Sounds like the concept of a synthetic blend. There are many potential problems with this, however. The additive package is different between ATF and engine oil, the viscosities are different, the ratio may not be ideal, etc. If you want a blend, buy a blend, but I don't recommend mixing your own blend at home...
Unfortunately, I don't know of a synthetic blend ATF on the market. But keep in mind that the gap between synthetic and conventional ATF is one of the largest in the lubrication industry -- synthetic ATF is really that superior to conventional ATF.
~ Fred
"Beware he who would deny you access to information, for in his heart he dreams himself your master."
