This is a discussion thread titled "Transmission Oil Level", within the Engine & Drivetrain forum, part of the Technical & Vehicle Assistance Forums category.
Old 06-06-2005, 12:46 PM
Last Online: 06-06-2005 12:46 PM
cedarwinds2003 is on a distinguished road.
cedarwinds2003's Photo Albums
Default Transmission Oil Level
I just flushed my transmission oil level yesterday. Before doing the work (on level ground), I checked the level of the engine while cold and it was right in the same spot as the 90 degree bend in the dipstick, well above the marking indicators. After driving for 15 minutes, the level had dropped to below the two notches indicated the appropriate level for a hot engine.
After flushing through 16 quarts and driving the truck for 30 minutes, the level was in the same spot as before and this morning before driving it was at the bend again.
I realize the level at operating temperature is most important, but it seems odd that the cold level is so high.
If anyone can provide some insight it would be appreciated.
Old 06-06-2005, 01:25 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Engine running & transmission in Park?
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
Old 06-06-2005, 06:04 PM
2005 Toyota Echo Hatchback
Last Online: 11-27-2008 05:11 PM
pcosens is on a distinguished road.
pcosens's Photo Albums
Gravity - any fluid in the channels / pumps/ valves of the transmission will drain downward. The only level that matters is warm, running, after going through the gears including reverse to fill all circuits . . . as per owners manual.
P
Bookmarks
Similar Threads for: Transmission Oil Level
synthetic oils - yes or no? nhparrot Engine & Drivetrain 21 01-29-2008 05:25 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Best oil to run in the 4.7 Tundra? SMOKEATR Engine & Drivetrain 69 03-22-2007 06:33 PM
Oil Filter Change nhparrot Engine & Drivetrain 7 02-07-2006 08:33 PM
GEORGE! or anyone else..Whats The Best "DINO" Oil nhparrot Engine & Drivetrain 0 03-28-2002 04:21 PM
