This is a discussion thread titled "Replacing Oxygen sensors: which brand", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 05-24-2005, 09:08 PM
fastman9's Avatar
Dealer : Toyota Carlsbad
Last Online: 12-16-2008 07:43 PM
fastman9 is on a distinguished road.
fastman9's Photo Albums
Question Replacing Oxygen sensors: which brand
I'm having a local muffler shop install my new JBA headers and was going to install new oxygen sensors as the light is already on.
My question(s) are:
Is $250 a reasonable price for the replacement of the headers? I know time is money but just checking.
Are all oxygen sensors the same, other then the ones that come with the OEM connectors? Can I save a couple of bucks here by getting some thing other then say Bosch?
Old 05-25-2005, 10:09 AM
fredmertz's Avatar
Dealer : Miller Toyota Of Anaheim
2004 Toyota Tundra
Last Online: 12-06-2008 03:34 AM
fredmertz is on a distinguished road.
fredmertz's Photo Albums
Default O2 Sensors
As far as price for the header im not sure what they go for But on the o2 sensor Bosch direct fit sensors are a great product. I know when I purchased a Bosch o2 for my old 1991 4runner there was a Factory Nipon Denso in the box. As long as you go with the direct fit ( factory connector) Bosch, Denso , or even walker should be fine. PM me if you need a part number . Price wise ,Most expensive to least Bosch , Denso then walker .
2004 Double Cab- Phantom Gray-SR5-2WD
Samsung Bluetooth Car Kit
Bilstein BTS Coil Overs w/spacers
T/C UCA
XM Radio
Old 05-25-2005, 10:19 AM
TundrastruckDave's Avatar
Dealer : Greenville Toyota
Last Online: 01-03-2009 09:10 PM
Not sure about the "price" given to you on the header install, since I've never opted for a set? At least not yet... . However, I can tell you (from what I've read here at TS.com) header installations on the Tundra are a real B!TCH! Although, you [yourself] "can" do it.
What I can offer you though, is some insight on the O2 sensors. Depending on "what" you end up going with, it WILL make a difference! If you opt to go the "cheapest" route, you'll probably be sorry you did, in the long run. The cheaper sensors out there, DO NOT come with the OE wiring harness/"connector" for a plug-n-play type scenario. What you (or the muffler shop in this case) will have to do is, take the old sensors and clip-off the wiring harness and then, splice it onto the new sensors. Short-n-sweet... BAD idea! However, there ARE alternative OE O2 senors out there, which DO have the connector "attached" and that's what I'd recommend you use. They're almost half the price of an O2 sensors from Toyota at $140+ each! Here's one of the few places I've found O2 Sensors at a decent price.
Hope this helps...
Mods to Date:
Mods to Come:
265/75/16 BFG A/T's,
Possible Mods:
Old 05-25-2005, 10:40 AM
fastman9's Avatar
One other question if I may. How do I reset the check engine light?
Old 05-25-2005, 11:02 AM
Disconnect the negative lead on the battery for at least 30 minutes. I let mine stay disconnected overnight, but I think the general conscientious (here at TS.com) is 30 minutes...
Mods to Date:
Mods to Come:
Possible Mods:
Old 05-25-2005, 07:04 PM
Toasted Coastie's Avatar
Locked in for life
Dealer : Toyota of Nashua
Last Online: 12-10-2008 06:53 PM
Toasted Coastie is on a distinguished road.
Toasted Coastie's Photo Albums
$224 is what I paid for the new set of o2 sensors. The new set supercedes buying them seperately from the dealership. I didn't mind paying it. They come with the antiseaze already on it.
I paid $300 to get my headers installed. When I took the right side off later to replace an o2 sensor, it took 3 hours to take of, put in o2 sensor, new gasket and put back on. this time did NOT include puting the truck on jacks, and getting all the tools together before starting, and I had another guy helping, and I'm a hack.
It is better to remain silent and have people wonder if you are an idiot, rather than to open your mouth and prove to everyone you are an idiot beyond all doubt. ~ Jim Rogers
Old 05-31-2005, 11:13 AM
fastman9's Avatar
Question
Hope this helps...
Thanks for the link. I don't see a difference between the left and right O2 sensor though? Aren't they different? I see a different part numbers other places.
Old 05-31-2005, 01:31 PM
Depends on your VIN number in some cases, as well as, your engine (i.e. V6, V8, etc.)
Mods to Date:
Mods to Come:
Possible Mods:
Old 05-31-2005, 03:24 PM
fastman9's Avatar
I can see that they are different for V8 and V6 yes, but VIN too?
Looking on the bottom of this page I don't see a difference.
Anyone point me in the right way for a 2000 V8 2WD pre Cat left and right O2 sensors?
Thanks all in advance.
Old 05-31-2005, 04:09 PM
O.K., looking at the info at the bottom of this page, I'd have to assume that both exhaust manifold O2 Sensors are the same as they are considered the "front" sensors, while the "rear" one IS different.
Keep in mind, I'm basing that, on what I've seen with my early model Tacoma. Like you, I too was confused over part numbers. You would "think" that the "front and "rear" (i.e. before and after the cat) would be different. Instead the ones on my Tacoma are the SAME... "front" AND "rear"... go figure?!
Since the new Tundras utilize a sensor on each manifold "plus" one behind the cat (I think), it doesn't make much sense that Toyota would use 3 different O2 sensors?! Especially when 2 of the 3, are basically registering the same emmissions info, from relatively the same spot on the engine... just opposite sides. That's kinda' why I think the 2 on the manifolds (i.e. "front") are the same, with a different one "behind" the cat.
That's my hypothesis anyway...
If all else fails, try calling Denso (the company that makes the sensor) at their technical hotline (800-336-1123) and see what they have to say.
Mods to Date:
Mods to Come:
Possible Mods:
Old 06-02-2005, 05:24 PM
fastman9's Avatar
I found even cheaper ones here
I ordered them. I'll let you all know how it goes.
Bookmarks
Similar Threads for: Replacing Oxygen sensors: which brand
Thread Thread Starter
