Originally Posted by MarkM
This topic gets very confusing to me.
Can anyone answer this question?
If you have the TRD Off Road which comes with a lockable rear diff., what happens when you order the VSC with the LSD combo? Do you get both features at different times? Does LSD work in only 2wheel drive or does it work in 4wheel drive? I know these are technical questions, but I'm still not sure how all this technology works together.
The VSC/LSD combo is electronic brake manipulation, has nothing to do with the differential. So yes, you can get the locker and the have the quasi LSD benefits from the VSC option. I believe VSC is disabled when the locker is engage, and I think it turns off when in 4wd as well.
As far as how it works.... the VSC uses your ABS sensors to relate wheel speed to vehicle speed. Wheelspin is detected when the wheel is turning faster than the vehicle is traveling. When this happens a number of things can be done ( not sure about Toyota specific here, just in general) Either the brakes can be applied to the spinning axle, or power output can be reduced. I've driven vehicles that had each system. The eletronic LSD takes this a step further and differentiates which wheel is spinning and applies the brakes to that partiucular wheel. Since Open differentials transfew power to the wheel with the least resistance, power is transfered from the spinning wheel to the wheel with more traction.
Personally I don't like electronic traction control. If I need to keep my wheels from spinning I let up on the throttle. I also like simplicity, less to break, less expensive to fix when things do break.
