Old 05-28-2005, 12:39 PM
03SilverSky's Avatar
Dealer : Modesto Toyota World
2003 Toyota Tundra
Last Online: 04-21-2007 12:19 AM
03SilverSky is on a distinguished road.
03SilverSky's Photo Albums
Default Oil Change Advice Please
My truck is approaching 15,000 and I want to make the switch to a synthetic oil. I am going to attempt to do my own oil and oil filter change ('03 iForce V8). I don't want to take my own oil to the dealership and have to wonder if they actually put it in my truck. The following are the steps I am going to take. Please set me straight on anything I have not thought of or anything that is not necessary.
1) Run the truck to heat and thin out the oil in the pan.
2) Remove skid plate.
3) Remove oil filler cap.
4) Remove drain plug and drain oil. (Is it lefty loosy?)
5) Remove filter. (What's a good filter wrench and is it lefty loosy?)
6) Replace plug.
7) Lube seal on new filter. (Using Fram 7,000 mile filter)
8) Install new filter, hand tight only.
9) Add engine oil. (Using Mobile 1 10-30)
10) Replace filler cap.
11) Check dipstick.
Any tricks or hints is appreciated.
Built 06/2003 SR5 Acc. Cab V8 Silver Sky Metallic 4x2
Old 05-28-2005, 01:54 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
1a) Park on a level surface.
4a) It's hot!
6a) Install a new gasket, looks like a washer, could be aluminum, copper, fiber, or nylon.
6b) My first choices are Toyota or Purolator Pure One. Next are Purolator, WIX, NAPA-Gold, Hastings, Baldwin. Amsoil is expensive and just about the same as the Hastings/Baldwin. Mobil 1 and other filters made by Champion Labs (STP, (U.S.) Bosch, K&N) have a new construction that I don't like.
Everything on our trucks I've found so far is the usual right hand threads to tighten.
Notice the hooks in the front of the skid plate that help hold it in place. You need to wiggle these free when you remove it. They help hold it up when you reinstall. I use a knee to hold the plate up while I'm putting in the first bolt in the back or removing the last one from the back of the plate. Put all the bolts in loose, then tighten them all. Otherwise, one or more won't line up. Be careful that the bolts go in by hand...if not, they're cross threaded and will tear out the threads.
Your Mobil 1 oil will be good for at least the full oil drain interval shown in your owner's manual. Don't throw away good oil early.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 05-28-2005, 03:36 PM
2003 Toyota Tundra
I just got back from Wally World and picked-up most everything I need. I see KLS recommends a new gasket. Edit...Went to dealer and received a new plug gasket (free).
Another concern I have is about the new filter I purchased. It is a FRAM Extended Guard XG3614. It is supposed to last 7,000 miles. My concern is this filter is 1 to 2 inches shorter than the Toyota filter I currently have on my truck. Does this matter or do I need to return this filter for another brand? The FRAM book states this filter will fit my truck.
Old 05-28-2005, 03:59 PM
nucleus's Avatar
2005 Toyota Tacoma
Last Online: 12-08-2008 08:12 PM
nucleus is on a distinguished road.
nucleus's Photo Albums
12) Run vehicle and check for leaks.
13) Re-check oil level.
14) Take used oil to recycling center.
wherever you go, there you are
Old 05-28-2005, 06:23 PM
Dealer : Alamo Toyota
2003 Toyota Tundra
Last Online: 11-06-2009 05:31 PM
gquenstedt is on a distinguished road.
gquenstedt's Photo Albums
The Fram filter will fit the Tundra V8, and V6, and many other Toyota vechicles, and quite a few other brands of vechicles. So, it is not specific to your engine, like the Toyota filter. Alot of people have said they have problems with the Fram filters on their Tundras, such as a klunk noise at startup, from the oil running out of the filter. I don't know, as I have not used a Fram on my Tundra. I guess the shorter filter would decrease the oil capacity by a couple ounces. I run the Toyota filters wich I bought a case of 10 on ebay. So, I guess the fram filter is ok, but the Toyota filter is preferable.
Just wondering, how did you get a free gasket from your dealer? My dealer charged me $1.68 each for the stupid gasket.
Old 05-28-2005, 09:16 PM
2003 Toyota Tundra
I called the dealer's parts department and asked if they had them and how much. I was told $0.90. I went down there and the guy had it right under the counter, handed it to me and said no charge.
Old 05-28-2005, 11:37 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
All the photos with round cardboard end caps in this group of filters are Frams. Pennzoil filters are relabeled Frams.
http://groups.msn.com/OilFilterStudy...hoto&PhotoID=1
Ken
Oil Filter Change nhparrot Engine & Drivetrain 10 06-07-2009 07:15 PM
synthetic oils - yes or no? nhparrot Engine & Drivetrain 21 01-29-2008 05:25 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Best oil to run in the 4.7 Tundra? SMOKEATR Engine & Drivetrain 69 03-22-2007 06:33 PM
GEORGE! or anyone else..Whats The Best "DINO" Oil nhparrot Engine & Drivetrain 0 03-28-2002 04:21 PM
