Old 04-29-2005, 08:40 AM
Malachi's Avatar
Dealer : Toyota of Greensburg
2004 Toyota Tundra
Last Online: 09-10-2009 04:21 PM
Malachi is on a distinguished road.
Malachi's Photo Albums
Default Fram Air Filters
Anyone using Fram air filters on their Tundra? Are they a good replacement for the stock Denso air filter?
Old 04-29-2005, 09:33 AM
RitcheyRch's Avatar
Fellow Tundra Owner
Dealer : Frontier Toyota
2002 Toyota Tundra
Last Online: 11-06-2009 11:33 AM
Images: 2
RitcheyRch is on a distinguished road.
Send a message via AIM to RitcheyRch RitcheyRch's Photo Albums
Stick with the factory. If you do a search you will find that the Fram filters are not as good as you would expect them to be.
Old 04-30-2005, 11:56 AM
Dealer : Russel Toyota
Last Online: 03-12-2006 06:51 PM
Stooge is on a distinguished road.
Stooge's Photo Albums
The Purolators look to be an exact copy of the Toyota branded item. Both are now made in Thailand, and probably by the same sweat shop. So buy what ever's cheaper.
Old 04-30-2005, 01:01 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
I haven't seem any authoritative comparisons of different brands of "paper" air filters. The main difference some folks notice is the quality of the rubber edge and how well it seals in the air box. There likely are quality differences, but I have only seen testing against oiled cotton (K&N, et al) and oiled foam.
I buy Denso filters from an online source whenever I need any parts...I order a couple of filters at the same time. It spreads the shipping cost. Locally, I think I'd get WIX or Purolator.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 05-02-2005, 08:31 AM
Malachi's Avatar
2004 Toyota Tundra
Default Purolator Air Filters
Ken
Ken,
It is interesting that you mentioned Purolator. I use the Pureone oil filter but I have never tried their air filters. I have access to an Advance Auto that sells Purolator products. I may have to check them out. I'm not sure of the quality of their air filters but if they follow the oil filters, they should be a good replacement and of good quality.
Maybe someone can respond that is using them in their Tundra and can verify the quality.
Old 05-02-2005, 09:31 PM
Dealer : Fremont Toyota
2002 Toyota Tundra
Last Online: 11-05-2009 08:47 PM
Triple BB is on a distinguished road.
Triple BB's Photo Albums
I was looking at a TRD filter and read somewhere else they're made by K & N.
Old 05-02-2005, 09:46 PM
ricqik's Avatar
Last Online: 10-24-2009 01:53 PM
ricqik is on a distinguished road.
ricqik's Photo Albums
I've been running fram air filter since the oem was ditched almost 100k ago. Paper filters don't deteriorate like oil filters because they don't get chemical on them, just dirt and dust. Any paper filter is better than k&n for filtration.
Stuffs:
JBA Headers, Costum Exhaust, ASP U/D Pulley, Centric Crossdrilled & Slotted Fr Rotors, LSD, IS Kit, Manik SS Steps, HID Headlights & Fogs, Pacer Tailgate LED Light Bar, Blacked Out Headlight & corners, LED tail lights
Toys:
04 Skeeter ZX250 w/300 Vmax HPDI (79.35gps so far)
05 Polaris Sportsman 700TWIN EFI (rarely ride)
Old 05-03-2005, 09:01 AM
Malachi's Avatar
2004 Toyota Tundra
Default ricqik
It may not be noticable, but is there any difference in power using the Fram as opposed to Denso? V8 Toilet got a little faster track time using the stock Denso air filter vs. TRD. I wonder if Denso would perform better than Fram or Purolator. If Denso doesn't make a difference in the way the 4.7 runs then buying the Fram or Purolator would be a good option.
Since you have been using Fram for about 100K, how has it performed for you?
Old 05-03-2005, 08:46 PM
ricqik's Avatar
My truck didn't feel stronger till almost 100k. Had alot of power when new then as I got used to the tq, it felt like I need more but as my mileage got closer to 100k it felt like my truck got stonger. Maybe it's just in my head but it does tow better than before, more get up. I actually went back to oem twice, at 40k and 60k, there's no difference in power that I noticed. I change the filter every 20k. The filters have just a slight gray to it when I change them, both oem and fram so it was a better cost saving to go fram.
Stuffs:
Toys:
Old 05-03-2005, 08:52 PM
EngineerBoo's Avatar
2005 Toyota Tacoma
Last Online: 04-25-2007 05:33 PM
EngineerBoo is on a distinguished road.
EngineerBoo's Photo Albums
I don't use Fram ANYTHING on my vehicles. (Kinda like putting a Cracker Jack ring on the finger of a supermodel!)
Just my opinion, though......
Rick "Engineer Boo"
http://www.cardomain.com/id/engineerboo
Baldwin oil and air filters? turnipgreen Engine & Drivetrain 1 07-23-2004 12:21 PM
Air filters and quick throttle response Tarpon Engine & Drivetrain 6 03-31-2004 01:35 AM
after market air filters schmenge Engine & Drivetrain 2 10-13-2003 05:03 PM
Cotton Gauze type drop in air filters like K&N and TRD v8Toilet Engine & Drivetrain 9 06-08-2003 10:58 PM
Air Filters nhparrot Engine & Drivetrain 0 03-28-2002 02:37 PM
