This is a discussion thread titled "4x2 Tacoma rear diff. ?", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 04-25-2005, 11:38 PM
Dealer : Sterling Mccall Toyota of Fort Bend
2003 Toyota Tacoma
Last Online: 02-28-2007 02:22 PM
asoij247 is on a distinguished road.
asoij247's Photo Albums
Default 4x2 Tacoma rear diff. ?
I just hit 30k on my 03 Taco prerunner, i want to switch to full syn. gear oil. Can someone tell me the precedure needed to do this please?
Old 04-26-2005, 01:40 PM
Dealer : Moose Jaw Toyota
2003 Toyota Tundra White Regular Cab,
1995 Toyota Tercel 1994 base tercel
Last Online: 01-06-2009 10:23 AM
file014 may have some regrets.
file014's Photo Albums
Drive 10+ miles to warm up the diff. Get a 24mm socket and probably 4 QTS of gear oil. You also need a funnel with a short (4-6 inch) flexible tube on the end. Check owners manual for how much gear oil and what grade (probably 75W140 unless you have the TRD LSD). Use the 24mm socket and remove the fill bolt FIRST, from the back side of the diff. If you cant get the fill bolt out, but you drained the diff, you are stuck with no gear oil and a truck you cant drive. After getting the fill bolt loose, remove the drain bolt and drain into an oil pan. Clean the metal shavings (metallic sludge) off of the magnetic drain bolt. Replace the drain bolt and torque it (I dunno what torque, I just get it tight). Use the funnel and tube to add gear oil to the fill bolt until it dribbles back out the hole. Replace fill bolt and torque it. Drive around a couple of days and make sure you arent leaking. Oh yeah, use synthetic gear lube, like Mobil 1.
Bookmarks
Similar Threads for: 4x2 Tacoma rear diff. ?
Tacoma: Rear Leaf Springs xSupaKx Suspension & Axle 6 10-30-2007 05:31 PM
'05 Tacoma Rear Spring Differences laugs1 Suspension & Axle 3 03-02-2005 10:10 AM
2005 Tacoma power sliding rear window XRunner17 Interior & Exterior 1 11-26-2004 03:43 AM
Metal fragments in rear diff oil kalwaus Engine & Drivetrain 21 05-25-2002 05:52 PM
Rear Diff Air Valve West Texas Engine & Drivetrain 5 05-07-2002 09:09 PM
