This is a discussion thread titled "Actuator replacement", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-02-2005, 04:50 PM
Iron Horse Herb's Avatar
Dealer : Gates Toyota
2002 Toyota Tundra
Last Online: 04-21-2007 11:07 PM
Iron Horse Herb is on a distinguished road.
Iron Horse Herb's Photo Albums
Default Actuator replacement
Took my 02 4x4 in because the 4 wd light was flashing when I took it out of 4 w high. Now let me back the story up a bit. Our last day of snow here in Northern Indiana I hit the 4 wd button and it woul not go in to 4wd. Hit the button again and it came out and I left it in 2 wd for the morning. That afternoon I put it into 4wd and it went in just like it should, then when I took it out I got the flashing light that says it is not all the way out I guessed. I posted the question on the TS forum and most said check to see it the motor would turn and nothing lodged in the way to keep it from moving. I then opened the motor case and pulled the gear out to inspect it and when I started to replace it I noticed it would have to be put back the exact way I removed it. Now I was hosed for sure, so I took the fuse out and forgot about it for now. later I took to the dealer to see what they would say about it. An hour later they told me the actuator assembly was bad and it would be $1789.95 to fix it. Someone on the forum had sort of the same problem and it was $400.00 to replace the drive motor.
Something doesn't sound right to me.
Any Suggestions?
iron Horse
Old 05-02-2005, 05:01 PM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
dyogim will become famous soon enough.
dyogim's Photo Albums
I bet you the majority of the cost is labor. Since, you have to remove the front diff out. I would look at toyota salvage yards for an actuator.
Mike - http://dyogim.blogspot.com
Old 05-02-2005, 05:10 PM
Mike Donofrio's Avatar
Dealer : Gateway Toyota
Last Online: 01-14-2008 05:40 PM
Mike Donofrio is on a distinguished road.
Mike Donofrio's Photo Albums
Any Suggestions?
iron Horse
That price sounds a bit steep. Do you run your 4WD often? If not, it could just be some corrosion on the actuator and/or shift fork assy Dyogim's right--a new motor from a salvage yard CAN'T cost more than a few hundred dollars. My sig line has a PDF attached that can help you in removing the diff to replace the motor assy if you are a DIYer. It's real easy to do ;-)
Sometimes, when you show up to a dealer with things all taken apart, they charge you for their troubleshooting and a little 'extra'. Let us know how we can help, $1800--for anything short of a new diff--is a bit steep IMO...
Mike D
Lost traction? Lock it up!!! Front locker install instructions here: http://www.teddnet.com/lockrite.htm
Upgrades: PA 3" Body Lift, Powertrax No-Slip rear, Detroit ezLocker front, Fabtech/Fox front, Wheeler's AALs, TC Front Diff Drop, 16 x 8 MB Wheels, 285/75R16 Goodyear Wrangler MT/Rs, Pioneer Head Unit, Infiniti Reference speakers [front and rear], 150 W bridged amp to bandpass enclosure, 6 CD changer with IR remote, iPod mini and xm hardwired into stereo, Toyota drop in bedliner, and Tonneau cover
Old 05-02-2005, 05:17 PM
RockyMtnRay's Avatar
2003 Toyota Tundra
Last Online: 10-12-2008 11:01 AM
RockyMtnRay's Photo Albums
Question No Warranty?
Any Suggestions?
iron Horse
If you haven't exceeded 60,000 miles, you should still be covered by the drivetrain warranty on this repair since the actuator is part of the drivetrain (5 years, 60000 miles warranty coverage).
Ray
Bookmarks
