This is a discussion thread titled "Limited Slip Diff - Gear Oil????", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-21-2005, 12:39 PM
Last Online: 01-07-2009 02:40 PM
rcdave is on a distinguished road.
rcdave's Photo Albums
Default Limited Slip Diff - Gear Oil????
I have a new 2005 Tundra with the limited slip differential. I am nearing the mileage for its first gear oil change. In the past, I've always used synthetic Mobil One gear lube but in non-LSD rear ends.
Is synthetic gear oil suitable? Do I need to add an additive due to the fact that its LSD?
Thanks for the help!
Old 04-21-2005, 01:18 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Read the label on the gear oil bottle. If it says that it is suitable for limited slip differentials, then it already has the additive in it. I believe Mobil 1 gear oil does have the additive already mixed in. Yes, synthetic gear oil is completely suitable.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 04-22-2005, 11:44 PM
1999 Toyota Tacoma
Last Online: 12-04-2008 12:38 PM
grillmasterp is on a distinguished road.
grillmasterp's Photo Albums
According to Mobil 1
Mobil 1 Synthetic Gear Lube LS 75W-90 contains special friction modifiers designed for limited slip-type differentials. In most applications, the addition of special LS (limited slip) additives is not required. For axles requiring the highest level of limited-slip performance, OEM specific LS additives can be added to this fluid.
Basically, I take this as it should not be needed but might be needed dependent on application. I have read that sythetic gear oil's inclusion of LSD additive is suitable for certain types(older) LSDs but may not really be enough for some of the newer LSD's- I will try to get more info- I was also told thatToyota has a TSB advising dino oil with additive over synthetic.
Check out this discussion
http://www.tacomaterritory.com/forum...ight=lsd+mobil
Old 04-23-2005, 10:21 AM
tundrabrad's Avatar
Dealer : Bill Wright Toyota Scion
2003 Toyota Tundra
Last Online: 10-29-2005 01:45 AM
tundrabrad is on a distinguished road.
Send a message via AIM to tundrabrad tundrabrad's Photo Albums
Arrow
My experience in using Amsoil 75W-30 Synthetic is that an additive is needed. Amsoil stated that it wasn't necessary but I experienced immediate chatter in the diff even with their Slip-Lok additive.
I added a tube of BG LSII friction modifier and the chatter went away. I now have Mobil 1 in the diff with BG LSII as well. I have no experience with Mobil 1 and no friction modifier.
Search 'LSD oil' and you will find many posts on the subject!
Brad
________________________
Tundrabrad
Menifee CA
2003 Tundra SR5 Access Cab 4X2 - Stratosphere Mica
Factory Options/Accessories:
Limited Slip Differential * RS3200 Security System * Towing Package * 17" Limited 5 Spoke Alloy Wheels * All Weather Floor Mats * First Aid Kit * Cargo Net * Wheel Locks * Aluminum Skid Plate * Auto Dimming Mirror * Fog Lights * Bed Extender
Mods/Additions:
Sylvania SilverStars * RhinoLiner * OBX Fire Extinguisher * Westin Signature Nerf Bars * Bullring Retractable Tiedowns * Snuglid Tonneau Cover * Coleman 400 watt Power Inverter * Magnafine transmission filter * Hellwig Anti-Sway Bar * SuperPlug
Old 04-23-2005, 10:28 AM
2005 Toyota Echo Hatchback
Last Online: 11-27-2008 05:11 PM
pcosens is on a distinguished road.
pcosens's Photo Albums
Go to your dealer and ask for the fluid spec sheet for your truck - they can access this and print it for you.
Likely it will still come up with dino gear oil specs for the LSD - with friction modifier. Toyota Canada sells LSD gear oil (see attached image) - repackaged oil from some standard supplier - and specs FORD LSD additive. Yes, FORD!
This is clipped straight from the Eaton site FAQ:
Q - What type of lubricant and limited slip additive should I use with my newly purchased Eaton Limited Slip Differential? [ed: factory Toyota LSD??]
A - Eaton strongly recommends utilizing an API-GL5 approved Mineral-Based 80W-90 Axle Lubricant and one 4-oz bottle of Limited Slip Additive (GM or Ford).
FWIW I use synthetic everywhere else on my truck.
Paul
Old 04-23-2005, 11:45 AM
nhparrot's Avatar
Assistant Administrator
Dealer : Rockingham Toyota
2007 Toyota Tundra Slate Blue CrewMax
Last Online: Today 05:22 AM
nhparrot's Photo Albums
Toyota Specs
Front
Hypoid API GL–5
75W–90
1.2qts
Rear
Hypoid API GL–5
75W–140
w/LSD 80W–90
2WD 4.0qts
4WD 3.7qts
LSD 2WD 3.3qts
LSD 4WD 3.1qts
~Glenn~
Forum Rules
Got a question 'bout TS.com site policy? click
HERE!
Bookmarks
Similar Threads for: Limited Slip Diff - Gear Oil????
synthetic oils - yes or no? nhparrot Engine & Drivetrain 21 01-29-2008 05:25 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Best oil to run in the 4.7 Tundra? SMOKEATR Engine & Drivetrain 69 03-22-2007 06:33 PM
Oil Filter Change nhparrot Engine & Drivetrain 7 02-07-2006 08:33 PM
GEORGE! or anyone else..Whats The Best "DINO" Oil nhparrot Engine & Drivetrain 0 03-28-2002 04:21 PM
