www.teddnet.com/lockrite.htm
Upgrades: PA 3" Body Lift, Powertrax No-Slip rear, Detroit ezLocker front, Fabtech/Fox front, Wheeler's AALs, TC Front Diff Drop, 16 x 8 MB Wheels, 285/75R16 Goodyear Wrangler MT/Rs, Pioneer Head Unit, Infiniti Reference speakers [front and rear], 150 W bridged amp to bandpass enclosure, 6 CD changer with IR remote, iPod mini and xm hardwired into stereo, Toyota drop in bedliner, and Tonneau cover
Old 04-19-2005, 11:32 PM
AV8R's Avatar
Dealer : Uniontown Toyota Scion
Last Online: 09-19-2008 04:26 PM
AV8R is on a distinguished road.
AV8R's Photo Albums
Ken
Ken, I'm wondering if a guy couldn't just jump up and down on the bumper to work the excess grease out.
Has anyone made the determination that the Moly grease may be used everywhere and not just on the double cardan? It makes sense to me that you could but I've read conflicting posts here on TS.
Jim
2006 Tundra V8 Salsa Red Pearl Dbl Cab, Limited 4x4, Leather Interior w/ Htd Captain Chairs, SRS Side Curtain Airbags, Moonroof, All weather guard, DRL's, LSD, Rear Audio, Overhead Console, Touch Screen DVD Navigation, Line-X, Husky Liners, VSE Bazooka Sub, Retrax Bed Cover.
Curiosity killed the cat but satisfaction brought him back.
Old 04-20-2005, 10:57 AM
2003 Toyota Tundra
I took the slip yoke apart last night and put grease on it. I can't imagine I would get enough grease on the splines via the zerk fitting unless I went through one whole grease canister. The splines were completely dry. Now, the clunk is gone.
Regarding breaking the seals on the u-joint. I've always seen/heard that you don't want to grease a ball joint (or other joint with a rubber seal) until grease comes out but you do on a u-joint. That, actually, you want grease coming from all four caps. Someone else posted this link here before so I'll post it again. After reading it, it only makes sense why would want to do it this way. The video is even better but is big.
http://www.pirate4x4.com/tech/billav...ft/index3.html
http://www.pirate4x4.com/tech/billav...ft/index4.html
http://www.pirate4x4.com/tech/billav...t/lubepath.avi
Old 04-20-2005, 02:42 PM
TUNDRA RU's Avatar
Dealer : Fairfield Toyota
2002 Toyota Tundra
Last Online: 12-23-2008 07:30 PM
TUNDRA RU is on a distinguished road.
TUNDRA RU's Photo Albums
I agree, your not done until you see the old grease coming out of the seals. They will reseal after the pressure equalizes.
Bookmarks
Similar Threads for: Lubing Slip Yoke
truck lurches forward when brakes are depressed bbfirebird Engine & Drivetrain 24 09-29-2006 04:50 PM
transmission down shifting biggary Engine & Drivetrain 17 03-18-2005 08:15 PM
Vibration in 1st gear? teamlong Engine & Drivetrain 11 05-08-2003 07:39 AM
Greasing the Slip Yoke swstandring Engine & Drivetrain 2 04-12-2003 03:22 PM
