Originally posted by Agent WD-40
Toyota probably put a higher temp thermostat in because it helps the engine warm up faster. By doing that you reduce emissions. The most emissions are produced when the engine is still cool. The cats also need to have exhaust at a certain temp to do their job best. Another thing to consider is that the tranny might also think the engine is not warmed up and use the different shift pattern for when the engine is not warm. It usually keeps it in gear longer and keeps it out of OD. Other than that, I guess you could give it a try and see what happens.
The truck warms up just as fast with any thermostat. The warm up time depends on the outside temperature and the load on the engine. The thermostat only determines the temperature that the engine will maintain. If you put in a 180° stat, the engine will warm up to 180° just as fast as it will with a 192° stat.
With a lower temperature stat there's the risk that the engine's computer will think that the engine is never warmed up fully and keep the engine running rich. That'll just waste fuel.
Ken
