Originally Posted by ALL MOTA
Well, it looks like I'm going to have my TRD/Kazuma LSD installed next weekend. I just wanted to know what I need in order for the install to go smooth (driving out about an hour to get to the shop). I read on a previous post that it requires an 'install kit' from the dealer. Anyone have a part number for the kit and what does it include? Do I need new bearings, shims, or anything else? I currently have 55K miles.
Also, what kind of LSD diff fluid do I use? Should I go with synthetic?
http://www.tacomaterritory.com/~gril...D_LSD_install/
You dont need any install kit if you are just swapping out carriers while retaining your stock ring & pinion - it is Unlikely you will need to reshim
Here is what I used for my bro's LSD install - in the above link:
2) rear axle seals
2) carrier bearing 90366-51001
1) tube RTV (FIPG) - You can use the precut toyota gasket also
~3.X qts of gear oil
The TRD LSD should include 1 tube of friction modifier
I changed the axle seals even though they were still good- its up to you - but it doesn't hurt to have a spare pair in case they are damaged upon removal/re-installation of the rear axles shafts
I also changed the carrier bearings - these can be recycled if they are not damaged upon removal - However- I'd recommend new bearings
On a previous discussion - Toyota & Eaton may recommend dino gear lube plus the additive-
I believe the key is the additive and I am indifferent about the use of synth or dino gear lube
In the pics above- Redline synthetic gear oil was used with the addition of a tube of the lsd friction modifier
