Old 05-29-2002, 12:58 AM
basmith's Avatar
Dealer : Desert Toyota Scion Of Tucson
2002 Toyota Tundra
Last Online: 05-21-2009 01:14 PM
basmith is on a distinguished road.
basmith's Photo Albums
Default Oil Gauge broken?
My oil gauge is starting to act like a spedometer. When I speed up it rises to H and when I slow down or stop it goes pretty close to L. Does anyone know what the problem is? It sounds like the sensor but just wanted to make sure before I bring it in to the dealership and look stupid. Anyone else have this problem? Thanks for the help.
Old 05-29-2002, 01:21 AM
Dude Boy's Avatar
Dealer : Toyota of Gladstone
2000 Toyota Tundra,
- Other - 1952 Ford F-1 4x4
Last Online: 11-17-2009 03:59 PM
Dude Boy is on a distinguished road.
Dude Boy's Photo Albums
This is pretty much normal for the Tundra. At least about everybody's does it, and the owner manual shows that oil pressure near "L" is in the normal range.
ADDING POWER HAS NEVER BEEN SO FAST!
Old 05-29-2002, 01:44 AM
Cloud9's Avatar
Dealer : Manhattan Beach Toyota
2002 Toyota Tundra
Last Online: 09-26-2009 12:25 AM
Cloud9 is on a distinguished road.
Cloud9's Photo Albums
Thumbs up You're OK
Oil pressure increases as the pump spins at higher RPMs. Your Oil pressure going up IS totally normal as you speed up, and it should drop when you drop the RPMs. So you're good to go.
I hate seeing it on low, too though, and wish Toyota have gone the route of putting the actual P.S.I. on the guage instead of Low and High. I don't know if low is below what it should actually be or not. That's what it makes you think at first. They probably should've put the L lower than it is, it gives you a false sense of insecurity. It beats an idiot light, but not by a whole bunch.......
Old 05-29-2002, 10:10 AM
TundRoss's Avatar
Dealer : Boch Toyota
2002 Toyota Tundra
Last Online: 09-17-2009 12:37 PM
TundRoss is on a distinguished road.
TundRoss's Photo Albums
I agree. since the oil pump is geared directly to the engine, the faster the engine spins, the higher the oil pressure. You'll also notice that when the oil is cold, thick, and hard to move you get a higher reading than when it's hot, thin and flows easily.
My Baby.......
.......a little old, but it's paid for.
Old 05-29-2002, 01:04 PM
basmith's Avatar
2002 Toyota Tundra
Default I guess I look dumb now
My gauge just now started to fluctuate with speed changes. It used to stay around H all the time. I guess it just needed some time to adjust. Thanks for clearing this up guys. I'm glad I didn't bring it in to the dealership.
Old 05-29-2002, 03:24 PM
Dealer : Thousand Oaks Toyota
Last Online: 10-25-2009 04:26 AM
Mr. Ving is on a distinguished road.
Mr. Ving's Photo Albums
How many quarts are you guys using?
Old 05-29-2002, 03:26 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Yesterday 08:35 PM
nhparrot's Photo Albums
Just about 6.5 qts on a oil/filter change on the V8.
~Glenn
Old 05-31-2002, 09:32 AM
cslinger's Avatar
Dealer : Beaman Toyota Co.
2002 Toyota Tundra
Last Online: 10-30-2008 02:04 PM
cslinger is on a distinguished road.
cslinger's Photo Albums
Default That is normal
The gauge in the Tundra acts like a real measure of the oil pressure at any given moment and at times like idle all trucks oil pressure drop and it is natural for it to flutuate while driving.
Other manufactures just use a different kind of gauge that is basically a oil pressure is good or oil pressure is bad kind of thing.
It is natural for the Tundra and it will drop to a little above the L when at idle etc.
Old 06-02-2002, 03:57 AM
Lazy Ace's Avatar
Mr. Magoo
Dealer : Capitol Toyota
2008 Toyota Prius Black as coal
Last Online: Today 05:07 AM
Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything. Lazy Ace has done just about everything.
Lazy Ace's Photo Albums
It could be worse guys. At least the Tundra doesn’t have a low oil pressure-warning bell like the old Kenworth I used to drive had. Man, every time you dumped the clutch this bell would go off very loudly.
In the winter, driving between Salt Lake and Rock Springs, you’d be damned near deaf when you pulled in!
Old 06-03-2002, 07:29 AM
Tundrav8yamaha's Avatar
Banned
Images: 100
Default gauge
i was about to say the same thing the gauge measures low to high pressure andread's funny took that in first mo i had my tundra was told te same thing its a normal byproduct......
Old 06-11-2002, 12:07 AM
Dealer : Stevens Creek Toyota
Last Online: 08-16-2009 10:56 AM
akauth will become famous soon enough.
akauth's Photo Albums
Default Oil pressure specs
Since I just put 5w30 in and put in a much larger filter I notice that my oil pressure gauge went from touching the second mark with 10w30 synthetic when idling (air off and hot) to halfway between the L mark and the second mark when idling and hot.
Also at 60 mph, it used to be above the middle of the gauge when running at speed and now it's almost exactly in the middle of the range when running at speed.
I looked up the required pressures in the manual.
At idle:
the minimum pressure is 29 kPa or 4.2 psi.
At 3,000 rpm:
the pressure range is 294 kPa - 588 kPa or 43 - 85 psi
Alan
