Old 06-19-2005, 11:59 AM
Dealer : Kenny Kent Toyota
1995 Toyota Paseo
Last Online: 03-12-2008 12:39 AM
davebatey is on a distinguished road.
davebatey's Photo Albums
Default Check Engine light Code P0155
It states bank 2 sensor 1 is the problem. Which side of the truck is bank 2?
Drivers or Passengers?
Thanks
2001 Tundra Limited Access Cab, 4x4, TRD
Old 06-20-2005, 05:38 AM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 11:27 AM
nhparrot's Photo Albums
Thanks
Passenger, see attached
~Glenn
Old 06-20-2005, 11:01 AM
1995 Toyota Paseo
WOW thanks Parrot!!! I knew one of you guys would come through for me.
Old 06-30-2005, 09:14 PM
1995 Toyota Paseo
You are not going to believe this but that page is WRONG!!!
Bank 2 sensor 1 is passenger side in the exhaust manifold or the upstream sensor.
That picture states that it is behind the converter AKA the downstream one. Toyota put out a TSB stating that there was some typos and to help clear up confusion...I only found this out because I spent $65.00 on the rear one and the code came back. After calling the toy dealership they explained that some of the documentation was incorrect and they set me straight...now i am out another 65 bucks on another sensor. So far it is working fine.
I am now going to work on a new book..."Things I could have done with $65.00"
LinkBack to this Thread: http://www.tundrasolutions.com/forums/engine-and-drivetrain/42090-check-engine-light-code-p0155/
Posted By For Type Date
P0155 - trouble codes swicki - powered by eurekster This thread Refback 10-18-2007 03:58 PM
Check Engine code PO161 jcsinc Engine & Drivetrain 5 06-10-2008 06:29 PM
Check Engine Light? vegasgreed Engine & Drivetrain 22 07-31-2006 08:33 PM
Check engine light @ 41,000 miles????? Tundratuff Engine & Drivetrain 30 02-27-2006 11:43 PM
Check engine light (gas cap not on tight code) wrandall Electrical & Computer Systems 8 02-15-2005 12:37 AM
Check engine light ON kolaroman Engine & Drivetrain 1 09-23-2003 03:09 PM
